Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 04-06-2007, 11:01 PM   #1
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
RadioShark2 - Modified Skin - For Touchscreens
Ok I edited the skin of the default Radio Shark 2 skin to make it more touchscreen friendly. It's not perfect but I wanted to go ahead and release what I've done, so others may take advantage of it.
I will be releasing a better looking, truly fresh from the ground up skin, as this one is just a scaled up version of the default skin, so stay tuned.
.1 Beta Release (Dowload HERE - @ CarPCNet)
Screenshot:
Extract this archive to the root folder of your Radio Shark program folder.
It will overwrite the RSOptions.ini file, so back that up first if you want to keep your default settings.
For the modified skin to work, the RSOptions.ini file must be edited. The second to last line will read:
FullSkinFile=Skins\Standard\Skin_Standard.xml
change that to:
FullSkinFile=Skins\RR_Skin\Skin_Standard.xml
If you just extract the modified skin to the root folder, you will overwrite that file and the program will use the new modified skin.
I haven't been able to test ALL of the features, so please let me know if you encounter any errors or misplacement for display items.
To create your own skin, edit the PNG graphics in the \SKINS\RR_Skin\ folder. Keep the file names the same.
If you want to make huge changes to the skin (like placement of display items, buttons, etc), you'll have to edit the XML file. Make a backup if you do that. Not all items are relative to the main skin borders, but other items in the skin itself.
If you have any questions, post them in this thread:
The W3bMa5t3r
W3bMa5t3r is offline   Reply With Quote
Old 04-22-2007, 08:08 PM   #2
T_Blaze is an unknown quantity at this point
Are you planning to make RS2 work with the default BMV2 skin? I'm trying to get it to work.
T_Blaze is offline   Reply With Quote
Old 04-22-2007, 10:17 PM   #3
W3bMa5t3r's Avatar
I'm afraid not. I know nothing about the plugin created nor do I have any clue on how to interface RS2 with RR... I simply modded the RS2 skin to be more touchscreen friendly for embedding. Hopefully someone else will be able to take that on
Old 03-01-2008, 02:53 PM   #4
if you can point me in the right direction to start off as what i need to do, i would be happy to do this. How would i make the default bmv radio skin work with rs2?
MMI eXtnd proTONEd FP Skins 77 04-17-2008 06:26 AM
New skin Floatingpi CF Skins 20 12-22-2007 01:31 PM
Mauri RR skin mauri RR Skins 122 12-06-2007 10:50 AM
Open Source Skin Editor for RR lbooker Road Runner 66 04-16-2007 02:51 AM
Some type of memory bug with Skin? civic5zigen Road Runner 4 10-30-2005 08:39 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
