The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Thread Tools Search this Thread Display Modes
Old 05-31-2007, 07:02 AM   #46
GuMiSZu's Avatar
Vehicle: 94/Toyota/Corolla 1.6GLI
My Photos: (0)
the USBradio.dll is compatible with ADS? or can I change this dll with ads compatible one?
thx...
Englishlessness :(
GuMiSZu is offline   Reply With Quote
Sponsored Links
Old 05-31-2007, 11:07 AM   #47
proph's CarPC Specs
proph's Avatar
Vehicle: 1999 Dodge Dakota
My Photos: (0)
just change the dll w/ the compatible one after the installation.
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
proph is offline   Reply With Quote
Old 06-03-2007, 03:45 AM   #48
307SW_NLD's CarPC Specs
307SW_NLD's Avatar
Vehicle: 2003/KIA/Sorento 2.5 CRDI
My Photos: (0)
Quote: Originally Posted by RS200Z View Post
There seems to be a memory leak with the RR_ICERADIO.DLL. After starting RR and leaving it idle, you can see that it's memory usage keeps going up from Task Manager.
After I remove the line "X,RR_ICERADIO" from my menu skin, the problem disappeared.
Hmm. been watching memory usage but did not notice the memory usage to go up. How fast did this happen?
My car: 2003 KIA Sorento 2.5 CRDI AUT
Hardware: EPIA SP13000, 60Gb 2.5"HDD, M1-ATX, Lilliput 7", RADIO SiLABS, K8055 BOARD
Software: Road Runner, FreeDrive, PowerDVD, WinXP SP1
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 50 % DONE
307SW_NLD is offline   Reply With Quote
Old 06-03-2007, 05:48 AM   #49
GuMiSZu's Avatar
My Photos: (0)
How can I setup RR to use this plugin?
i'd life to try it
thx
Englishlessness :(
Old 06-03-2007, 08:48 AM   #50
307SW_NLD's Avatar
My Photos: (0)
i'd life to try it
thx
1. You can use my skin that you can download (see couple of posts back)
2. You can read the pdf I have attached in the plugin download and use the example
Basically.
1. Do not set RadioMode to 7 in RR.INI
2. Register the plugin dll after copying it to the RR directory (together with the ini)
3. edit your menu.skin and add X,RR_ICERADIO
Now create a skin for your radio (or use the example from the zip)
The labels and commands you can use are documented in the pdf.
Sponsored Links
Old 06-03-2007, 10:18 AM   #51
The Vauxhall Vectra Project
ccsnet's CarPC Specs
ccsnet's Avatar
Vehicle: Vauxhall Vectra C SRI XPack Auto - v5 ( Via 12000 based ) Sygic & With FreeICE
My Photos: (0)
What do you set it too then ? I've already changed mine......
Terran
ccsnet is offline   Reply With Quote
Old 06-03-2007, 11:53 AM   #52
My Photos: (0)
zero works
1Munkey is offline   Reply With Quote
Old 06-03-2007, 12:19 PM   #53
FreeDrive Creator
CdRsKuLL's CarPC Specs
CdRsKuLL's Avatar
Vehicle: Ferrari 360 (nearly)
My Photos: (5)
any setting will do as your not using the radio bit, so it doesnt matter at all
CdR
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 06-04-2007, 05:51 AM   #54
GF-ler's Avatar
Vehicle: Mazda
My Photos: (0)
when will it be true, that i can use a ADS stick with roadrunner.
and its equal for me if its out or inside roadrunner. i need a result.
and no, ice radio didnt work with it, and the usbradio.dll only shows me the name of the station, but i want all.
GF-ler is offline   Reply With Quote
Old 06-04-2007, 07:18 AM   #55
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
documentation says to run >cmd then change to RR directory and type regsvr32 RR_ICERADIO.DLL
Well no such dll is in the zip file.......
USBRadio.dll is in the zip, but that one fails with a 'cant find entry point'
whats going on...........
Lez.
XM 2.1TD ~ Morette triple headlights+HID ~ Leather kit ~ XC70 alloys
Exhaust rear boxes removed ~ meshed air filter
lez is offline   Reply With Quote
Old 06-04-2007, 07:44 AM   #56
GF-ler's Avatar
Vehicle: Mazda
My Photos: (0)
if you read the documentation, there is nothing who told you to regsrv the usbradio.dll, or ?
why you try it.
you only should register the rr_iceradio.dll, make the entry in the menu.skin and insert the order in your exectbl.ini, nothing else.
if you use the silabs stick, the iceradio is near perfect. you can work with all parameters who are written in the help file.
if you look to post #1, you find a link for the last 1.06 version. it works and its complete.
Old 06-04-2007, 07:49 AM   #57
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
Quote: Originally Posted by GF-ler View Post
why you try it.
maybe I'm stupid.
And I have found I accidently deleted it while unzipping it.......
Doh:
Apologies everyone.......
Lez.
Old 06-04-2007, 09:18 AM   #58
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
It tells me (uk)radio 1 is a country music station..........
I guess its only decoding the RDS data (in this case PTY 10) to an american lookup table, maybe we need a UK dll (hint) with the table entries changed to suit..........(not 'now' I'm not complaining, but later etc, just so its 'right')
Wonder how is this going to affect the probablity of TMC, because that will be different, why the standard had to be reinvented is beyond me...
Lez.
Old 06-04-2007, 09:49 AM   #59
ccsnet's Avatar
My Photos: (0)
TMC is only in the EU... the US has some other name I can't remember...
Re RDS - its an international standard so should be correct.
Terran
Old 06-04-2007, 09:52 AM   #60
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
Terran
Tomato'e tomato all over again.........
the lookup table is different for european / US station classification, of course they are the same (almost) but in a different damn order so two tables are needed to do it right............
I thought the US had TMC on FM?
I know we have it carried on the back of classic FM and associated stations under the parent company, and I think radio 1
tables.
http://en.wikipedia.org/wiki/Radio_D...#Program_Types
Lez.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
radioSHARK Plugin for RoadRunner Evolution VIII RR Plugins 192 09-30-2007 05:55 PM
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 12:32 PM
Problem with radio stations scanning and adding them to the station list sneck RR Bug Tracker 17 10-29-2006 10:55 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 03:43 PM
Sirius Radio Plugin... ThermoDust Centrafuse 7 08-27-2005 08:20 PM
Sponsored Links
Ad Management by RedTyger
