Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 10-31-2007, 10:52 PM   #61
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Quote: Originally Posted by guino View Post
what are we trying to do now ?
EL CAMINO has written a real handy script to edit MP3 ID3 tag info using RR's OSK.
However, when clicking on the tag to edit, it opens up the OSK w/ a blank field. It'd be real nice to pass on the label/tag data to the OSK textbox so that you don't have to re-type the whole thing if you are just editting a letter or two.
Not a huge deal, but more a convinience thing.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 10-31-2007, 10:53 PM   #62
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Pass a value (label) into the OSK when called via OSK to CMD.
Ideally the contents of the variable to which the output is going should be displayed in the OSK if it already has a value.
Sorry if that don't make sense as it's 3am here.
ie from skincommands
"OSKTOCMD;MYVAR;RUNQ;$MYVAR$"
highlighted variable contents should be passed to the OSK
Enforcer is offline   Reply With Quote
Old 10-31-2007, 11:12 PM   #63
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
Quote: Originally Posted by Sal R. View Post
OSK contents still empty.
please go over the install again, the commands are different now, seems that treetop777 have it working. i been using and testing for a couple of days with no issues.
@guino
i do this purely in autoit, but would be nice to do it with RR's code, like the web plugin does
when the button to enter a new url is hit the osk shows "http://www." automatically.something like
Code:
"OSKTOVAR;TAGS;STARTING TEXT"
or even better, in all OSKTO and NUMOSKTO commands. this way can be used with any call. T
EL CAMINO is offline   Reply With Quote
Old 11-01-2007, 11:12 AM   #64
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Would you have any idea why my embedded album art are not displaying now? I haven't done much troubleshooting but it started when i installed the plugin. I use X,mp3art to display most of the album art.
treetop777 is offline   Reply With Quote
Old 11-01-2007, 12:44 PM   #65
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
1-Check if it works again by removing this plugin
2-Change the order of the X, lines -- this does make a difference if there's a bug in one of the plugins.
@EL_CAMINO: I've added a OSKTEXT command to set the text of the OSK/NUMOSK for next release.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-01-2007, 05:01 PM   #66
EL CAMINO's Avatar
!!!thank you!!!! guino.
@treetop777
seems to be the case, cut be something wrong in the mp3art plug in. winamp still shows the albumart, after the changes, and Road Runner doesn't do it after the changes. once again "Guino??"
Old 11-01-2007, 05:40 PM   #67
guino's Avatar
did you do anything in your plugin to provide labels to RR ?? the bug could be in there and that could interfere with other running plugins.
Old 11-01-2007, 06:20 PM   #68
EL CAMINO's Avatar
yes, just one, and is just a regular custom label, which is.
Code:
"!TAGS_COMMENTS"
most of the code is for error trapping, and info reading. i you want i can send you the code, is simple as hell. child's play for you.
Old 11-02-2007, 02:14 AM   #69
guino's Avatar
pm me the code for your Label procedure in the plugin -- it is an extension plugin right ? I'll take a look at it.
Old 11-03-2007, 12:07 AM   #70
EL CAMINO's Avatar
well, as guino release a new updated RR version, the new command to preset the osk text. well be used to load the tag info if any, works a lot faster and looks cleaner, about the mp3Art plugin, seems to have some issues reading the Album art after editing tags. guino will take a quick look at this problem for me.
thank you guino.
EDIT:
i tested the latest version with more than 20 mp3's and the album art is been untouched, still shows in RR mp3Art plugin.
Old 11-06-2007, 05:59 PM   #71
Raw Wave
treetop777's Avatar
Quote: Originally Posted by EL CAMINO View Post
EDIT:
Tested it, the tag shows up in the OSK as intended but I'm sad to say it's still deleting the embedded album art
I fools you because when you go into the editor, the art is there; after you finish editing and return to the audio player, the art is still there BUT go to a different song then go back to the edited song and the art will be gone.
I opened them in tag&rename and they are really gone.
Old 11-07-2007, 01:31 AM   #72
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
i hate to say this
but i have just tryed this myself, and the art dose disappear
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 11-08-2007, 09:00 PM   #73
EL CAMINO's Avatar
ok, seems that a newer version of cddbcontrol.dll, works better. i will include the new dll to the package. please unregister first the old cddbcontrol.dll to do this run unregister.bat and then copy the new dll, now you can run register.bat to register the new cddbcontrol.dll, remember that is a different dll. also the tag.exe must be replace.
Old 11-09-2007, 02:04 AM   #74
THE EXPERIMENTER
carputer1's Avatar
i'll give a whirl tonight
thanks for keeping on top of this 1,
while i have your attention i have just added delete track from your skin but it dose'nt seem to work, i followed what you had in your skin and from the tools download.
any pointers
thanks
Links
Old 11-09-2007, 11:26 AM   #75
EL CAMINO's Avatar
what is the problem?, the track keeps playing?, the track is removed from the playlist only? or there is no changes at all?, from what skin are you launching the delete process?
Playlist search bug kobaz RR Bug Tracker 4 07-29-2007 07:41 PM
Search Engine Problem? lkstaack Mp3car Forum Suggestions/Comments 6 05-29-2007 10:18 PM
hey noobs, How many times have you been hit with the :search: lominono Off Topic 52 07-03-2005 08:00 AM
FAQ: Why do people keep telling me to SEARCH? tj!2k4 The FAQ Emporium 1 06-28-2005 02:06 PM
Help - A plug in that uses an mp3s ID3 tag to search for a song??? zzsprade Software & Software Development 0 02-18-2002 12:33 AM
