Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 11-09-2007, 11:46 AM   #76
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
sorry forgot to say that
i get all the actions right up to the deletion popup, and it dose not delete anything.
launching from the tag editor skin i got from this thread(capri28's 1) all i did to the skin is change the graphics abit.
sorry to bug you and thanks
at work for the next half hour then be home and downloading your latest tags and trying that out as well.
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 11-09-2007, 01:19 PM   #77
THE EXPERIMENTER
carputer1's Avatar
new tag editor 2.1.0
works ,now dose not delete the album art.
great work thanks El
Links
Old 11-09-2007, 02:56 PM   #78
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
make sure you have a playlist in the skin before you launch the deletion process. i remember that was the problem capri had, if you dont want to see the playlist in the skin you use, just hide it.
EL CAMINO is offline   Reply With Quote
Old 11-09-2007, 03:13 PM   #79
THE EXPERIMENTER
carputer1's Avatar
ok i just added this line
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
S,132,410,495,8,161,380,453,34,H,01,"POINTER.gif", 18,"SONGPOS",
but no go, found this in your tag test skin
Links
Old 11-09-2007, 03:29 PM   #80
EL CAMINO's Avatar
thats a slider, not a playlist, use the skin editor, open the skin you have the delete button, and add a playlist, make it x=-100, y=-100, w=1, h=1, everything else you can select anything, or leave it blank.
Old 11-09-2007, 03:47 PM   #81
THE EXPERIMENTER
carputer1's Avatar
ok that worked
was'nt thinking with that last line Doh!
added this line to my tag skin all works thanks
S,-100,-100,1,1,,
Links
Old 11-09-2007, 07:16 PM   #82
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Indeed! Tag Editor is working perfectly
Thanks El C.
treetop777 is offline   Reply With Quote
Old 01-09-2008, 06:32 PM   #83
tundra2000's Avatar
tundra2000 is on a distinguished road
hi, im getting an autoit error
"Line -1:
Error: The requested action with this object has failed."
i get it right after i click enter on my OSK after typing in a new title for the currently playing song. what to do?
EDIT:also occurs when i try to edit any other info.
tundra2000 is offline   Reply With Quote
Old 01-09-2008, 11:24 PM   #84
EL CAMINO's Avatar
you must register the dll, theres a register.bat ready to be used.
Old 01-10-2008, 09:25 AM   #85
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
camino.. does this plugin require use of a tag_editor.skin? The reason i ask is i'd like to use it on my audio_player.skin instead. Because i'm using flash i'll just create a sprite for editing tags instead of actually having to change skins to do it.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 01-10-2008, 02:30 PM   #86
EL CAMINO's Avatar
no is not required, but let me tell you, i found a better way to do this, no need for stop playing the track at all, no cddbcontrol.dll need it, if you have activewinamp installed this is for you, the thing is, it has some tags missing,
-track number
-comments
-year.
only supports
-artist
-album
-genre
-title
i might post this as an alternate editor, for users like you, if you want this one let me know, i'm testing it, and i like it more than the one i use at this moment.
Old 01-10-2008, 03:03 PM   #87
tundra2000's Avatar
i did........
does it matter if my tags folder is inside my skin? i changed all the commands out on the exectbl.ini.
>>i do still get the same error even if it is in the RR directory... so it leads me to believe thats not the prob.
yes...............
Old 01-10-2008, 03:16 PM   #88
EL CAMINO's Avatar
it doesnt matter where you put the folder, just make sure to register the dll, and not move the folder after that, if you do unregister first and register again. your problem sounds like is not registerd right.
Old 01-10-2008, 04:52 PM   #89
tundra2000's Avatar
ive registered and unregistered a thousand times lol, im not moving it around. i know how to register things and it just doesnt seeem to be working lol. this has a place in my new skin, ive just gotta get it working!
Old 01-10-2008, 04:57 PM   #90
EL CAMINO's Avatar
LOL, ok, i will post the alternate editor soon.
Playlist search bug kobaz RR Bug Tracker 4 07-29-2007 07:41 PM
Search Engine Problem? lkstaack Mp3car Forum Suggestions/Comments 6 05-29-2007 10:18 PM
hey noobs, How many times have you been hit with the :search: lominono Off Topic 52 07-03-2005 08:00 AM
FAQ: Why do people keep telling me to SEARCH? tj!2k4 The FAQ Emporium 1 06-28-2005 02:06 PM
Help - A plug in that uses an mp3s ID3 tag to search for a song??? zzsprade Software & Software Development 0 02-18-2002 12:33 AM
