Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 04-01-2009, 11:18 PM   #121
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
i use mute only if a tag/art/lyrics is been updated, on the current track, first STOP, then write the tag, then mute, then play, then seekto, then mute, but only if the track is been played.
EL CAMINO is offline   Reply With Quote
Old 04-02-2009, 09:01 AM   #122
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i tried enabling the plugin again and it did the same thing. The mute is occuring before RR resumes winamps playback so there's no actual track playing but i can confirm that winamp is running when it happens. Perhaps i dont have the latest version? I'm still using the one with the folder name aw_genie.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 04-02-2009, 09:23 AM   #123
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Rather than stop a track that is playing, why not wait till the track has finished then change the data?
Enforcer is offline   Reply With Quote
Old 04-02-2009, 02:38 PM   #124
EL CAMINO's Avatar
i had that idea as well when trying to find the best way to hadle this,but the only thing is that the update wont be instant, that's why i went this route.
Old 04-02-2009, 02:39 PM   #125
EL CAMINO's Avatar
i can pm you part of the code, maybe you can see what's wrong.
Old 04-02-2009, 02:48 PM   #126
Confusion Master
Enforcer's Avatar
Maybe you could update the labels only, do it looks like they have changed, then as soon as song changes, change the file.
Old 04-02-2009, 03:12 PM   #127
Terminal flasher
thinking like that makes me wanna order you to fix/create every RR Plugin. You best cut it out.
E.C.. go ahead and pm me it. I'll see if i can figure it out.. but i notice its not doin it on my work pc.. just in the car
03 Acura RSX Coupe
Old 04-02-2009, 04:25 PM   #128
Confusion Master
Enforcer's Avatar
Shaddup, I have enough trouble fixing my own, that the physical part of the install gets neglected.
Old 04-22-2009, 03:12 PM   #129
Terminal flasher
latest RR seems to have broken the tag editing feature. It shows the plugin is loaded but then i get this:
Code:
Que Exec: True, tag_editor.skin, "AwRR_Set_Album", False 4/22/2009 3:09:43 PM: Executing: AwRR_Set_Album 4/22/2009 3:09:43 PM: Command not executed: AwRR_Set_Album 4/22/2009 3:09:43 PM: Que Exec: True, tag_editor.skin, "ONCOMMANDINVALID", False
any ideas?
03 Acura RSX Coupe
Old 04-23-2009, 07:57 PM   #130
EL CAMINO's Avatar
not sure, but with the last version i have it does work ok, i added the "ON.." events(thanks RR team) in the plugins, i'll make it available tomorrow. works really good.
Old 05-03-2009, 03:31 AM   #131
EL CAMINO's Avatar
an updated version is released, Lyrics and AlbumArt download is now inside the plugin, script has been removed, an option to use external source is still available.
"ON..." Events are now inside the plugin, (Thanks RR Coding Team). more info in skin commands.txt,
Old 05-03-2009, 07:19 AM   #132
almera's Avatar
almera is on a distinguished road
in tag_editor.skin, when I click to artist ("EXEC;AwRR_Set_Artist||AWRR_ARTIST"), plugin downloads and set the album art automatically then shows OSK.skin for a second then updates lyrics. Is there a problem with this command? Other than Artist, tag edit future works fine. Thanks for the new version..
almera is offline   Reply With Quote
Old 05-03-2009, 02:28 PM   #133
EL CAMINO's Avatar
you are right, i broke the code when adding auto Embed art, so i had th change the command from "AwRR_Set_Art" to AwRR_Embed_Art" thats the only change i had to do. all good now, thankyou for letting me know.
Old 05-03-2009, 02:50 PM   #134
almera's Avatar
Thanks again for this nice plugin, I just tested, works fine now.
Old 05-09-2009, 07:36 AM   #135
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
yippee finally got it working, damn comp systems , so far so good, only problem found so far is labels don't update on clclick, but its early testing so get ready for me to break this again lol.....
carputer1 is offline   Reply With Quote
Playlist search bug kobaz RR Bug Tracker 4 07-29-2007 07:41 PM
Search Engine Problem? lkstaack Mp3car Forum Suggestions/Comments 6 05-29-2007 10:18 PM
hey noobs, How many times have you been hit with the :search: lominono Off Topic 52 07-03-2005 08:00 AM
FAQ: Why do people keep telling me to SEARCH? tj!2k4 The FAQ Emporium 1 06-28-2005 02:06 PM
Help - A plug in that uses an mp3s ID3 tag to search for a song??? zzsprade Software & Software Development 0 02-18-2002 12:33 AM
