The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Thread Tools Display Modes
Old 07-23-2007, 08:32 PM   #16
Road Runner Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
OSK to search the Database
Quote: Originally Posted by tejesh83 View Post
Excellent idea! Can you post the relevant commands or a patch file?
If I get some more time, I'd like to take that even further and do something like DJIK's Jump 2 File Plugin. I really miss the "j" function of winamp and would love to have an easy way to query the entire medialibrary to find and play or enqueue any mp3 using an OSK.
There has been no alteration to the script needed whatsoever, just how the information gets passed to the script is all.
As far as the JTT, this replaces it completely. The only thing it does not do, is show the songs as you type the name. On the MAJOR plus side, this method is completely skinnable, and works 100% seamlessly with Road Runner.
All that is needed is for these 2 lines to bring up the OSK to search for text in the title of a song, to be added to the ExecTbl.ini file.
Code:
"SearchForSong"," ||OSKTOCMD;MySearch;SearchSongTitle" "SearchSongTitle","RUNQW;wscript.exe" "$rrpath$\SmartPlayLists\queryWinamp.vbs" "$winamppath$" "title HAS "$MySearch$"" "||RELOADLIST||Load;Audio_Playlist.skin"
Then all you need for the Button code is the following:
Code:
"SearchForSong"
When its all set up, it works like this:
- Press the search Button
- The OSK pop's up and you type in a search word, "Rock" in this example
- In only a second or 2 it kicks you to the playlist screen with all the search results (MUCH better than the minute or so for Road Runner to search the hard drive!)
Here is the result of the "Rock" search:
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0, 7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 3.0 Skin
http://www.johnwpb.com
JohnWPB is offline   Reply With Quote
Sponsored Links
Old 07-28-2007, 03:49 AM   #17
Iceman_jkh's CarPC Specs
My Photos: (1)
Awesome work on the plugin!!
Anyone using Freedom 2.1 willing to make a suitable skin for this?
Iceman_jkh is offline   Reply With Quote
Old 07-28-2007, 09:28 AM   #18
My Photos: (1)
I noticed that in Winamp, if you type in your search criteria and then Right-click on one of the results, you can either load that particular song OR you can load the entire album (if its part of an album) which that track belongs to.
Are these two options possible with this plugin?
Old 07-29-2007, 11:49 PM   #19
JohnWPB's Avatar
My Photos: (0)
The way this plugin works, is when you do a search for "Rock" for instance, every song containing the word "Rock" is added to an on the fly playlist. So when you look at the results, you can either double tap to play a song in the list, or it will just play the songs in the newly created playlist in order.
Being this is the way it works, you could type "Pink Floyd" and every single Pink Floyd song, no matter what sub folder they are in, will be made into a playlist.
Basically you just need to mind what you are searching for, to get better results.
Old 07-30-2007, 02:36 AM   #20
My Photos: (1)
Thanks John. I have a lot of songs that are part of compilation albums (eg: Ministry of Sound - Sessions). I search for a particular song, which I find, but I decide that rather than just play that 1 track, Id like to load the entire album - and listen to it as it should be heard. Thing is, I dont know which album its on, so I cant search the album alone. (Also, I cant search via album with this plugin anyway, I dont think. Further more, I heaps of 'Ministry of Sound' albums, so it will be hard to search that way too.). Any suggestions on how I can overcome/fix this?
I really like the way winamp does it at the moment (in Winamp V5), if you've tried it?
Sponsored Links
Old 07-30-2007, 09:40 AM   #21
Vehicle: 05 Acura TL 6sp Navi
My Photos: (0)
The album load is not a feature of the active_winamp API as far as I can tell. What winamp is most likely doing is a second query where album=(the selected song's album).
You can do this with the plugin as is, but will require some creative custom RR skinning. First you'll need a new button on a screen containing the playlist, that will load the entire album from the currently selected file. Basically what that button does is grab the selected song's album data from its id3 tags and run the new query mentioned above using the plugin. I'm new to RR skinning, so I'm not sure how to do this offhand. You'll have to dig through "Skin Commands.txt" in the RR folder to figure out the playlist selection and grabbing id3 data.
-TJ
Smart Playlists Plugin for RoadRunner
CarPC - 05 Acura TL Navi (pics soon)
Retired CarPC - 03 Infiniti Qx4
tejesh83 is offline   Reply With Quote
Old 08-07-2007, 02:53 PM   #22
cdevelasco's Avatar
Vehicle: 2006 Mitsubishi Montero Dakar V6 4x4 (SWB)
My Photos: (0)
Help Please
Hello, this plugin is EXACTLY what i have been looking for, and I was quite glad to see it posted. Unfortunately I can not get the plugin to work. I have followed the instructions for installing the plugin (or atleast I think Iīve done it all correctly);
Requirements:
Winamp 5 (I have Version 5.0 (x86)- Dec 14 2003)
ActiveWinamp plugin (Downloaded from link providede at begining of this thread)
Road Runner (Have the latest version)
Road Runner skin with SmartPlayLists support (Added the skin edits of BMV2 provided in the zip at the beggining of this thread)
Installation:
Copy SmartPlayLists folder to Road Runner root directory (Did this, copied to C:\Archivos de Programa\Road Runner\ the .vbs file is inside the folder C:\Archivos de Programa\Road Runner\SmartPlayLists Yes my windows in my test machine is a spanish version)
Ensure Winamp 5 is installed (Check, ver 5.0 (x86) Dec 14 2003)
Ensure activewinamp plugin is installed (Check)
Ensure Road Runner winamp path is set to your Winamp5 install (Check, this was done when I originally installed road runner, if not I would not be able to hear my music right?)
Set Road Runner to use a skin featuring SmartPlayLists (see BMVW skin patch folder) (check, I copied the supplied files, both the .jpg and the .skin into the BMV2 folder to test out the plugin)
Now when I run Road Runner, I go into the audio player skin and press any of the 4 color coded buttons, nothing happens, the music continues to play without a problem, but I do not see the play list update, and the buttons on road runner lose functionality, When I try to press any of the buttons I hear the windows error "ding". I open the the task manager and it seems road runner hasnīt crashed becuase the "not responding" message is NOT there, and the CPU usage is less than 10%. but I cant use road runner, the buttons stop responding after I press one of the smart play list buttons, I have to terminate the roadrunner.exe process from the task manager and restart road runner in order to regain control. Anyone have any idea of how I can fix this. I thank you all in advance for your help.
My Projects:
Old project
2000 A4
http://www.mp3car.com/vbulletin/show...ight=2000+audi
New Project
2006 Montero
http://www.mp3car.com/vbulletin/show...6-4x4-swb.html
cdevelasco is offline   Reply With Quote
Old 08-09-2007, 10:53 AM   #23
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (101)
this is a TERRIFIC plugin.. just implemented it into my skin. Great work!
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 08-10-2007, 11:50 PM   #24
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (12)
Been using winamp v5.2x I think, and have had apsolutly NO problems with it..
And with the other issue, depending on how you have you music organized, a simple autoit or vb script could do that...
Blue ZX3 is offline   Reply With Quote
Old 08-11-2007, 12:00 AM   #25
My Photos: (1)
My music is organised into a single folder per album. Within that folder there are CD1 and CD2 directories (or CD3...etc). The track ALBUM also contains 'Ministry of Sound - Sessions 1 (Disc 1)' for example. So the disc data is stored in the Album name as well. This prevents winamp from adding the tracks to the playlist like this: track1/disc1,track1disc 2,track2disc1,track2disc 2, etc. Having the disc number stored in the ALBUM seemed to overcome this. Is there another way to do it (a better way) blue? I looked into 'sort by filename and directory, but it didnt seem to do anything in RR. I also label my MP3 files [track number Artist - Title.mp3], so it usually fixes most ordering issues. Except when you have multiple CDs from the same album (see "track1/disc1..."above).
I understand that you could do (althougn not sure exactly how) this with an AutoIT script.. then only reason I would prefer to have it added to the plugin (as a feature in itself), is that it would then become a standard feature for the plugin - and skin developers would code their skin to incorporate it.. rather than everyone coding their own AutoIT's slightly differently. get what I'm saying?
Old 08-11-2007, 04:37 AM   #26
Raw Wave
Blue ZX3's Avatar
My Photos: (12)
Couldn't resist...as this could really be used an any skin, any button, with/without this plugin
Simple run this from a button code, and it will play from the current album, starting with currently playing song.
Delete the ".txt" ext
NOTE: music has to be like artist\album, or it will just play the files that are contained in whatever folder that the currently playing song is from...
Old 09-07-2007, 06:29 AM   #27
JohnWPB's Avatar
My Photos: (0)
Thanks for a fantastic plugin/script!!!!!!!!
tejesh83L I just wanted to say THANK YOU for a fantastic little script! Altering it a bit, and creating a variety of searches, it is fantastic addition to Road Runner! Searching for something now only takes a second or two, compared to up to a minute with the standard Hard Drive search!
I created a skin simply for this search feature, and it works great! Thanks again!
In this screen cap, I tapped "Filename Search" and used the keywords "meat para" It's great being able to use partial words and such!
Old 09-21-2007, 04:07 PM   #28
JohnWPB's Avatar
My Photos: (0)
I just wrote another tiny script, that when you do a search for a song, and would like to the the entire album it lets you. This works by getting the ID3 tag for album name, from the currently selected song in the list.
All of the scripts and code are in my DigitalFX skin (link in my sig) if someone wants to pick it apart and add it to their own skin.
Old 09-21-2007, 06:55 PM   #29
My Photos: (1)
I would if I knew how to John!
But thanks for letting us know ... atleast I might be able to try pick the code apart :P
Old 09-25-2007, 05:46 AM   #30
My Photos: (0)
Hiya,
Just wanted to chime in a massive thanks for this plugin - Guino pointed me in the direction of it and I'm using it to solve my new podcasts problem perfectly.
I am using an external RSS/Podcast grabber, HappyFish to manage the download of new podcasts (couldn't get Shoutcast Wire easily to work so gave up on it) which downloads to a known location and alters the genre to "podcast", Winamp media library is then set to scan this location regularly to pick up and catalog new files.
I then mapped one of my buttons (mixer which I don't use) to call this plugin for genre = podcast, playcount = 0 which fires all my shiny new podcasts into my playlist and I am a happy man
doogieb is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
IRMAN plugin knyarko StreetDeck 3 01-05-2007 08:26 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 03:43 PM
Boolean Operators in Smart Playlists shakes FrodoPlayer 1 05-09-2005 01:08 PM
Smart Playlists frodobaggins FP FAQ 0 12-01-2004 04:55 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 05:39 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
