The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Thread Tools Display Modes
Old 10-15-2007, 10:25 AM   #1
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Upd8 1.0.8
Download
Original Version Here
Firstly it has had a name change, it shall from hereonin be called Upd8.
What it does
  • Checks for connection to remote location
  • Automatically updates new folder and files (playlists and songs)
  • Removes old folders/files (optional)
  • Unlimited subdirectories
  • User selectable file types or all types
  • Visual indication of connection/no connection
  • User Configure Utility
  • Can be used with Memory Sticks (automatic detection of)
  • Log of all transfers/deletions
  • Indication of free diskspace
  • Multiple Source Locations
  • Multiple Destination Locations
  • Skinnable
  • Tells RoadRunner to load Upd8 screen when new sync takes place (can be turned off)
Future additions
  • ftp access
  • Resume copy after a disconnection
  • Entering in of location paths within program rather than editing ini file.
*Requests please
Upd8 1.0.8 Changes
Bug fixes
limited to 2000 folders and 2000 files : fixed now 20,000 folders and 200,000 files
missing sync causes error : fixed whole path ignored now if sync and extension missing.
paths needed end \, this cause error : fixed adds \ if missing.
& doesn't show up and causes next letter to be underlined : This was a label display issue only now fixed.
Stops sync'ing all locations if current sync loses connection during mid sync. : fixed
Manual would not run if a succesful copy was done recently : fixed
Meters don't change when copying root folders : fixed.
Not all files copied for some reason : fixed, removed an extra check for whether the file exists, we already know it exists
Only first extension sync'd : fixed, change of method caused conflict.
Upd8 1.0.6 Instructions
Extract from the zip to your Road Runner (or any Front End) folder. This will create
a folder called Upd8. Run register.bat. Within the Upd8 folder there
is a folder called skins, I have enclosed a Default skin, BMV2. I have also enclosed
the corresponding upd8.skin file for this skin as well, this should have been copied
into the appropriate skin folder within RR.
Read the Readme.txt in the Upd8 folder for full instructions
This is a beta so I want those bug reports.
Also anything else you would like added to it list here.
Enforcer is offline   Reply With Quote
Sponsored Links
Old 10-15-2007, 10:27 AM   #2
Confusion Master
Enforcer's Avatar
My Photos: (1)
Config screen
Old 10-15-2007, 04:58 PM   #3
ThunderStick's CarPC Specs
ThunderStick's Avatar
Vehicle: 1986 Jaguar XJS
My Photos: (2)
Will this compare existing files with the source files. This would be usefull.
86 Jaguar XJS - Completed
New Age - RR Skin
Concept - RR SKIN
"Your two cents are worthless pennies if you consider the exchange rate for my 2 cents"
ThunderStick is offline   Reply With Quote
Old 10-15-2007, 05:22 PM   #4
Confusion Master
Enforcer's Avatar
My Photos: (1)
At the moment it compares the modified date, so if changes were made it will copy the latest version or leave the newer version there.
But no it doesn't compare the files byte for byte. The way the program is written I can add that but it's likely to really slow it down (But I will see if there is an easy way to do that for the future maybe)
Old 11-06-2007, 11:50 AM   #5
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (129)
Dear Administrator....
Send me my activation email
Sincerely,
Me
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 11-06-2007, 11:54 AM   #6
Confusion Master
Enforcer's Avatar
My Photos: (1)
ooops Account deleted activated.
Old 11-06-2007, 01:41 PM   #7
The Vauxhall Vectra Project
ccsnet's CarPC Specs
ccsnet's Avatar
Vehicle: Vauxhall Vectra C SRI XPack Auto - v5 ( Via 12000 based ) Sygic & With FreeICE
My Photos: (0)
Signing up for this.... I think one of those was a mod I was after ages ago. I'll have to play but would it be possible for the app to say what the estimates size might be of the files selected ?
So if yiou have a 20GB drive and 40GB of music and select music you'll know when your going to run of space did you run it ....
Also can it be run standalone ? eg If its on a portable drive that is used in the car but when brought inside and connected to a desktop PC can just be run from that drive ?
Also - when selecting files / folder it might be good having the option to 'tick' trees like a lot of AV software does when you selecting which folder / subfolder you want to copy.
Lastly ( for the future ) a way of creating play lists / & correcting MP3 data on the fly while copying ( ie my HOWTO over on DC ).
Terran
ccsnet is offline   Reply With Quote
Old 11-06-2007, 03:04 PM   #8
Confusion Master
Enforcer's Avatar
My Photos: (1)
(1)
(2)Also can it be run standalone ? eg If its on a portable drive that is used in the car but when brought inside and connected to a desktop PC can just be run from that drive ?
(3)Also - when selecting files / folder it might be good having the option to 'tick' trees like a lot of AV software does when you selecting which folder / subfolder you want to copy.
(4)Lastly ( for the future ) a way of creating play lists / & correcting MP3 data on the fly while copying ( ie my HOWTO over on DC ).
Terran
(1)Not the way it works a present. Essentially it looks at all the files at the source and then goes through the destination and checks if it exists, if it doesn't or is older it copies the new one over. To have it tell you whether there was enough space before hand it would have to make a list of the differences and then start copy, which don't really want to do as the list might change while it's copying.
(2)Doesn't need RoadRunner to run so can be run standalone, also you can run as many seperate copies as you want.
(3)The idea is for you to a have a location in the same format as that on your CarPC, I don't think I'll be adding a selectable folder option as it will complicate it too much. (Unless there is a lot of requests for it)
(4)Link? and explain what you mean by playlists M3u ones,Centrafuse ones?
Old 11-06-2007, 04:05 PM   #9
ccsnet's Avatar
My Photos: (0)
1) The way I am thinking about using this it would not be an issue. I'll grab the mp3s off my home server on to my portable drive ( see my VRX log ) using my desktop computer inside.
3) I ask because v5 will have a portable drive to bring in the house to sync with rather than fully installed.
4) http://www.digital-car.co.uk/forum/s...ead.php?t=6393
Terran
Old 11-06-2007, 04:14 PM   #10
Confusion Master
Enforcer's Avatar
My Photos: (1)
Download it and try it out.
The program can copy either way.
IE PC to USBDrive or USBDrive to PC, it's up to you how you set it up
Sponsored Links
Old 11-07-2007, 04:23 AM   #11
ccsnet's Avatar
My Photos: (0)
Good advice
Terran
Old 12-27-2007, 04:59 AM   #12
Vehicle: BMW
My Photos: (0)
i havent received my activation email either
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 12-27-2007, 08:36 AM   #13
Confusion Master
Enforcer's Avatar
My Photos: (1)
What username did you use?
Old 12-28-2007, 09:17 AM   #14
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
Does this use standard RR skins, or is it like the traffic cams, and I have to use notepad to edit it? Is it a "full screen" app, or can I move the buttons and windows to any location?
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0, 7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 3.0 Skin
http://www.johnwpb.com
JohnWPB is offline   Reply With Quote
Old 12-28-2007, 02:21 PM   #15
Confusion Master
Enforcer's Avatar
My Photos: (1)
It's the same as Traffic cams, Roadrunner-esque skins.
The buttons and windows can be anywhere on the skin, as with Trafficams.
You will have to use notepad to edit them though.
Sponsored Links
vB code is On
Trackbacks are Off
Released: BETA 10 skippy76 Road Runner 169 03-07-2006 10:53 AM
StreetDeck Developer Edition Beta Fiberoptic StreetDeck 19 01-23-2006 02:18 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
