Download
Original Version Here
Firstly it has had a name change, it shall from hereonin be called Upd8.
What it does
- Checks for connection to remote location
- Automatically updates new folder and files (playlists and songs)
- Removes old folders/files (optional)
- Unlimited subdirectories
- User selectable file types or all types
- Visual indication of connection/no connection
- User Configure Utility
- Can be used with Memory Sticks (automatic detection of)
- Log of all transfers/deletions
- Indication of free diskspace
- Multiple Source Locations
- Multiple Destination Locations
- Skinnable
- Tells RoadRunner to load Upd8 screen when new sync takes place (can be turned off)
Future additions
- ftp access
- Resume copy after a disconnection
- Entering in of location paths within program rather than editing ini file.
*Requests please
1.0.83 Bug fixes
Corrected fault with it not copying folder with peroids in.
Corrected fault with it not copying system files (.jpgs created by media player)
It now saves sync method when changed in program.
1.0.8 Changes
Bug fixes
limited to 2000 folders and 2000 files : fixed now 20,000 folders and 200,000 files
missing sync causes error : fixed whole path ignored now if sync and extension missing.
paths needed end \, this cause error : fixed adds \ if missing.
& doesn't show up and causes next letter to be underlined : This was a label display issue only now fixed.
Stops sync'ing all locations if current sync loses connection during mid sync. : fixed
Manual would not run if a succesful copy was done recently : fixed
Meters don't change when copying root folders : fixed.
Not all files copied for some reason : fixed, removed an extra check for whether the file exists, we already know it exists
Only first extension sync'd : fixed, change of method caused conflict.
1.0.6 Instructions
Extract from the zip to your Road Runner (or any Front End) folder. This will create
a folder called Upd8. Run register.bat. Within the Upd8 folder there
is a folder called skins, I have enclosed a Default skin, BMV2. I have also enclosed
the corresponding upd8.skin file for this skin as well, this should have been copied
into the appropriate skin folder within RR.
Read the Readme.txt in the Upd8 folder for full instructions
This is a beta so I want those bug reports.
Also anything else you would like added to it list here.
