Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 10-18-2007, 10:41 AM   #1
Robby BMW's Avatar
Robby BMW is on a distinguished road
Arrow RRTMS - RoadRunner tire monitoring system extension plugin
This plugin is designed to work in conjunction with my custom TPMS USB Receiver.
A detailed description of the whole project can be found here.
How it works:
Pressure and temperature information are sent to the receiver and displayed on the car pc screen. When an under-inflated, over-inflated or over-heated tire is detected, RoadRunner will switch to the plugin skin and, if available, an audible voice message is spoken to warn the driver. The alerts depend on threshold value set for pressure and temperature by the config utility.
This plugin has been developed as “Extension Plugin” using the guideline provided by Guino (thank you Guino), so it can be integrated in RoadRunner easily.
Video of the plugin in action:
RoadRunner TPMS plugin in action!
You need to upgrade your Flash Player
How to install:
Copy the files provided in the RoadRunner folder and the skin files in your favorite skin folder (you can also use the skin provided (that is part of my BMW-E36 skin) as a guideline to develop your own skin.
Register the DLL, from a command prompt type: regsvr32 RRTMS.dll
Add in your "MENU.SKIN" the command "X,RRTMS" and create a button with the comand "TMS" in order to switch to the plugin screen.
Launch the utility “RRTMS Config” and set all the stuff.
Added skin commands:
COMANDS/BUTONS:
“TMS” – Go to the main screen of the plugin
“TMS_SILENT” – Silent mode. If active, the plugin will not show any warning
INDICATORS:
“TMS_SILENT” – Indicates that the silent mode is active.
"TMS_ALERT_FL" - Indicates that in the front left tire there is an irregularities.
"TMS_ALERT_FR" - Indicates that in the front right tire there is an irregularities.
"TMS_ALERT_RL" - Indicates that in the rear left tire there is an irregularities.
"TMS_ALERT_RR" - Indicates that in the rear right tire there is an irregularities.
"TMS_ALERT_ST" - Indicates that in the spare tire there is an irregularities.
“TMS_PRESSURE_ALERT” – Indicates that the pressure of a tire is under or over the threshold values
“TMS_TEMPERATURE_ALERT” - Indicates that the temperature of a tire is over the threshold value
“TMS _ALERT” – This will attempt to show TMS_PRESSURE|TMS_TEMPERATURE.gif from the current skin folder into the defined area when an alert is underway.
LABELS:
"TMS_PRESSURE_FL" – Shows the pressure of the front left tire.
"TMS_PRESSURE_FR" – Shows the pressure of the front right tire.
"TMS_PRESSURE_RL" – Shows the pressure of the rear left tire.
"TMS_PRESSURE_RR" – Shows the pressure of the rear right tire.
"TMS_PRESSURE_ST" – Shows the pressure of the spare tire.
"TMS_TEMPERATURE_FL" – Shows the temperature of the front left tire.
"TMS_ TEMPERATURE_FR" – Shows the temperature of the front right tire.
"TMS_ TEMPERATURE_RL" – Shows the temperature of the rear left tire.
"TMS_ TEMPERATURE_RR" – Shows the temperature of the rear right tire.
"TMS_ TEMPERATURE_ST" – Shows the temperature of the spare tire.
SLIDERS:
"TMS_BATTERY_FL" – Shows the battery charge status of the front left sensor.
"TMS_BATTERY_FR" – Shows the battery charge status of the front right sensor.
"TMS_BATTERY_RL" – Shows the battery charge status of the rear left sensor.
"TMS_BATTERY_RR" – Shows the battery charge status of the rear right sensor.
"TMS_BATTERY_ST" – Shows the battery charge status of the spare tire sensor.
Look at the skin provided for more details on how to use these commands.
Screen shots:
- the plugin in action -
- the config utility -
- another screen shot of the config utility -
Change log:
1.00:
-First release.
1.10:
- Improved the comunication between the USB port and the HID device.
- Fixed a bug with the battery level sliders.
1.20:
- Fixed the issue with sliders when multiple plugins are loaded. (More informatinos on this thread)
1.30:
- Fixed a bug with the USB buffer.
- Changed the default sensors locations in accordance with the suggested installation sequence of the original 3rdEye TPMS kit.
- Added some improvements to the config utility.
1.40:
- Fixed the indicators in agreement with this thread.
Downloads:
RRTMS 1.40 Binary
RRTMS 1.40 Source
Downloads (Robby's Server):
RRTMS 1.40 Binary
RRTMS 1.40 Source
Users request:
BMW-E36 TMS SKIN PSD Source
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Advertisement Sponsored links
Old 10-18-2007, 10:45 AM   #2
juve021 is on a distinguished road
NICE WORK!!! I can't wait for the hardware part to come out!!!
juve021 is offline   Reply With Quote
Old 10-18-2007, 10:45 AM   #3
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
no kidding this is SWEET.. i gotta find out how to get the hardware.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 10-18-2007, 11:28 AM   #4
l1nk's Avatar
l1nk is an unknown quantity at this point
Wonderful work Robby!!
**** Solo 3 parole: 6 1 mito!! :-) ****
l1nk is offline   Reply With Quote
Old 10-18-2007, 12:00 PM   #5
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enough
This is way too cool! I wish my car would tell me that instead of just saying there's a problem with "some" tire (doesn't say which) that has the "wrong" pressure (doesn't say over or under)...
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 10-18-2007, 12:47 PM   #6
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
I am so ready to ditch my SmarTire system just to incorporate this feature into my carPC.
Bring on the hardware!
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v4/18/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 10-18-2007, 12:49 PM   #7
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
Siiiiiiick i saw the other thread this is sweeeet
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 10-18-2007, 01:03 PM   #8
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
I wonder if this will work in a submarine.
edit cool video demo.
Enforcer is offline   Reply With Quote
Old 10-18-2007, 01:57 PM   #9
Robby BMW's Avatar
What about a spaceship?
Old 10-18-2007, 04:02 PM   #10
Griff1's Avatar
Griff1 is on a distinguished road
Is this just for Bm's or is it just me....what's the hardware requirement for this?
EDIT = Never mind,doh.
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,ROADRUNNER, iGo8, Custom Freedom 2.1
Griff1 is offline   Reply With Quote
Old 10-18-2007, 04:15 PM   #11
john1701's Avatar
john1701 is on a distinguished road
EXCELLENT!!!!!! You build it, they will come!!! I SOO want this!
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Vista with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:Garmin
Screen:Xenarc 700TSV
The Florida Meets Thread
john1701 is offline   Reply With Quote
Old 10-18-2007, 05:07 PM   #12
SoulR's Avatar
SoulR is an unknown quantity at this point
that is truly awesome, well done
SoulR is offline   Reply With Quote
Old 10-19-2007, 03:35 AM   #13
richyrich's Avatar
richyrich is an unknown quantity at this point
Well i dont know about anyone else but i think this is one of the best Plugins I have seen for RR since i have been using it!
Shame i havent had the know-how to do this before but hey!
Im working on the hardware side of things, il post any updates on the other detailed thread!
richyrich is offline   Reply With Quote
Old 10-19-2007, 04:02 AM   #14
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Wow, fantastic work on the hardware, skin, and configuration utility! Just wish there was a current place to buy the "whole package".
Over here in the U.S. we use PSI (Pounds per square inch) and not Bar's. In preparation to the hardware becoming avail, is there a way you could add a math conversion into the extension plugin to measure in PSI? Possibly just a check mark / drop down list in your config utility? I have never personally seen a tire pressure gauge, compressor or such using Milibar's here.
Secondly, another very useful addition, would be the ability to have a "Add Air" mode button on the skin. Pressing this & then adding air to the tires would sound an audible tone, speech or something to let you know you are at the correct pressure. It would save on adding air, checking with a gauge, adding more air, checking with a gauge... Adding air, OOPS too much...hisssssss.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 10-19-2007, 04:13 AM   #15
richyrich's Avatar
Robby has already done that John! you can change it in the settings (second picture down!!)
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Plugins 200 04-06-2009 06:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 06:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 06:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 05:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 10:27 AM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
