Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 12-12-2001, 01:46 AM   #1
I guess this has died too.... When oh when will we get a phone plugin that actually works? I'd pay $100 for the program at this rate! its just too long overdue... the technology is there, it just needs a genious to hack it apart and make it work.
pepsimachine is offline   Reply With Quote
Old 01-21-2008, 09:00 AM   #2
VorTechs's Avatar
RRMobile 0.3 Development
Although I don't actively have a phone working yet (left mine at home today!), I've started making some fairly heavy changes to RRMobile with a view to providing an update in the near future.
The full list of changes that I have made so far:
  • Modified plugin structures to be class based (for transportability of data across the application)
  • Plugin configuration INI file reader re-written
  • Plugin configuration modified to read from a single file
  • Plugin starts with no default profiles configured
  • Plugin now writes a default configuration if none exists
  • Plugin no longer closes when phone not available
  • Plugin loads demo data of 100 contacts with random default numbers, when Com Port = 0
  • Clicking on 'Phone Status' icon when phone not available re-establishes communications
The new configuration file looks a little something like this:
Code:
[Configuration] RRMSkinPath=C:\RoadRunner\Plugins\RRMobile\Skin\ RRMLogLevel=0 AvailableProfiles=1 ActiveProfile=1 [Profile 1] Com Port=0 Baud rate=57600 Timeout=5 Use DTR=0 Use RTS=0 Wait Time=3 Supported Commands= Unsupported Commands= Initialise Command= Vendor Command= Model Command= Call Answer Command=ATA Call Hangup Command=ATH Call Dial Command= Last Phone Book=0 [Profile 1 \ Phone Book 0] Phone Book Name=Phone Book 0 Enabled=0 Initialise Command= Open Command= Read Command= Terminate Command= [Profile 1 \ Phone Book 1] Phone Book Name=Phone Book 1 Enabled=0 Initialise Command= Open Command= Read Command= Terminate Command= [Profile 1 \ Phone Book 2] Phone Book Name=Phone Book 2 Enabled=0 Initialise Command= Open Command= Read Command= Terminate Command= [Profile 1 \ Phone Book 3] Phone Book Name=Phone Book 3 Enabled=0 Initialise Command= Open Command= Read Command= Terminate Command= [Profile 1 \ Phone Book 4] Phone Book Name=Phone Book 4 Enabled=0 Initialise Command= Open Command= Read Command= Terminate Command= [Profile 1 \ Phone Book 5] Phone Book Name=Phone Book 5 Enabled=0 Initialise Command= Open Command= Read Command= Terminate Command=
I'll probably tidy up the names of the sections related to the phone books so they read a little more sensibly (ie Profile 1 \ Outlook Phone Book etc) and I'm going to see if I can get my hands on some old working mobiles for testing with.
If you have RRMobile working currently, I'd appreciate a copy of your existing configuration files for a couple of reasons:
1) To write a conversion routine to port over existing configurations
2) To build a list of commands on a phone by phone basis to provide some basic templates to get people up and running quicker
Anything you can provide, please e-mail me here!
TIA.
KimmyBean> Stu, you know that cybersex we had?
KimmyBean> I'm pregnant!
VorTechs is offline   Reply With Quote
Old 01-21-2008, 09:03 AM   #3
VorTechs's Avatar
Demo screenshot of some demo data enclosed:
Old 01-21-2008, 10:33 AM   #4
Confusion Master
Enforcer's Avatar
Pulls out chair and sits down.
Looks around but is disappointed as there is no sign of the blonde waitress from the other thread.
Enforcer is offline   Reply With Quote
Old 01-21-2008, 01:17 PM   #5
VorTechs's Avatar
One step at a time, I want to get a grip on what RRMobile is doing to then use it in a completely clean app.
Old 01-22-2008, 08:31 AM   #6
VorTechs's Avatar
Just fixed a bug causing the plugin to hang when communicating with some phones.....
Old 01-22-2008, 12:54 PM   #7
Really looking forward to your release.
If you need any testing done I'm happy to help out (I have a Sony Ericsson W610 & HTC Wizard - WM6)
Will this be able to route audio through the PC (and pass the pc's mic as an input) as I've currently found nothing able to do this
Cheers!
swift_gti is offline   Reply With Quote
Old 01-22-2008, 01:18 PM   #8
VorTechs's Avatar
This plugin isn't likely to be able to connect to the Audio Gateway (the bit that passes the audio over BlueTooth), certainly initially.
I intend to write a new plugin where hopefully this will be achievable, although I'm still researching the subject. If I can prove the concepts further than I've gotten so far, then I'll expose the back-end of the new plugin to a new version of RRMobile.
Old 01-22-2008, 02:33 PM   #9
carputer1's Avatar
rrMobile relives
Cheers!
carputer1 is offline   Reply With Quote
Old 01-23-2008, 05:55 AM   #10
Excellent, thanks for your reply - I look forward to seeing how this develops!
Old 01-23-2008, 12:23 PM   #11
EL CAMINO's Avatar
i'm in to!!
EL CAMINO is offline   Reply With Quote
Old 01-24-2008, 11:32 PM   #12
MySQL Error
MatrixPC's Avatar
Just to add a little encouragement. I'm watching this thread too.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 01-25-2008, 12:31 AM   #13
tundra2000's Avatar
me dos. phonecontrol is not working on any of my computers.... im anxious for a new [supported] solution
tundra2000 is offline   Reply With Quote
Old 01-25-2008, 02:44 PM   #14
Arrow's Avatar
Subscribed!
Arrow is offline   Reply With Quote
Old 01-25-2008, 05:44 PM   #15
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
Wow! Great news for sure! CDR took the code and went flash with it Meaning it can not be skinned. I have been hoping someone would take the code and leave it as it was originally written to work directly with RR's skins. Great work!
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is offline   Reply With Quote
CompactFlash Association Announces CF SATA Development rijndael General Hardware Discussion 0 07-21-2007 03:18 AM
SD Development Environment 06TC_OWNER StreetDeck 3 07-13-2007 03:47 PM
RRMobile makes RR disappear rscherp RR Plugins 7 11-06-2006 10:28 AM
FS: Siteplayer Development Kit jpx7777 Classified Archive 1 03-24-2006 01:27 PM
