Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 01-29-2008, 03:56 PM   #1
Sal R.'s Avatar
An Album Browser...kinda like Coverflow, but not as cool. It works though...
First and foremost, couldn't have done this w/o the help of Sonicxtacy02's builder.exe and EL CAMINO who really helped make this more process friendly for my M10K and faster overall. I modified it for this purpose, but all the kudos for that part go to them.
Since my carPC can't handle coverflow (it can barely handle iLists), I took it upon myself to put together a skin-based album browser that functions kinda like coverflow (i.e. browse music by album name).
My directory structure is as follows:
Artist
- Album
- - Tracks
Will work for: .mp3, .wma, .ogg, & .flac
How it works:
- It will scan your $musicpath$ for album art using the $coverfile$ mask as the filtering criteria and add any directory w/ the audio filetypes listed above.
Here's a screenshot:
I've attached a skin sample for you guys to play around with. Let me know how it goes.
Latest Update: 3/6/08
NOTE: v1 users can just overwrite the "browsecovers.exe" of their original installation to update to v2. If you want to utilize genre filters, just create buttons using the instructions below. I recommend you rebuilding your music database to make use of the latest features.
1. Fixed extra/duplicate album issue regarding hidden album art
2. Added genre based filtering of albums
- - Your music directory should look something like this:
- - - $musicpath$
- - - > Genre1
- - - - > Artist
- - - - - > Album
- - - - - > [coverart]
- - - > Genre2
- - - - > Artist
- - - - - > Album
- - - > Genre3
- - - - > Artist
- - - - - > Album
- - - > Genre4
- - - - > Artist
- - - - - > Album
Since your genre is alphabetized, you must assign a number to a genre in numerical order that corresponds to your alphabetical folder list.
i.e.
Indie = 1
Jazz = 2
Metal = 3
Rock = 4
etc.
Button Codes:
Code:
BXX,...,"SETVAR;genrechoice;1||SENDMSG;BrowseCovers;Genre" > Brings up Indie Albums BXX,...,"SETVAR;genrechoice;2||SENDMSG;BrowseCovers;Genre" > Brings up Jazz Albums BXX,...,"SETVAR;genrechoice;3||SENDMSG;BrowseCovers;Genre" > Brings up Metal Albums BXX,...,"SENDMSG;BrowseCovers;AllAlbums" > Brings up All Albums
You can have as many genres as you want.
Label Codes:
$GENRE_NAME$ is the name of your currently selected genre
Command not discussed, but was included in v1:
"GOTO_NUMBER","SENDMSG;BrowseCovers;goto" > Jumps to a specific Album number
v2 does not impact v1 original functionality.
In The Works
1. Bug fixes as they arise.
nLite'd XP Pro / RR v09/10/2008 / Winamp v5.13
Sal R. is offline   Reply With Quote
Old 01-29-2008, 04:04 PM   #2
will it play and add files to the playlist too ?
04 Accord Coupe Carputer
ajamils is offline   Reply With Quote
Old 01-29-2008, 04:08 PM   #3
EL CAMINO's Avatar
nice workaround sal!! downloading now
EDIT:if you need a builder to search for any type of file extention let me know, i still have that function from the old coverflow builder
MY RR SKIN |-POLARIS-| R.I.P.
EL CAMINO is offline   Reply With Quote
Old 01-29-2008, 04:11 PM   #4
Sal R.'s Avatar
It'll play the selected album, but it replaces the current playlist.
Hmmm...i didn't think to use an ADD1 type button, but it can.
*goes back to rework it*
EDIT: Okay, it's updated. It has a SELECT and ADD1 function...and some missing image files for the sample skin.
Old 01-29-2008, 04:30 PM   #5
Sal R.'s Avatar
Yeah, that'd be great. I was toying around w/ Sonic's builder, but can't quite get it to filter more than one file type.
So if you have it, that'd be great for me to take a look at.
Old 01-29-2008, 05:10 PM   #6
EL CAMINO's Avatar
i'll pm you that
Old 01-30-2008, 02:30 AM   #7
Valheru's Avatar
I like this ... coverflow would'nt run on my humble car-pc either ... but this does.
One small request, would it be possible for the user to specify the name of the album art ... all my album art is called "cover.jpg" rather than "folder.jpg" ...
Check out the TEKNIK skins here
Valheru is offline   Reply With Quote
Old 01-30-2008, 09:13 AM   #8
Sal R.'s Avatar
Sure. I'll make it so that it's user defined via .ini file until I can get a script together that can search multiple file types.
EDIT: Updated first post w/ new script to allow for user defined album art image in the .ini file.
Old 01-30-2008, 01:48 PM   #9
Valheru's Avatar
thanks for the update Sal ...
one thing though, it scans all the folders and creates the playlists but no cover art files are copied into the albumart folders !
one other thing ... any chance of releasing the execTBL code for the "SKIPTOLETTER2" that is in the skin for albumart browser ??? please !!
Old 01-30-2008, 03:27 PM   #10
Sal R.'s Avatar
Whoops!
I created the variable from the .ini file, but didn't use the variable in the rest of code...which includes the part that copies the art file.
My bad.
I'll post up a new version of the skin code later tonight after I've had a chance to test the script in the carPC. I've revised the code and rely solely on AI to load images to speed up the process. This will also enable the slider to update images.
Old 01-30-2008, 03:31 PM   #11
Valheru's Avatar
Thanks mate !
Old 01-30-2008, 07:33 PM   #12
Sal R.'s Avatar
Updated first post.
Road tested it w/ my M10K and works pretty good.
This revision is more process intesive. +30% in CPU usage while the script was running on my carPC.
If anyone has any suggestions to reduce cpu usage while it runs, I'd be glad to hear it.
Old 01-30-2008, 09:20 PM   #13
treetop777's Avatar
Something is wrong..
When i run albumbuilder.exe, all it does is start RR - doesn't create the "album view" folder. All my paths are default. Don't use playlists so i don't have a path for that - maybe that's it?
treetop777 is online now   Reply With Quote
Old 01-30-2008, 10:32 PM   #14
Sal R.'s Avatar
Are albumbuilder.exe and albumbuilder.ini in the same folder?
playlistpath is not used in the script. Only musicpath from rr.ini. So if RR isn't running, the script will open rr to get the musicpath to scan your library.
Default location of "Album View" is
C:\Program Files\Road Runner\Album View\
Default album art type is "folder.jpg"
Script only works for mp3's atm.
Old 01-31-2008, 07:38 AM   #15
Valheru's Avatar
All is working great now except the "Add Album" option.
This is my ExecTBL line ... "PLUSALBUMART","BROWSE||SELECT+||BACK".
I changed the "ADD1" to be "SELECT+", but no difference !
No matter what I use the the add album, it just clears the playlist and nothing is added.
Any idea's ?
Coverplay - an alternate coverflow clone juve021 RR Plugins 8 10-18-2007 12:04 PM
Album art downloader hijinks21 Software & Software Development 105 07-20-2006 09:56 AM
New Super 7" LCD- powers up, but No Signal display on RGB input- Home LCD works kinda HACKTHS LCD/Display 1 02-27-2006 09:01 PM
Select album to play via album art xGumbyx Mobile Impact 21 01-25-2006 07:46 PM
Radio kinda works?!?! BartTN Road Runner 6 06-08-2005 06:57 AM
