Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 04-07-2008, 03:04 PM   #1
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
OVERLAY [screen loader]
this is a very simple script that is capable to load any screen(.skin files) just like RR does, the big difference is that the background is not used, some people including myself needed this. heres some screenshot. same screen loaded using this little guy(top) and RR (bottom).
as of now only buttons are supported (is what i needed the most)i might include labels and indicators later on...
NOTE:skin(Teknik V2 created by valheru) hope is ok to use it as an example)
[[[labels enabled in BETA version]]]
1.25 out, memory leak and cpu usage fixed
1.3 out, RideRunner/RoadRunner Version
EL CAMINO is offline   Reply With Quote
Old 04-07-2008, 03:54 PM   #2
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Very nice.
I can already image the possibilities in my new skin...
I know you can achieve the same effect using pink transparencies, but for some reason, I could never get that to work properly.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 04-07-2008, 04:41 PM   #3
EL CAMINO's Avatar
another big advantage using this is, that even if a screen is loaded on top of RR you still have control over RR, not possible using RR for the moment.(i think guino said something about adding this features to RR in upcoming releases not sure.)
Old 04-08-2008, 01:14 PM   #4
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
Overlay in MKIII
I have this app in My skin on Destinator 7 works really well, slight delay in the button press.
but its the best so far.
in my D7 i have 2 OL graphic files 1 for map view , then you hit on/off button which will switch to the 2 image OL. so the menu's of D7 can be used .
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is online now   Reply With Quote
Old 04-09-2008, 03:36 PM   #5
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
I wonder if an image can be overlayed on top of a visualization? That way i can have buttons for next and prev vis right on top of the visualization itself. I'm going to have to try it!
Thanks El C.
treetop777 is offline   Reply With Quote
Old 04-09-2008, 05:01 PM   #6
Valheru's Avatar
Valheru is an unknown quantity at this point
well now - I could hardly refuse you the use of TEK2 ... seeing as you put so much work into it's creation ...
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0
Valheru is offline   Reply With Quote
Old 04-09-2008, 05:12 PM   #7
brandensin is an unknown quantity at this point
wow.. great job El.... This could allow gps view with tremandous improvement if i understand correctly.. carputer1 just inspired me what i wanna do with my gps view...
basically, we can now put the buttons on the map as floaters and make them look transparent... Is it possible you can put a timer and make the skin go away? you know like valheru's popup..
brandensin is offline   Reply With Quote
Old 04-09-2008, 07:36 PM   #8
Raw Wave
treetop777's Avatar
This is Fantastic! It does load over the vis, those buttons actually work for prev. and next avs. Now i only have to go dig into skincommands to learn how to position the overlay.
Thanks El Camino, there's a lot that can be done with this.
EDIT: nevermind the position, i loaded it in the truck and the buttons show where they should.
Old 04-09-2008, 09:09 PM   #9
EL CAMINO's Avatar
i'm glad you guys have found a good use for it, this is based in what i did for the carwings skin. part of the code belongs to LiquidSmoke, thats what i heard.
Old 04-09-2008, 11:20 PM   #10
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Nice work EL - Downloading now, AutoIT I take it?
blk02si is offline   Reply With Quote
Old 04-13-2008, 12:57 PM   #11
Raw Wave
treetop777's Avatar
Question
I want to overlay buttons on the GPS screen and also the main menu screen but the overlay buttons for each screen are in different positions..can that be done? if so, how?
Old 04-13-2008, 01:13 PM   #12
THE EXPERIMENTER
carputer1's Avatar
you need
to make the png's with the buttons where you want to see them.
this is how i did it for the gps scr in my skin.
you also need to have a seperate cmd line for the other images
"C_OVERLAY","RUN;$rrpath$Plug in's\Overlay\ElcosMenu.exe|overlay2.skin"
"O_OVERLAY","RUN;$rrpath$Plug in's\Overlay\ElcosMenu.exe|overlay.skin"
1st line gps map on overlay png
2nd line gps menu overlay png
hope that helps
Links
Old 04-13-2008, 02:44 PM   #13
Raw Wave
treetop777's Avatar
hope that helps
Sure does help.
This is the command on the main menu to start visu and an overlay for next prev avs:
"RUN;$SKINPATH$ElcosMenu.exe|overlay.skin||VIS U"
So to start and overlay the GPS screen (from a button on the main menu) i could use:
"RUN;$SKINPATH$ElcosMenu.exe|overlayGPS.skin|| GPS"
I get it! Thanks very much.
Old 04-13-2008, 09:48 PM   #14
BREWDOG52's Avatar
BREWDOG52 is an unknown quantity at this point
Thanks El Camino!!
worked great for Ig4...couldn't get it to look good over video, it just flickers, probably just my on-board graphics though...
here's a SS of My IG4 screen with the overlay
BREWDOG52 is offline   Reply With Quote
Old 04-14-2008, 01:27 AM   #15
THE EXPERIMENTER
carputer1's Avatar
this is a down fall
for OL , it dose not like video, nor dose it like being over ilists, theses are the only 2 things that i have found with this app so far.
nice Ig Ol skin
Links
Holux GPS Trouble mangus580 StreetDeck 34 11-26-2007 09:56 PM
