Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 04-19-2008, 10:24 AM   #1
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Thumbs up W3bLock - Screen Lock w/ GPS Tracking
Updated 4-19-2008 3:21 PM EST Version 1.3.0.0
W3bLock - Screen Lock For TouchScreen Systems w/ GPS Tracking.
Lock Screen with customizable screen, background, & buttons. Options include pin, audible alarm wav file, 5 startup applications / 5 RR commands on valid input, 5 startup applications / 5 RR commands on invalid input. If running with the RoadRunner frontend, it will also log GPS data on invalid pin entry, or from program start until valid pin entry.
GPS tracking requires W3bTracker account. (FREE)
Additional options exist like multi-pin entry, customizable password character for the display, etc.
Thanks to SonicXtacy02 for testing it out for me. Oh and just seeing your recent post, I guess this makes 5.
This program DOES NOT require RoadRunner, but if you want the GPS tracking and the ability to run the RR commands, it does require RR, and for GPS tracking, a W3bTracker account. Hence the reason for being in the RR plugin section. Figure more folk would want the tracking than not.
Grab it [ HERE ]
Version 1.3.1.0
  • Added option for adding program to Registry for optimized startup vs putting in your startup folder or other options. Edit the config.ini to enable the option:
    putinreg=yes
Version 1.3.0.0
  • Added RR Command output. Enter the commands for W3bLock to send to RR on valid or invalid pin entry.
  • Added multi-pin input. 3 users with their own 5 valid executable program entries and 5 RR commands. All invalid entries share 5 executable program entries and 5 RR commands.
  • Added "silentalarm". Enter your preset code for silentalarm and it will clear the panel entry, and start uploading gps tracking information without audible alarms, flashing on screen, or closing the screen and loading other applications/RR commands.
  • Added Customizable panel input "password character". Instead of seeing the pin you've entered, enter whatever character you choose and it will display that for each number entered.
Version 1.1.1.0
  • Added the option for GPS Tracking! With invalid Pin entry, or Pin entry timeout. This will ONLY work if you are running RoadRunner and RoadRunner has a GPS port set. It also requires you have a tracking account (FREE) at http://w3btracker.com
    That's where the tracking information will be sent.
Version 1.0.1.0
  • Add option for Logging and Pin Entry Timeout. If Pin is not entered within specified time, the alarm sounds and programs set for invalid entry run, will run. GPS logging will run from program start until valid Pin entry. Setting value to 0 will disable this option.
  • Button refresh fix.
Version 1.0.0.0
  • Initial Release. GPS Logging and run 5 applications on invalid Pin entry. Close screen lock and run 5 applicaitons on valid Pin entry.
  • Audible Alarm option.
  • Customizable background and buttons.
W3bMa5t3r is offline   Reply With Quote
Advertisement Sponsored links
Old 04-19-2008, 03:26 PM   #2
W3bMa5t3r's Avatar
Updated to version 1.3.
Old 04-19-2008, 04:39 PM   #3
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
very nice and complete plugin.. i've been testing it for days now and have discovered no issues
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 04-24-2008, 08:29 PM   #4
W3bMa5t3r's Avatar
Updated
Version 1.3.1.0
    putinreg=yes
Old 07-17-2008, 09:09 AM   #5
Jon-G's Avatar
Jon-G is on a distinguished road
Is there anyway of making this work with the Microsoft Fingerprint reader software?
Jon-G is offline   Reply With Quote
Live GPS tracking DTK GPS 11 05-08-2007 07:14 AM
GPS Tracking w/Text Messaging (with carputer on.) fromplanetbob GPS 18 06-26-2006 07:39 PM
Cheap GPS in-car tracking device MobileEVDO GPS 3 02-25-2006 09:19 PM
GPS tracking to avoid high speed police chase JimmyFitz GPS 3 02-09-2006 12:02 AM
