04-22-2008, 03:25 PM
#16
Super Moderator
Quote: Originally Posted by Sonicxtacy02
on the website there is a place on the bottom left corner where u must specify how many points u wish to show. Have you done that?
Yes, as well as in the stand alone on the drop down menu. I set it to 15 seconds for testing.
Quote: Originally Posted by W3bMa5t3r
John, why are you using the molo tracker url? that's only for uploading directly from a cell phone running the mologogo application
try using http://w3btracker.com/tracker.php
I honestly have no idea  It is the URL that is in the account info screen pop-up menu where I got my UID#, so I used it hahaha:
Changing it to the URL you posted above did the trick though.
Now a bit off topic  I LOVE that font that you are using above in the very first screen capture, on the 4 buttons. Can you tell me the name of it, or possibly post it for download? I took a screen capture, and fed it to what the font, and it got close, but no exact matches.
04-22-2008, 07:14 PM
#17
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Glad ya got it working.
The font, Yeah it's one of my fav, it's BoomBox, you can find it here.
04-23-2008, 09:38 AM
#18
using the stand alone right now on a trip from Spokane to Lake Havasu, seems to be working great when I have a data connection. if anyone wants to check it out, guest login: davedog
TruckPC, BoatPC, and CarPC I need a life!
04-23-2008, 11:07 AM
#19
Awesome
04-24-2008, 09:58 AM
#20
Username: davedog
Speed: 79.24264194
speeding much?? :-)
04-24-2008, 11:16 AM
#21
The Last Good Gremlin
Quote: Originally Posted by silvi4000
Username: davedog
Speed: 79.24264194
speeding much?? :-)
I saw a few 80+ in there yesterday, but I can't talk, I did it too yesterday. WOT is part of routine maintenance for my ESC-V.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
04-24-2008, 12:33 PM
#22
gotta keep those valves clean
05-02-2008, 09:10 PM
#23
I keep getting :
The application failed to initialize properly (0xc0000135).Click on OK to terminate the application. ?? any ideas ?
05-03-2008, 05:48 AM
#25
Thanks w3bMa5t3r , that (version1 ) and the newer version v2.5 installed after it seemed to sort out that issue for me and all is now working ok.
05-30-2008, 03:58 AM
#26
Can i ask if the tracking on this starts when RR first starts up , or only when you click on the button thats starts W3bTrackerRR ?
If its only when you click on the button , is there an easy way to get it to start when RR initially starts up , but not to pop up the W3bTrackerRR screen ?
Id like this to start 'silently' as such but im not sure how to do it.
06-06-2008, 02:01 AM
#27
Awesome plugin =] I've been using it to track my drive from CA to KS. I originally had it set to 15 second updates, which was a horrible idea. Now I'm stuck with all these points i want to erase but cant. Sure, I can do it one at a time, but when I select multiple points, it still only erases one. Also, the 'wipe all points' button that you refer to in the faq seems to be non-existant =[
06-11-2008, 01:49 PM
#28
any answers on that question above anyone ?
06-17-2008, 11:46 AM
#29
Hey guys. Yeah I have some work still to do, just too many projects lol. I'll check the RR plugin and see how I have it setup.
As far as the website goes, I have work to do there as well. The delete all should be a quick enough fix. I'll see what I can do...
06-29-2008, 07:15 PM
#30
I just wanted to share the way I added this to my Road Runner (DigitalFX 3.0 of course =D)
This will add W3bTracker to the button selection menu. The menu that comes up when you press and hold on a button.
I found the list of "MyApps" in the ExecTBL.ini and added this line to the bottom of them.
Code:
"MyApp48","LOAD;W3bTrackerRR.skin;W3bTrackerRR;C:\Program Files\Road Runner\W3bTrackerRR\W3bTrackerRR.exe;W3bTrackerRR||SETVAR;CUSTOMW3bTrackerRRCMD;W3bTrackerRRLoaded"
The reason I execute it like this is so it closes when I close roadrunner.
Then I scrolled down to the "SetAppLabels" line and added this to the end
Then I scrolled down to the "SetCommandLabels" section and added this line to the end
Code:
"SetCommandLabels48","SETVAR;MyApp48LB;W3BTrack||SetCommandLabels49"
I put W3bTrackerRR.skin and the two JPGs in the DigitalFX 3.0 folder
I created a simple logo icon for the button and put it here DigitalFX 3.0\MenuIcons\W3BTrack.png
I also attached this PNG for everyone to use.
Let me know if I am stepping on toes here.
I am the stig's cousin.
| Thread Tools |
| Display Modes |
Linear Mode
