Quote: Originally Posted by
Maheriano
I think I asked this question before but didn't quite understand the answer I got. So if I download this and install it, do I need to do anything else to run it in either the Carwings Dynamic skin or the eLite Lite skin? Is it true that I have to build my own screen in the skin to display it?
Off-topic: Do you guys realize that you can use VLC with RR by simply choosing VLC in RRConfig ? this is INCLUDED in the latest installs and we provide support for it:
http://www.mp3car.com/vbulletin/rr-p...r-plugins.html
Answering your questions:
1.Should this plugin still work? yes.
2.Does it require anything else? yes -- you need to modify the skin to use the commands posted in this thread to make use of the plugin.
3.Can I use it with carwings: yes, but you'd have to modify the skin to use it.
Still, the VLC support provided with RR's installer does NOT require any skin changes and can be used directly with any existing skin. The only possible reason for using this plugin would be if you want to use VLC with an old/unsupported version of RR (that didn't have VLC support).
