Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 09-07-2009, 06:13 AM   #106
lambosprit's Avatar
lambosprit is on a distinguished road
Quote: Originally Posted by boelle View Post
i have not had much chance to play around with vlc yet... but how do you configure how many speakers etc? and how do you choose subtitles etc?
Are you talking about just vlc or the plugins?
If the plugins then subtitles isn't possible because its not part of the sdk.
The tools menu gives you the audio settings where you can decide what to setup.
My plugin allows you to specify which audio device to use if your using the multiscreen option (2 dvd's at the same time on different screens) so you can hear the audio for each dvd seperately.
lambosprit is offline   Reply With Quote
Old 09-07-2009, 10:31 AM   #107
boelle is an unknown quantity at this point
i dont know which part... but i was thinking of selecting subtitles and and if i want dolby digital or DTS sound
boelle is offline   Reply With Quote
Old 09-17-2009, 08:39 PM   #108
anuchit is an unknown quantity at this point
I have question..
1. Can I move controle screen dvd area to right of touchscreen because I am Asia the rigth of power steering car ( left hand to touch controle)
2. Can I play VCD in RR with VLC plugin
anuchit is offline   Reply With Quote
Old 09-17-2009, 09:29 PM   #109
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
1-The place of the text is fixed at the top-right
2-You should be able to play VCD in RR with VLC plugin (IF it can play VCD outside RR it can play it inside) -- don't have any VCDs to try here but don't see why it wouldn't work.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 09-29-2009, 08:08 AM   #110
pincopallo69 is an unknown quantity at this point
VLC support...Simply Wonderful!!!!
Are there any video or videobrowser skin to study?
I've got some problem to send a selected item from a list (/S) to VLC application.
I've tried, but browser launch winamp video window.
pincopallo69 is offline   Reply With Quote
Old 09-29-2009, 09:36 PM   #111
guino's Avatar
When using this thread's VLC plugin you MUST use the skin commands from this plugin. This plugin is advanced and requires you to follow its instructions to get it to work correctly.
If you just want VLC with basic support working on any existing (unchanged) skin you should use the VLC plugin from the installer.
Old 09-30-2009, 10:11 AM   #112
Thanks Guino for quick response.
I actually work on Crystalsilver Skin (Dalailama's creation) and your last edition of RR with VLC plugin set.
There's no problem to set and launch VLC from ExecTBL.ini.It find my VIDEO directory and start play video.
It point directly to $vlcvideopath$ by simply adding:
"VIDEO","PAUSE"||LOAD;VLCVIDEO_PLAYER.skin;VLC;C:\ Programmi\VideoLAN\VLC\VLC.exe|$vlcvideopath$;Lett ore Multimediale VLC".
vlsvideopath is set on Skin.ini file to a video file directory on my HD.
I'd like to realize a VLCVIDEO_BROWSER to open file from a selection list.(like Dalailama does in his post http://www.carputer.it/showthread.php?t=7611)
I read your VIDEO .doc directory for VIDEO plug-in, but i didnt' understand what are new command to use.
By the way on web I haven't found nothing to make an easy video file selection directly by VIDEO_skin.
It's Hard but I'll search again. If you have another link please post me.
ThanKs again for your good job with RR.
Old 10-01-2009, 04:57 AM   #113
I've found some new information about VLC Skin Editor.
So I'll try to make a VLC Skin in Crystalsilver style.
I could use VLC native playlist function to search, load and manage video file like I actually do with Igo8PC navigator.... and works go on, ...maybe!!
...since someone makes something better!!
Old 10-01-2009, 09:03 AM   #114
guino's Avatar
Please note that if you're using the VLC player that comes with RR, you should NOT be talking about it in this thread -- this one is a separate VLC plugin (NOT the one that comes with RR). For discussing functions/features for the VLC player that comes with RR, you should open a new thread OR post in the Video Player's thread - thanks for understanding.
Custom Indicator Bug JohnWPB RR Bug Tracker 4 03-27-2008 06:10 PM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
IRMAN plugin knyarko StreetDeck 3 01-05-2007 09:26 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
