Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 08-02-2008, 02:07 PM   #16
Wants to make it harder
monkeyracer's Avatar
monkeyracer is an unknown quantity at this point
Quote: Originally Posted by Enforcer View Post
Please don't use AI.
ok
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 08-03-2008, 10:12 AM   #17
Quote: Originally Posted by guino View Post
If you haven't done that yet, you should be able to export the class into a .tlb file using "regasm /codebase /tlb P2140API.dll" then load it up to use it with the extension plugin sources.. or you could simply edit their demo in C# and have it send commands to RR regularly to set variables with the desired values -- just suggestions of course.
ok, i've got the P2140API.dll exported to P2140API.tlb...
I've looked through the example plugin, and it looks like for all my labels, I would use this code:
Code:
'***************************************************************** '* This Function will be called with a requested label code and '* format specified at the skin file. Simply return any text to '* be displayed for the specified format. '***************************************************************** Public Function ReturnLabel(ByRef LBL As String, ByRef FMT As String) As String Select Case LCase(LBL) Case "mylabel" 'This example returns a "hello" text to show it works ReturnLabel = "Hello from Extension!" 'Specify whatever and whichever labels you wish to create 'You can add as many as you'd like, and you can process complex labels as long 'as you parse them yourself (i.e. "mycomplexlabel;parameter") 'Case "mycommand2" 'Insert Command code here End Select End Function
So first I have to reference the codes from the API, then send those codes as a label to RR with returnlabel right? How do I reference the API in the code?
so if I want to turn Batt_V (from P2140API) into psuBATT_V (in RR) the code might look something like this:
Code:
Public Function ReturnLabel(ByRef LBL As String, ByRef FMT As String) As String Select Case LCase(LBL) Case "psuBATT_V" ReturnLabel = $Batt_V End Select End Function
As long as I create the $Batt_V variable from the Batt_V command right?
Or, am I way off base?
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-03-2008, 12:03 PM   #18
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Yep, you seem to have the idea.
Enforcer is offline   Reply With Quote
Old 08-03-2008, 02:39 PM   #19
Thanks, I feel like I might have a grasp on this, but then again, a fellow forum member had an idea about solar panels, it's all about the practice though. If I can't practice the idea, it means nothing.
I think I can get it, but how do I reference the P2140API.dll in the code so that the variables actually work?
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-03-2008, 03:11 PM   #20
Confusion Master
Enforcer's Avatar
Have you
1. registered te dll
2. added it in Project --> references
Old 08-03-2008, 03:56 PM   #21
Have you
1. can not find entry point... i think, I'll have to check again,
2. nope, will do...
thanks....
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-03-2008, 07:54 PM   #22
Confusion Master
Enforcer's Avatar
Which VB are you doing this in, it looks like it needs VB .net as it requires .NET 2.0
Old 08-03-2008, 08:29 PM   #23
I added the .dll as a resource, but it still couldn't find the entry point to register it...
I'm using the free Visual Basic 2008 Express Edition with the .net 3.5 framework...
Also, Visual C# 2008 Express Edition, since the API was done in c#.
I think I've got the beginnings of the plugin started:
Code:
Option Strict Off Option Explicit On <System.Runtime.InteropServices.ProgId("RRExtension_NET.RRExtension")> Public Class RRExtension Public Function ReturnLabel(ByRef LBL As String, ByRef FMT As String) As String Select Case LCase(LBL) Case "psuBATT_V" ReturnLabel = "P2140.P2140Board.cbP2140.Batt_V" Case "psuBATT_C" ReturnLabel = "P2140.P2140Board.cbP2140.Batt_C" End Select End Function
So theoretically, if this were all I needed for codes, In RR, I could use this:
Code:
L01,20,429,101,33,#FRed#,#FGreen#,#FBlue#,20,"BankGothic Md BT","psuBATT_V","CENTER" L01,20,489,101,33,#FRed#,#FGreen#,#FBlue#,20,"BankGothic Md BT","psuBATT_C","CENTER"
with the "X,PSUmonitoRR" extension referenced in menu.skin
Right?
Is the
Code:
in the right syntax? or should it have a $ in front of the p2140? and with or without quotes?
Code:
ReturnLabel = "$P2140.P2140Board.cbP2140.Batt_C"
Sorry if that's a noob question, but I've so far had about 30 minutes of experience with VB and/or C# etc...
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-05-2008, 09:33 AM   #24
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
You're in the right track... I have never tried to make an extension plugin with VS2008, but it should be possible.
You don't have to add the DLL to the references of the project, instead, you add the TLB you made and it should give you access to the classes/objects of the DLL -- so you'll be able to create the objects defined in the class to read the data from the PSU.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 08-05-2008, 09:39 AM   #25
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Code:
Code:
Right?
Is the
Code:
Code:
shouldnt need the $, and definitely no quotes. Quotes are only used for strings not variables. That all looks like it should work aside from that. Test it. Run it in RR with debug=TRUE and see what error message if any you get. If you get the activeX message your .dll is not communicating with RR .. probably because of the issue we discussed (cant register COM in the free version). If u'd like i can send you a source of RRFusion done in VB2008 so u can see the proper formatting.. but it looks like u've got a good grasp of it all.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 08-05-2008, 09:59 AM   #26
When I try, I get the error:
Quote:
A reference to 'C:\P2140API.tlb' could not be added.
The ActiveX type library 'C:\P2140API.tlb' was exported from a .NET assembly and cannot be added as a reference.
Add a reference to the .NET assembly instead.
I added the .dll as a reference and it seems it reads it.
I tried it without the quotes, and it "squiggly-blue-underlined" the "P2140.P2140Board.cbP2140.Batt_V" meaning some syntax is missing.
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-05-2008, 10:27 AM   #27
Terminal flasher
that means either that func in the dll is not public SHARED or its typed wrong. If you erase and type the first few characters the tooltip should appear to complete the rest of the line. Does that happen?
03 Acura RSX Coupe
Old 08-05-2008, 10:41 AM   #28
"Reference to a non-shared member requires an object reference"
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-06-2008, 04:50 PM   #29
jonessc's Avatar
jonessc is an unknown quantity at this point
That guys a legend
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 09-20-2008, 09:24 PM   #30
rocsell's Avatar
rocsell is an unknown quantity at this point
Any updates on this? How are you coming along??
rocsell is offline   Reply With Quote
Plug and play but where AJWatU LCD/Display 4 10-19-2007 05:39 PM
USB plug hard wired to glovebox sky_lennard Power Supplies 5 09-30-2007 12:52 AM
Where to Buy 3 Contact DC Power Plug tallyman General MP3Car Discussion 0 03-18-2007 10:53 PM
EPIA MII 10000 onboard USB plug help guizai General Hardware Discussion 5 01-26-2007 07:08 PM
multiple items on 1 12v accessory plug... also where to find dc-dc supply Valhalla1 Power Supplies 5 07-12-2003 02:43 AM
