Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 09-16-2008, 10:36 AM   #16
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
I don't think the path thing was always there, but it has been for quite a while.
Enforcer is online now   Reply With Quote
Old 09-22-2008, 11:50 AM   #17
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Quote: Originally Posted by mitchjs View Post
I will prob post my C# plugin template i did at some point
mitch
Quote: Originally Posted by 2k1Toaster View Post
Would appreciate that.
bump for c#...
Old 09-25-2008, 03:51 PM   #18
Raw Wave
mitchjs is on a distinguished road
ok, ok, i need to clean it up a bit!
me worky on it
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 09-25-2008, 03:54 PM   #19
2k1Toaster's Avatar
me worky on it
mitch
With the help of Sonic I already figured it out. So no rush...
Old 10-10-2008, 08:39 PM   #20
Confusion Master
Enforcer's Avatar
Think this FAQ might need updating
http://www.mp3car.com/vbulletin/rr-f...interface.html
And probably copied to this section.
Old 10-15-2008, 03:47 PM   #21
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
I'm just now getting around to using the new ReturnIndicatorEX... and for some reason i cant get an image to display in my indicator. In a test .dll i have the following code:
Code:
Public Function ReturnIndicatorEX(ByVal IND As String) As String ReturnIndicatorEX = "" Select Case LCase(IND) Case "pluginimage" ReturnIndicatorEX = "D:\MovieTimes.jpg" End Select End Function
There is a image file named movietimes.jpg in the correct path.. so why isnt anything displaying in the indicator?
EDIT... the same code works within ReturnIndicator just not ReturnIndicatorEX
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 10-15-2008, 04:39 PM   #22
Confusion Master
Enforcer's Avatar
Strange, I have no issues with ReturnIndicatorEX using file paths.
The fuesl ones use images from the road runner\gas folder, trafficams uses images from Road Runner\RRTC\images folder
and the new upd8 uses an image from the skin folder.
The only thing common to them is that they are all sub dirs of road runner.
One issue I do have is that if the image changes but the filename doesn't road runner will continue to show the old image.
List of available plugins and features JohnWPB RR Plugins 5 10-25-2008 07:16 PM
StreetDeck Input Plugins (Remotes, Steering Wheel Controls, etc.) god_of_cpu StreetDeck F.A.Q. 15 08-21-2007 04:46 PM
Embed several plugins, time delay Flappy Road Runner 3 01-02-2006 04:22 PM
Codecs and plugins Rider Road Runner 3 09-20-2005 09:55 AM
How to use extra/different plugins globbits ME Archive 7 08-30-2003 06:42 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
