Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 09-10-2008, 10:28 AM   #1
Raw Wave
mitchjs is on a distinguished road
All plugins need updating
GUINO has fixed the Indicator in plugins, to do that
a change has to be made in the main code to allow
a non processed Indicator...
this is the solution we came up with, and adding of the ReturnIndicatorEx
which depreciates ReturnIndicator
change your code to the default return of "" instead of "False"
example
Code:
Public Function ReturnIndicator(IND As String) As String 'Default (No Action) 'ONLY return "True" or "False" IF AND ONLY IF you process that code 'else return "" ReturnIndicator = "" Select Case LCase(IND) Case "myindicator" ReturnIndicatorEx = "True" End Select End Function
also... TO MOVE FORWARD change ReturnIndicator to ReturnIndicatorEx
ReturnIndicatorEx:
Code:
'***************************************************************** '* This Function will be called with requested indicator code '* specified at the skin file. Simply return "True" or "False" to '* displayed the respective ON or OFF layer of the skin images. '* alternatively you can specify a path to a file to be displayed '* as the indicator specified. Return "False" to erase the image. '* ONLY return something else IF AND ONLY IF you process that code '***************************************************************** Public Function ReturnIndicatorEx(IND As String) As String 'Default (No Action) ' DO NOT RETURN "False" for unprocess indicators, return "" ReturnIndicatorEx = "" Select Case LCase(IND) Case "myindicator" 'This example show ON for even seconds and OFF otherwise ReturnIndicatorEx = IIf(Val(Format(Time, "SS")) Mod 2 = 0, "C:\VBStuff\Road Runner\XMArt\1.gif", "False") 'Specify whatever and whichever indicators you wish to create 'You can add as many as you'd like, and you can process complex indicators as long 'as you parse them yourself (i.e. "mycomplexindicator;parameter") 'Case "myindicator2" 'Insert Code here to return "True", "False" or Path name End Select End Function
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 09-10-2008, 10:30 AM   #2
Raw Wave
I will prob post my C# plugin template i did at some point
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 09-10-2008, 10:35 AM   #3
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
it says there in the notes.. but i wanted to point out the addition to the indicator code. Plugin indicators can now be true, false, OR an image path. This will allow you to display an image through an indicator.. similar to the way the ALBUMART indicator works. To display the image simple create an indicator and set the case for that indicator to ReturnIndicatorEX = IMAGEPATH.. like so
Code:
Case "myindicator2" ReturnIndicatorEx = ImagePath 'where ImagePath is a full path to image file stored locally
to remove this indicator from being shown simply
Code:
ImagePath = "False"
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 09-10-2008, 10:39 AM   #4
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
mitch
Would appreciate that.
Old 09-10-2008, 02:42 PM   #5
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Code:
Code:
ImagePath = "False"
This is in fact a great improvement as the same indicator code is not limited to just On/Off states, but it can be expanded to many different states displayed each by a different image... an example would be the channel arts for XM/Sirius etc.. where the Album art is an indicator and the image of channel is just a different state for the indicator. Not to say, the images will be loaded with transparency over the OFF layer.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 09-10-2008, 03:37 PM   #6
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Mitch, in your example above you do have the code correct, but in the comments it states:
You may want to change that, as if they read the "instructions" in the code, it would defeat the "" instead of "false"
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is online now   Reply With Quote
Old 09-10-2008, 03:43 PM   #7
Terminal flasher
i'm lost on that one. You can still set ReturnIndicator to False, you just cant set it as false as the default setting. Where ReturnIndicator = "" used to be ReturnIndicator = false. That was pretty much the root of the problem
03 Acura RSX Coupe
Old 09-10-2008, 05:45 PM   #8
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Does this mean the the ReturnIndicator section is now completely ignored and we are to use ReturnIndicatorEx only?
Enforcer is offline   Reply With Quote
Old 09-10-2008, 06:13 PM   #9
Terminal flasher
no ReturnIndicator still works fine as long as the default isnt set to false. That being said ReturnIndicatorEX is EXACTLY the same accept for the image improvement
03 Acura RSX Coupe
Old 09-11-2008, 02:09 AM   #10
Robby BMW's Avatar
Robby BMW is on a distinguished road
Has been fixed also this issue?
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 09-11-2008, 06:35 AM   #11
Raw Wave
there is no issue
if not proccesing a slider return a -1
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 09-16-2008, 12:45 AM   #12
2k1Toaster's Avatar
bump for c#...
Old 09-16-2008, 05:00 AM   #13
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
You have me lost at "accept for the image improvement"? What Image improvment? You could always set a path to be displayed, since....IDK.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 09-16-2008, 08:41 AM   #14
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by 2k1Toaster View Post
bump for c#...
It's C#'s birthday, how old?
I was thinking this, but thought I had already given mitch too much of a hard time to mention it.
Old 09-16-2008, 09:36 AM   #15
Terminal flasher
you could always set a custom image path to for an indicator in the extension interface? Thats news to me.. i thought it was an ON/OFF thing only before.
03 Acura RSX Coupe
List of available plugins and features JohnWPB RR Plugins 5 10-25-2008 07:16 PM
StreetDeck Input Plugins (Remotes, Steering Wheel Controls, etc.) god_of_cpu StreetDeck F.A.Q. 15 08-21-2007 04:46 PM
Embed several plugins, time delay Flappy Road Runner 3 01-02-2006 04:22 PM
Codecs and plugins Rider Road Runner 3 09-20-2005 09:55 AM
How to use extra/different plugins globbits ME Archive 7 08-30-2003 06:42 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
