Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 10-04-2008, 12:19 AM   #16
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Why not make it a standard location for plugins but you can change it in the rr.ini file? That way, people without a clue or care will have their plugins work properly while those who know enough to change the path can do so?
Same with backgrounds. Default is a \backgrounds folder but you can change it if you like.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 10-04-2008, 08:00 AM   #17
Chuck's Avatar
Chuck is on a distinguished road
How about the Skin.ini
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 10-04-2008, 04:05 PM   #18
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
What about the skin.ini? Any entries from the rr.ini in the skin.ini WILL overide the rr.ini settings.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-04-2008, 07:37 PM   #19
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 10-08-2008, 05:28 PM   #20
lor109's Avatar
lor109 is on a distinguished road
I've just recently started messing with some of the newer plug-ins(RRTube, RRmedia, Elcolendar etc..) and for someone who has never really done anything except basic music functions on their carppc, I must say it can me a real pita getting things installed and functioning. I'm not complaining, I really appreciate all of the genius on this site. But I think Enforcer is 100% correct in stating that we need some sort of standardization.
Nathaniel
lor109 is offline   Reply With Quote
Old 10-08-2008, 05:39 PM   #21
MGD
MGD's Avatar
MGD is on a distinguished road
All plugins should be in a subfolder in Road Runner\Plugins, makes it easy for everyone.
MGD is offline   Reply With Quote
Old 10-08-2008, 05:59 PM   #22
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Hard-coded.
The same standard should be applied to non-skin specific .exe's.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 10-08-2008, 06:10 PM   #23
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
I totally, and 100% agree with both points.
1) a SET folder for plugins:
The Road Runner is getting more and more cluttered up with all of the plugins (And a big surge of them in the past 6 months or so)
On my system, I have 16 folders in the Road Runner folder for plugins, as well as 36 (THIRTY SIX!) dll's in the root Road Runner folder. It is just out of control!!!
I also think it should be:
Road Runner\Plugins
and inside that sub folders (\RRMedia,\MovieTimes ect...), as many plugins and packages, scripts ect have many files.
I can put the DLL's in a Plugins folder, as Enforcer mentioned, RR does not care where they are if they are registered.
But I can NOT move the 16 folders, MovieTimes, Gas, and so forth, as they would no longer work.
2) An entry in the rr.ini to point to whatever folder, such as:
PluginsLocation=C:\Program Files\Road Runner\Plugins
This would still let people choose where they are located, while still allowing a standard "Root" location.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 10-08-2008, 06:14 PM   #24
Sal R.'s Avatar
I vote for "pluginspath"
Seems more "in line" with the rest of RR's dir path variable names.
Old 10-15-2008, 09:41 PM   #25
GizmoQ's Avatar
XXXXPATH is akin to RR.ini variables not RRPath\folders. And I this this could be confusing to Newbies.
EDIT: OOps, disregard the above, now I understand.
Old 10-17-2008, 11:00 PM   #26
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
OK, resurrected this.
I now have another suggestion.
All plugins should have an indicator that has the same name as the plugin, so that other plugins can tell if they are running or not.
Enforcer is offline   Reply With Quote
Old 10-17-2008, 11:31 PM   #27
GizmoQ's Avatar
Now that one I like, too. I can see several obvious uses right away.
Again, which one did I miss?
Old 10-17-2008, 11:33 PM   #28
The Curator
Blue ZX3's Avatar
I think that is a great idea.
#1 A plugin with issues with another plugin would allow some error checking and maybe react diffently if the other one causing the problem is running.
#2 If someone makes a plugin that could use info that another plugin already populates a label then you could just grab that, instead of doubling the work the the other plugin did in the fist place, which could help to keep things efficient.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-17-2008, 11:45 PM   #29
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
another good idea, that needs to be added..
EL CAMINO is offline   Reply With Quote
Old 10-18-2008, 12:09 AM   #30
Confusion Master
Enforcer's Avatar
Also if I know RRMedia is running then RRUpd8 on a successful copy of new files to RR's Musicpath can get RRMedia to reread the music. (I assume their is a command for this, I did ask in the rrmedia thread but you nicely ignored my questions)
It has already. (well to the plugins standardisation sticky in the plugin section)
Standardisation of Plugins. Enforcer RR Plugins 1 01-13-2009 07:04 PM
List of available plugins and features JohnWPB RR Plugins 5 10-25-2008 07:16 PM
Where to find Plugins? skigil CarFrontEnd 1 11-25-2007 11:23 AM
StreetDeck Input Plugins (Remotes, Steering Wheel Controls, etc.) god_of_cpu StreetDeck F.A.Q. 15 08-21-2007 04:46 PM
Embed several plugins, time delay Flappy Road Runner 3 01-02-2006 04:22 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
