12-09-2008, 02:07 PM
#31
Though it may not be an iPhone, I do have a VZW Samsung Alias to donate..
2003 Mazda 6i Sedan - White
CarPC in the making!
12-09-2008, 02:18 PM
#32
in case of verizon i wont be able to use it as i cant put a sim card in it... but since you are local it should not be a problam to check is that thingie does send the caller id info.
in mean while im talking to samsung dev team to see if i can fix the problem with Samsung D807
12-28-2008, 01:30 PM
#33
I have an LG Dare from Verizon. I have made the serial port connection before no problem. How do you debug the com port to look for the CLID signal? I'd be happy to try.
Edit:
Now that I reread this thread and saw you had a link there for a comdebugger, I'll test it out, when I can get to it.
12-28-2008, 01:51 PM
#34
ok let me know... also there might be other branch version released, but i have to check that and how we can do that
12-28-2008, 11:44 PM
#35
Wow, I just realized I've completely forgotten about this thread until now (thanks to subscription emails). I'm off from school til Jan 26th, so I can finally put more effort into this project.
12-28-2008, 11:45 PM
#36
good so we will be using HandsFree instead of serial port as HFP has serial port functionality build in
01-04-2009, 11:37 PM
#37
I tested some with both LG Dare from verizon. When I try to use comportdebugger I got nothing. RRMobile says this phone doesn't support AT commands.
01-05-2009, 11:17 AM
#38
Umm maibe it dosnt
So, I guess we should focus on HFP version that doesnt relay on AT commands
01-05-2009, 11:43 AM
#39
Terminal flasher
Quote: Originally Posted by tempgp
Umm maibe it dosnt
that would be my suggestion.. it would ensure compatbility for a broad number of phones.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
01-05-2009, 01:19 PM
#40
ok will do
02-24-2009, 12:43 PM
#41
Any updates on this? How can I test HFP on my Dare?
Which programming language are you using, btw?
Also, my sister just recently got a Blackberry Storm. Her old phone was the Verizon XV6700 (running a fairly recent Windows Mobile OS, took out the Verizon pre-loaded applications and firmware). I'd able to switch phones at any time if we'd be able to get any more data out of Windows Mobile.
02-24-2009, 01:02 PM
#42
I'm using VB.net
My original Idea was to use AT commands for TX/RX but after some trial and error we decided to go w/ BlueSoleil bluetooth stack and that thingie needs C++. Once we get C++ DLL for .Net I can roll out and app that will do lts of things.
Unfortunaltly as i figured many of new phones use Windows mobile 5/6 and in that case there are no AT commands and all data is exchanged via ActiveSync so there might be aneed for another module to emitate activesync or use it protocol or something
02-24-2009, 01:11 PM
#43
Temp, I'll be happy to do any testing for you when you're ready. I have both and LG Dare and Samsung Q (win mobile 5).
02-24-2009, 03:35 PM
#44
So this program will be using C++? Cool!
I'm guessing that I need the BlueSoleil stack, right?
02-24-2009, 04:28 PM
#45
Signing up,
Not sure what help i can be as i have WindowsMobile 6.1 (HTC Touch HD).
Btw,an app exists which create's/translates AT commands for wm
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,ROADRUNNER, iGo8, Custom Freedom 2.1
| Thread Tools |
| Display Modes |
Linear Mode
