Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 02-24-2009, 04:51 PM   #46
tempgp's Avatar
tempgp is on a distinguished road
do you know that app name?
Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
Bluetooth Cell Phone CallerID [Pre-Alpha]
Custom Button Bash Board - Add physical touchable buttons to your CarPC Project
Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
tempgp is offline   Reply With Quote
Old 02-25-2009, 05:53 PM   #47
angel120's Avatar
angel120 is an unknown quantity at this point
I just installed the latest evaluation version of Bluesoleil, and downloaded their PhoneDialer plugin.
With the Bluesoleil stack, I was able to send name cards to my computer (wasn't able to with the original Vista stack). The PhoneDialer plugin works halfway. I'm able to make calls from my computer, but I can't see the CallerID if someone calls me. Bluesoleil also says it can't download my phone's contact list. Lastly, I tried sending a text message, but it failed.
Hopefully this is relevant info to the project..
2003 Mazda 6i Sedan - White
CarPC in the making!
angel120 is offline   Reply With Quote
Old 02-25-2009, 05:55 PM   #48
tempgp's Avatar
um stange. it worked fine on my Samsung D807
What phone did u try?
Old 02-25-2009, 06:20 PM   #49
angel120's Avatar
Verizon LG Dare and this bluetooth adapter, on my desktop with Vista Ultimate 32bit
Old 02-25-2009, 06:23 PM   #50
tempgp's Avatar
strange
what device capabilities does BS tells u?
Old 02-25-2009, 09:17 PM   #51
angel120's Avatar
I'm assuming this is what you were looking for:
And here are my ports:
Old 02-25-2009, 09:24 PM   #52
tempgp's Avatar
seams like all works fine
can u brows the address book?
oh i know why you got ptoblems. Demo has max of 2Mb file transfer
Old 02-25-2009, 09:49 PM   #53
angel120's Avatar
Damn. Alright, I'll get that fixed soon.
Old 02-25-2009, 11:31 PM   #54
tempgp's Avatar
just tur on then turn off BT before you do any test, I managed to get it over like that.
Old 02-26-2009, 11:28 AM   #55
bemenaker's Avatar
bemenaker is on a distinguished road
Hey, have you guys been following this thread at all:
http://www.mp3car.com/vbulletin/rr-p...ne-plugin.html
Seems like these two projects are extremely similar, and it might be a good idea to combine forces. Just a thought.
bemenaker is offline   Reply With Quote
Old 02-26-2009, 12:53 PM   #56
tempgp's Avatar
wow i was looking at it but aorigoiinally he/she didnt use bluesolei.. i better contact that person =)
Old 03-03-2009, 02:17 AM   #57
Blankstar85 is an unknown quantity at this point
Tried the program, Awesome. I have found a couple At commands, Still working on more. I have got it to answer a call, Make a data call.... Cant get voice call. When i call the phone just ring ring ring show up, lol. Just to refresh I have Samsung Glyde
Blankstar85 is offline   Reply With Quote
Old 03-03-2009, 11:15 AM   #58
tempgp's Avatar
I think version curently posted only supports caller ID # and nothing esle
Old 03-04-2009, 12:27 AM   #59
lacning74's Avatar
lacning74 is an unknown quantity at this point
i installed the parrot EVO bluetooth in my car. it works with the car speakers well but doesn't display numbers. can i use this CallerID program at the same time it is connected to EVO? if so, this would be perfect! i had a lot of issues trying to get my Treo paired with my computer, though, in the past. if CallerID can work with EVO simultaneously, i think i'll get a bluetooth dongle to try-out.
2007 Mini Cooper eee PC worklog
lacning74 is offline   Reply With Quote
Old 03-04-2009, 11:09 AM   #60
tempgp's Avatar
that depands on your setup,...
you only can heve 1 serial (1 incomming, 1 outgoing) connection between comp and the same device
If you want to use the same connection for you EVO then you need put thet port on Xport, if your EVO uses HS or HSF or HDA profiles then i have no idea whats gonna happen... well if you have original Toshiba stack then you probably will have multiple ports and that might work. If you have BlueSoleil or anything that combines ports in 1 then i doubt it.
An interesting solution to adding phone support to CarPC AvWuff Hardware Development 36 02-08-2009 01:35 AM
Need help from Bluetooth phone integration gurus Marassa Software & Software Development 3 06-08-2007 01:34 AM
BlueTooth Mobile ( Cell ) Phone Software AMC 96 TE Magna Wireless Communications 2 03-23-2006 07:44 AM
