Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 03-04-2009, 09:36 PM   #61
angel120's Avatar
angel120 is an unknown quantity at this point
I have the full version of Bluesoleil (version 6.2) now. I'm able to make a serial port connection, send and receive contacts, but I still cannot view my cell's phonebook (BS says "the operation is not supported").
When I go into Bluetooth Places > LG Dare, I see Bluetooth Dial-Up Netoworking, Bluetooth File Transfer, Bluetooth Messages, Bluetooth Object Push, Bluetooth Phonebook, and Bluetooth Serial Port (COM8).
DUN seems to work, though I didn't go beyond the setup (VZW charges a lot for tethering).
BT File Transfer seems to work, I'm able to view the files on my phone.
BT Messages doesn't work ("The operation is not supported").
Object Push seems to work. My phone says "check number or email," while Bluesoleil says "My business card was sent to LG Dare."
Phonebook doesn't work ("The operation is not supported").
Serial Port seems to work, I'm able to get and maintain a strong connection.
From my phone, I clicked on "brows files," and was able to see my desktop's root directory (though it was "empty").
Once again, this was on a Verizon Wireless LG Dare.
2003 Mazda 6i Sedan - White
CarPC in the making!
angel120 is offline   Reply With Quote
Old 03-05-2009, 11:52 AM   #62
tempgp's Avatar
tempgp is on a distinguished road
sounds terrible
do you know if LG has nay foftware to back up address book or something? If they do then there should way to get it working.
Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
Bluetooth Cell Phone CallerID [Pre-Alpha]
Custom Button Bash Board - Add physical touchable buttons to your CarPC Project
Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
tempgp is offline   Reply With Quote
Old 03-05-2009, 12:38 PM   #63
angel120's Avatar
I really don't think LG has any backup software.. Verizon takes care of that through a certain program in Get It Now. They charge $3/mo for the service.
Old 03-05-2009, 01:37 PM   #64
ray_t is an unknown quantity at this point
For what it's worth, I had to sell my LG phone so that I could use various features on my CC9060 bluetooth install. It's due to LG's only using bluetooth v1.3 (I think) where as Sony Ericssons use v2+.
ray_t is offline   Reply With Quote
Old 03-05-2009, 03:05 PM   #65
tempgp's Avatar
i dont belive it, ... if there is data cable on ebay then there is a software, which will work over BT too. I'm looking aty LG site now
Old 03-05-2009, 03:15 PM   #66
tempgp's Avatar
is the phone based on windowws mobile?
Old 03-05-2009, 04:00 PM   #67
angel120's Avatar
The LG Dare? Nope. Just good ol' crippled Verizon firmware.
Old 03-05-2009, 04:03 PM   #68
tempgp's Avatar
ok then there should be way to get data of the phone
i googled for data cable and found some store selling cable + program that allow to access addresss book.
Old 03-05-2009, 04:07 PM   #69
angel120's Avatar
The cable is no problem, my phone uses a standard USB cable for charging and data. I can use bitpim to back up my phone, etc etc. But my main thing is to get this bluetooth stuff working on here so I can put it in my car. There are times when I need to talk to someone, or someone calls me, while I'm driving and I either have to pull over or miss the call (I REFUSE to pick up my phone when I'm driving, the ticket is between $150-$200 here in NY).
Old 03-05-2009, 04:13 PM   #70
tempgp's Avatar
get windows tinted ;-)
so then if USB works then BT should work too the only wuestion is to finf how your "bitpim" requests the data. on all most of the phones data is exchanges via AT commands due to simple reason - cost of development is low. the only exeptions are iPhone, BlackBerry and Windows Mobiles .. thos need special modules
Old 03-05-2009, 04:34 PM   #71
angel120's Avatar
Bitpim actually enables me to see the phone's file system, so the user is able to literally do a full backup of the phone.
We may be going in a circle with this, but how does a car's bluetooth work? You mentioned in an earlier post that they use the Hands-Free Profile, right? Does the HFP send/receive AT commands?
What do the iPhones, BlackBerries, and Windows Mobile phones use?
Old 03-05-2009, 06:16 PM   #72
tempgp's Avatar
BT nativly was designed as wireless extention to serial port. So all service profiles wraped around serial ports. new profiles such as HS - Headset or HFS - Hands Free uses both data (audio pakage transfer) and serial port function at the same time.
Phone book spesifically: HFS profile does not support poone book nativly so it relys on servie part of AT commands to be used to request caller ID. HFS doesnt support phone book browsing or anything like that, so if some one wants to get a hold of phone book you still need to get it via AT commands. There is a diference in at command sent via HFS and throug serial port as they are controller by different IEEE documents. I can attach speck doc if i can find it here.
Other devices:
iPhone nativaly relys on vCard, how to work w/ it from BT prespective I dont know yet. Blue Solile claims they have support for it in their API
BlackBerry - never had one have no ifo about it
Windows Mobile - they need Active Sync connection, there is special Active Sync protocol that you can apply to serial port (there you can youse AS native commands to request address book and other information) I didnt do nay programs with AS yet.
Old 03-05-2009, 06:32 PM   #73
angel120's Avatar
Would it be possible to accomplish something similar to what your program will do, but instead use a USB cable? Might prove to be easier...
Old 03-05-2009, 11:40 PM   #74
tempgp's Avatar
shoul be the same ther is no difference in USB an serial (at least not in the case of cell phones)
Old 05-05-2009, 01:40 AM   #75
angel120's Avatar
It's been a while since there has been a post here.... Any updates?
I was playing around with a USB connection from my phone to my Vista laptop.
I was able to get BitPim to recognize it and pull the phonebook data from my phone.
I was able to get my USB Modem COM port to react to AT commands (via temp's software) which only started DATA calls, but still I can't get the Serial COM port to react to any AT commands..
Any ideas? At least there's SOME progress...
An interesting solution to adding phone support to CarPC AvWuff Hardware Development 36 02-08-2009 01:35 AM
Need help from Bluetooth phone integration gurus Marassa Software & Software Development 3 06-08-2007 01:34 AM
BlueTooth Mobile ( Cell ) Phone Software AMC 96 TE Magna Wireless Communications 2 03-23-2006 07:44 AM
