08-30-2009, 06:14 PM
#136
I haven't tried it. I was working on another plugin when VS2008 started actng up. I am currently trying to resolve this so I can finish this plugin.
09-17-2009, 09:05 PM
#137
The Last Good Gremlin
Is the "Cover.exe" compatible with RR if I have Foobar as my media player instead of Winamp?? CoverJuke doesn't seem to be sending the directory list to Foobar.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
09-17-2009, 11:51 PM
#138
I could not tell you, becuase I have never tried to use it with foobar. I do know that all cover.exe does is creat a variable called coverjukepath that can be loaded into a list and then played through RR. I think it should not matter what player plays the actual list.
09-17-2009, 11:57 PM
#139
i dont know if Covers.exe has been changed, but as far as i remember, all it does is sets the path , so RR can see the tracks inside the selected folder, is just a simple command.
SETPATH;<Selected Folder>
also in another note, coverjuke.ini has a setting that tells coverjuke to send either the folder path or the entire file list, i havent check how much coverjuke has changed, but the source for Covers.exe was available, in the original thread.
09-18-2009, 01:38 AM
#140
I use the latest of coverjuke, cover.exe, only sends me to the RR audio skin nothing more no list of the album i selected. It dont autoplay like the old coverjuke with Cover.exe did.. maybe I misunderstood the setup but I believe you point extenal player to cover.exe correct? I stopped playing with this awhile ago and seeing how you guys posted I figured I'd jump in and ask. I have it setup just dont use it due too I either set it to winamp and it plays but then stays on coverjuke skin and I create button to mainmenu and the album, song showing is'nt the same as the one playing.. i read this thread many times and older CJuke worked..I must be missing something...
Did it.. Done it... now I got to keep the neighbors kids away!!
Reason: reword
09-18-2009, 12:10 PM
#141
k, dont forget, RR needs a directory list, to be able to see where to get the files from, no directory list, no files to read. i'll do a quick test today. and see whats going on. maybe something changed in coverjuke.
09-18-2009, 08:34 PM
#142
it depends on your coverjuke action variable and the command that u have set for Coverjuke play. I have a plugin that does all of this for you, but my VS 2008 stopped working so I wasnt able to compile the last version, and the one before it is buggy. When I find time, I'll try to get it set-up on a different machine. Until then, if you need it to work immediately let me know and I can work with u to get it to work.
09-18-2009, 09:04 PM
#143
well currently I been playing with voice commands to control music but I certainly would like to get this working also.. as its hard to remember hundreds of albums by title..  I set the external player to point to winamp. If its set to cover.exe it chenages screens but just can't get it to play or laod anything into RR.. Currently I set it so the center of Chrysler emblem has button ("reloadlist||exit") upon it exiting to the menu screen.. It still dont update the current music tags? I would simply like to hit album and have it switch to audio sceen and play it.. i am using the same Exbl setting as the first one that was released maybe this is my issue.
/, CoverJuke
"COVERJUKE","LOAD;coverjuke.skin;CoverJUke;$RRPATH $Plugins\Coverjuke\CoverjukeLoad.exe;||SETTOPMOST; RR;TRUE"
"PREVALBUM","ACTIVATE;coverJuke||WAIT;0.1||SENDKEY ;{LEFT}||SETTOPMOST;RR;TRUE"
"NEXTALBUM","ACTIVATE;coverJuke||WAIT;0.1||SENDKEY ;{RIGHT}||SETTOPMOST;RR;TRUE"
"GOTOALBUM","||OSKTOCMD;LETTER;SKIPTOLETTER"
"SKIPTOLETTER","ACTIVATE;coverJuke||WAIT;0.1||SEND KEY;$LETTER$||SETTOPMOST;RR;TRUE"
"SLCTALBUM","!SELECT||AUDIO"
"SEEALBUM","MENU;Coverjuke_Playlist.skin||SETPATH; $COVERJUKEPATH$||SETTOPMOST;RR;TRUE"
"COVERJUKE_ENTER","ACTIVATE;coverJuke||WAIT;0.1||S ENDKEY;{ENTER}||SETTOPMOST;RR;TRUE"
"COVERJUKE_CANCEL","ESC||GETFOCUS||SETTOPMOST;RR;T RUE"
"ONEXIT","CLOSEWINDOW;coverJuke"
09-18-2009, 10:28 PM
#144
Yeh it's changed a bit since then. I'll have a look through my old files and see what I can come up with.
09-20-2009, 02:01 PM
#145
I was having the same bit of trouble with the high cpu usage. On my test machine Coverjuke ran fine using a singlecore Atom 230 on a 945G chipset. On my CarPC however I got 54% usage on my Core 2 T2500, meaning one core had 100% load. This on a 945GM chipset, and the performance was choppy to say the least.
After installing a new Intel Integrated Graphics driver ( actually I went form a ver. 7.0. "something" to a version 6 - the latest available from Intel ) everything is running like a charm.
Trying to make the CPU work like a GPU - bad idea :-)
09-25-2009, 11:46 AM
#146
Coverjuke 1.56 Elite
Ok I am new to this and have been beating my self trying to get this to work. I am using the elite skin, I have been able to get the coverjuke 1.56 to embed ok, I created an new skin for it. I have read this thread five times and keep getting clues but still cant get it to work right.
I have this in the exectbl.ini
/, CoverJuke (El-Camino)
"CJ_LOAD","LOAD;coverjuke.skin;Browse by Covers;$skinpath$coverjuke\Coverjuke.exe;!SDL_app"
"CJ_PREVALBUM","ACTIVATE;coverjuke||WAIT;0.1||SEND KEY;{LEFT}"
"CJ_NEXTALBUM","ACTIVATE;coverjuke||WAIT;0.1||SEND KEY;{RIGHT}"
"CJ_SELECT","ACTIVATE;coverjuke||WAIT;0.1||SENDKEY ;{ENTER}"
"CJ_PLAYALBUM","!SELECT||AUDIO"
"CJ_GOTOALBUM","||OSKTOCMD;LETTER;CJ_SKIPTOLET TER"
"CJ_SKIPTOLETTER","ACTIVATE;coverjuke||WAIT;0.1||S ENDKEY;$LETTER$"
"CJ_VIEWALBUM","LOAD;COVERJUKE_PLAYLIST.SKIN||SETP ATH;$COVERJUKEPATH$"
which loads coverjuke inside the skin but non of the other commands work. I created buttons for them but they just make coverjuke exit. I know the new version no longer uses cover.exe which I think is the command forwarder, but not sure. I see toxic000 updated the cjsend.exe for the new version but I cant find any docs on how to write the commnad.
I am also have the playlist update problem, but the thing is when I select the album to play in coverjuke it doesn't exit back to previous skin in stay in coverjuke, so I cant ever try the hidden playlist.
Thands for your help
09-25-2009, 12:21 PM
#147
i have same issue as you.. This was reason I stopped playing with it. many isssues I had and all the fixes the have posted are for ealier versions.
09-25-2009, 01:43 PM
#148
Quote: Originally Posted by toxic000
With this CJSend Version and the good Work from ws6vert i can use the Sendkeys.
With Space Navigator i can scroll through the Folders and select it. In my Skin is also an Button to reload Covers in Coverjuke.
coverJuke 1.56 and elite lite
Ok I got more of it working, I download the th new cjsend.exe script and put it in the coverjuke folder. Edited the exectbl.ini with the following wanted commands posted by ws6vert
Code:
SENDING KEYS TO COVERJUKE
1. To send a key to coverjuke simply make a button in your skin that executes the key stroke you want to send according
to the following list:
Note: The following list is based on your coverjuke directory being located in C:\Program Files\Coverjuke. If it
in a different location you will have to update the button code with the correct directory.
DESC. Button Code
Next Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{RIGHT}"
Prev. Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{LEFT}"
Select Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{ENTER}"
Skip to Letter "RUN;C:\Program Files\Coverjuke\CJSend.exe|{"letter"}" -- Insert any letter (could even be set to a variable in RR, for quick searching)
1st Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{HOME}"
last Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{END}"
Randon Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{SPACE}"
Jump Right 10 albums "RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGDN}"
Jump Left 10 albums "RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGUP}"
Close CoverJuke "RUN;C:\Program Files\Coverjuke\CJSend.exe|{ESC}" *New
Created a few buttons in the my skin in elite left, right, select and reloadlistex. I can now scroll left and right select the current displaying album and refresh the playlist so elite and coverjuke the same album info.
When I select the album I would like coverjuke to go to the previous menu. Anyone now how to do this.
09-25-2009, 05:37 PM
#149
Guys... patience. I have posted already that I am working on a plugin for this. There is really no point in wasting your time trying to hack together a working version of the scripts posted earlier. They were written for a previous version of CJ, with a different window handle and apparently a different way of handling keystrokes. So, please be patient. I am in school at the moment, so I dont get much time to work on this, along with VS2008 issues. I will try to find time to work on this, this weekend. Maybe get a basic version working.
09-26-2009, 12:24 AM
#150
Sure, that's easy.
Open up your coverjuke_playlist.skin and edit the SELECT button to "SELECT||RELOADLIST||EXIT||EXIT"
If you want it to go to a specific screen like audio player you could also use:
"SELECT||RELOADLIST||EXIT||LOAD;AUDIO_PLAYER.S KIN"
| Thread Tools |
| Display Modes |
Linear Mode
