Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 02-27-2009, 08:36 AM   #16
toxic000 is an unknown quantity at this point
In Coverjuke Config i have a little Problem with set multiple folders for music.
I can set only one Folder and also more than one folder. In Coverjuke it displays only the first defined Folder.
In Config.ini it displays right with the comma.
toxic000 is offline   Reply With Quote
Old 02-27-2009, 02:02 PM   #17
ws6vert is an unknown quantity at this point
toxic, I will look into this today, and post up tonight.
edit:
Ok I have looked into this, and it appears that coverjuke cannot open multiple folders at one time, but you can select which folder to open at start-up. Just check the box for "Selection of folder at startup," When Coverjuke loads, it will open a screen, and give the option to select a particular folder to open and view the album covers. This is probably not the best way for coverjuke to handle this. I will contact the creator and see if there is any way that it can changed to load out of the separate folders at one time. Word of caution, Coverjuke does not resize the window that allows you to select the folder. So it will probably look extremely weird inside of RR.
Toxic, how is your music directory set-up? Can you set a top-level folder for all albums?
ex: C:\My Documents\My Music
ws6vert is offline   Reply With Quote
Old 02-27-2009, 06:02 PM   #18
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Went through the instructions and this is the result. Is this what it supposed to look like? It's quite different from the screen cap in the first post.
treetop777 is offline   Reply With Quote
Old 02-27-2009, 06:59 PM   #19
Looks good to me, you can turn off all those extra buttons and stuff around the corners in the Coverjuke Config. Since we wont be using coverjuke to play the albums, there is no need for those buttons. Makes it look much cleaner.
Also, coverjuke is fully skinnable in its self, and can be made to look very good inside of RR, I prefer the xbox style skin because it seems like it would be easier to control on a touchscreen.
Old 02-27-2009, 07:42 PM   #20
GOTOALBUM command has been fixed.
The fix is as follows:
Add/change in ExecTBL:
Code:
"GOTOALBUM","||OSKTOCMD;CJ_LETTER;SKIPTOLETTER" "SKIPTOLETTER","RUN;$pluginspath$CJSend.exe|{$CJ_LETTER$}"
Old 02-27-2009, 08:36 PM   #21
Version 1.2 in progress
After having a discussion with another member on the forums, I see the need to rewrite a certain portion of the script.
Here is the issue:
RR does not immediately grab a window to embed it, it takes anywhere from half a second to 2 seconds depending on the speed of the system. This causes a problem with the script because the script sizes coverjuke based on the size of the embedder window. I will rewrite the code to wait on RR to embed the container window that way it will properly resize coverjuke.
So, if others are seeing that coverjuke opens too big sometimes, this is most likely the issue. I will be working on the code, and hopefully it wont be too long before I can get the update.
Old 02-28-2009, 11:40 AM   #22
Announcement: Version 1.2 has been attached.
Version 1.2 has been attached. See first post!
If upgrading from version 1.1:
-Replace version 1.1.exe with "Coverjuke Embedder V1.2.exe".
-Change your COVERJUKE command in the execTBL to:
Code:
"COVERJUKE","LOAD;coverjuke.skin;!AutoIT v3 Gui;$PluginsPath$CJ Embedder V1.2.exe;CJ Embedder"
And that's it!
I strongly suggest udating to this version, as it is faster, and more stable than the last version. This version will wait for RR to embed the container window before executing the rest of the script. This solves the problem with coverjuke sizing improperly.
Enjoy!
Old 02-28-2009, 01:08 PM   #23
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
Code:
"COVERJUKE","LOAD;coverjuke.skin;Browsing By Cover;$PluginsPath$CJ Embedder V1.2.exe;CJ Embedder"
f voice is enabled, will say "Browsing By Cover", instead of "!AutoIT v3 Gui" iwith the above code.
use voice=true in rr.ini to test, some people use voice = true, including myself.
EL CAMINO is offline   Reply With Quote
Old 02-28-2009, 02:42 PM   #24
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
WOW! 1.2 is much improved! Thanks for the time to get this working, looks great, runs super fast, and the RR integration is outstanding.
Now all we need is multiple folders.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 02-28-2009, 02:56 PM   #25
dotcom1 is an unknown quantity at this point
+1
dotcom1 is offline   Reply With Quote
Old 02-28-2009, 04:08 PM   #26
Your v1.2 looks really good. Embeding with correct resizing goes perfect!
My Album Folder is
D:\Music (all inside with *mp3, *wma, ..., on end)
In Coverjuke but, i want only see my Music Albums. Because in D:\Music lies also the \eBooks Folder- that the reason for use multiple Folders.
For this, you can change in your skin.ini:
The result in my skin:
Old 02-28-2009, 04:32 PM   #27
kbreeden
Thanks for putting this together, WS6vert.
I'm having a problem. I have followed the instructions carefully. Coverjuke works fine outside of RR. I have assigned a button in RR (DFX skin) with the command "COVERJUKE" ; however, when I hit the button the Coverjuke skin loads but coverjuke.exe does not execute (nothing but the skin on screen and coverjuke.exe does not show up in task manager). Any ideas?
kbreeden is offline   Reply With Quote
Old 02-28-2009, 05:10 PM   #28
Raw Wave
treetop777's Avatar
That also had me baffled for a minute. I installed the program to RideRunner\plugins\ but the lines you add to skin.ini calls for coverjuke to be in c:\program files\
Check that and see..
Old 03-01-2009, 12:01 AM   #29
El Camino:
Thats a great Idea, I will make that change. I have never worked with RR's speaking capabilities, I just assumed that RR needed the class name in order to embed the window!
Toxic:
Excellent Find!! I will try to work this into the readME. Others that want to be able to open multiple folders in Coverjuke please refer to Toxic's post. I will also search through Coverjuke's key commands to see if there is a way to bring up that window after the covers have loaded.
kbreeden:
The script needs to know where coverjuke is installed on your computer. It can be anywhere, you just need to set the variable "CJ_DirPath" to the folder that contains the coverjuke.exe. I tried to set up the ReadMe, execTBL, and skin with the default paths.
Old 03-01-2009, 06:04 AM   #30
Toxic:
Change to a other Folder at runtime would be excellent.
Second Way:
I think, it would go well with RR Commands like writetofile or addtofile or better saveto"skin".
Like the savetoskin command, it would be the best:
change in RR a folder, press the coverjuke button, and a saveto"Coverjuke.ini" Command set the new folder in the ini File and restart simple Coverjuke.
With that, its no need for multiple Folders, because its the better way to load the Covers (Speed of Coverjuke with less folders).
For this way, BlueZX3 can may help us? If he can write a command, with the same functions like Savetoskin, only for a other ini File...
Switching between RR and copilot CombatCQB Road Runner 13 01-26-2009 06:27 PM
RR Black screen of death? maxxell Road Runner 7 12-17-2008 10:23 PM
RR Interchange - Update RR via a USB Media Stick Gobby Road Runner 60 10-04-2005 05:48 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
Bruno Speech Recognition with RR? ruairi Road Runner 12 05-03-2005 01:20 PM
