Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 03-14-2009, 11:51 AM   #61
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
Quote: Originally Posted by kbreeden View Post
Nice work on this, wd6vert! Now all we need is for Mika, the developer of Coverjuke, to build in a database feature so it doesn't have to load all of the covers each time.
I thought thats what the usecache line in the ini took care of.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 03-14-2009, 11:57 AM   #62
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
what i thought to but it still scans the music folder , unless i have a setting wrong
carputer1 is offline   Reply With Quote
Old 03-14-2009, 09:28 PM   #63
l1nk's Avatar
l1nk is an unknown quantity at this point
Same here... Maybe usecache is still unused by the coverjuke or simply it does not work as supposed
l1nk is offline   Reply With Quote
Old 03-15-2009, 12:35 AM   #64
ws6vert is an unknown quantity at this point
It does work, I could send you my cache file and it wil load all the information about my covers, it's just unable to load the actual image. I believe the way this program is written, is it caches the data for each of the covers, and then when the program is run, it knows eactly where to go to get the image to use for the software. If it were to make a copy of each image, for loading via a cache system similar to the internet, it would be a pretty big cache file and folder.
Do you have selected "use cache data" and "fast loading cover"? Mine load up pretty quickly with these two parameters checked.
ws6vert is online now   Reply With Quote
Old 04-06-2009, 05:40 PM   #65
Version 1.54 is here and better than ever
Coverjuke 1.54 was released this week, and with the improvements to this version.... It embeds perfectly without the need of the CoverjukeEmbedder script! I will update the first post to remove the download files and give instructions for embedding in RR.
Old 04-07-2009, 01:03 AM   #66
dotcom1 is an unknown quantity at this point
dotcom1 is offline   Reply With Quote
Old 04-07-2009, 02:29 PM   #67
THE EXPERIMENTER
carputer1's Avatar
well at 1st look much much better ,Embeds very nicly and no scanning on start up as well, now to see what else is in here lol...
Old 04-07-2009, 03:15 PM   #68
what is the code line in ExecTBL.ini
"COVERJUKE","LOAD;coverjuke.skin;$skinpath$coverju ke\Coverjuke.exe;Coverjuke"
seems not working
Old 04-08-2009, 01:02 AM   #69
"COVERJUKE","LOAD;coverjuke.skin;Browse by Covers;$skinpath$coverjuke\Coverjuke.exe;!SDL_app"
The only thing I see as a problem, is that CPU usage it up from normal. Not sure why. I havent been able to use SENDKEYS with it embedded either, but I'm still investigating. If anything, I can rewrite CJSend to work.
Old 04-08-2009, 02:54 AM   #70
Schma is an unknown quantity at this point
New version works pretty nice but...
when i select an album coverjuke does not exit automatically to audio player like the old one used to.
Also if i exit via the exit button(in the skin, not coverjuke) i get to audio player, but it still shows the earlier album but its playing the album i just selected.
Any solution for these?
Schma is offline   Reply With Quote
Old 04-08-2009, 02:13 PM   #71
Yeh, let me finish up with my tests, and i will update the first post with everything needed to get it working correctly again. If someone wants to beat me to it, then have at it!
Old 04-13-2009, 08:07 AM   #72
kbreeden
Excited about the new release, though I was never able to get the last version to run well due to 100% CPU load (P4, 2.4ghz).
kbreeden is offline   Reply With Quote
Old 04-20-2009, 04:30 PM   #73
1.55 is out!!!!
SENDKEYS?!?!
Old 04-20-2009, 10:20 PM   #74
looks promising, I will be done with classes next week and hopefully will have time to look at this again
Old 04-28-2009, 07:19 AM   #75
Has anyone got this to work with windows 7?
It is really slow and nothing seems to help in the compatibility mode.
Tried all the settings.The movement of the covers is just really slow.
It worked great in vista on this very same machine.
Switching between RR and copilot CombatCQB Road Runner 13 01-26-2009 06:27 PM
RR Black screen of death? maxxell Road Runner 7 12-17-2008 10:23 PM
RR Interchange - Update RR via a USB Media Stick Gobby Road Runner 60 10-04-2005 05:48 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
Bruno Speech Recognition with RR? ruairi Road Runner 12 05-03-2005 01:20 PM
