04-30-2009, 06:05 PM
#76
How exactly do you embed the cover flow? I am lost when it comes to modifying the exec tbl and assigning a key to bring up cover flow.
I am using digital fx 4.0
04-30-2009, 11:48 PM
#77
"COVERJUKE","LOAD;coverjuke.skin;Browse by Covers;$skinpath$coverjuke\Coverjuke.exe;!SDL_app"
05-01-2009, 12:50 AM
#78
Finally finished with Finals... who would of thought designing a Cryogenic Distillation coumn would be so hard! HA! Anyways, I hope to find some time after this weekend to get back on here and look at this and hopefully figure the majority of it out. Mostly Sendkeys as last time I tried I couldn't get it to work. thank you all for the patience.
05-01-2009, 01:59 PM
#79
QUOTE=ws6vert;1309931]Finally finished with Finals... who would of thought designing a Cryogenic Distillation coumn would be so hard! HA! Anyways, I hope to find some time after this weekend to get back on here and look at this and hopefully figure the majority of it out. Mostly Sendkeys as last time I tried I couldn't get it to work. thank you all for the patience.[/QUOTE]
05-22-2009, 12:10 PM
#80
Now, the v1.56 is out. And it has Support for other player as the internal - Winamp function perfect, without our cover.exe.
And since v1.55 i have big Problems with my CarPC - With Coverjuke my CPU load is on 100%
Only, if i set the Framerate to 1(!), the Load goes down to ~20%. But this looks not good, and is even to big for use with Riderunner,Navigation etc....
Is there a way, to contact the programmer from coverJuke about this Problem?
The older Versions of this Program would be the best, because the CPU Load was at the minimum and it looks good. Now it only looks good on my Core2Duo HomePC.
05-22-2009, 06:32 PM
#81
Dot & Toxic:
Sorry I haven't had a chance to get going with this. I thought I had my computer fixed up but it is still acting up. Since the CPU usage of Coverjuke has increased dramatically, I have started to try to think of new ways to integrate this with RR. When I get my computer stable enough, I'm going to look into a true plugin for RR. I intend to use the sources to try to lean down coverjuke to just displaying the cover animation, and delegate playing of the albums or movies to RR. This should cut the CPU back down to normal. But this will take time. Anyone with some coding experience want to jump on board let me know and maybe we can get some headway started.
Ws6vert
06-04-2009, 07:30 PM
#82
Good News!
V 1.56 is out and CPU is down tremendously! There is also plugin support for winamp, which I will have to try out as well.
06-05-2009, 09:09 AM
#83
Hi,
which v1.56 had you tested? I downloaded the 1.56 today and install it again.
But, the same result as before:
Below my System. In my Musicfolder are only 4 Albums.
Which settings you use?
06-05-2009, 06:27 PM
#84
Quote: Originally Posted by toxic000
Hi,
Hey man, I just used regular settings like I always have... Here is a screen cap:
I'll try to verify on another computer if I get a chance. I would still like to pursue a trimmed version specific for RR though. Media playback and Tag Reading I think is what is causing the majority of CPU issues as that seems to have been his main focus lately
06-05-2009, 09:41 PM
#85
Quote: Originally Posted by ws6vert
Good News!
Wow, getting better all the time. Maybe my Pentium 4 can handle it now.
06-08-2009, 04:09 PM
#86
Coverjuke 1.54 was released this week.......... and give instructions for embedding in RR.
A guide to what is needed to be done to get this working, would be nice...
Because I don't get it....
You install Coverjuke with it's exe from sourceforge.
You make a .skin file. You call the skinfile from a button in your RR audioplayer skin,
with the command "COVERJUKE","LOAD;coverjuke.skin;Browse by Covers;$skinpath$coverjuke\Coverjuke.exe;!SDL_app" .
And....then...?
I'm lost at the rest....
Henrik
06-09-2009, 01:51 PM
#87
And then there's nothing left to do. Your skin file should open with Coverjuke embedded into it. Lately the new releases have had CPU issues. Version 1.56 seems to have fixed this issue, but I have not had a healthy computer over the past months to work come up with step-by-step instructions again. There is a wealth of information on getting applications embedded in RR, I would suggest scouring those with anymore questions. If you have questions regarding interfacing between coverjuke and RR, then there should be a Covers.exe script that will do that for you. If this is your question, then post up specifically and I will help you get it set up.
06-09-2009, 07:10 PM
#88
The Last Good Gremlin
What's the latest news on keyboard commands? I want to skin some buttons and use sendkeys for stuff like prev, next, select, first, last, folder menu, reload, etc.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
06-10-2009, 12:19 AM
#89
you can press F1 and a help screen will popup, select keyboard, to see all available shortcuts.
06-11-2009, 09:16 AM
#90
Latest news is I haven't had a chance to try SendKeys on the new version. Like El Camino said, hit F1 and try to pass a keyboard shortcut to it using Sendkeys. If it doesn't work, I will look at making CJSend work with the new version. I think I will just have to update the Window handle in the script for it to work.
| Thread Tools |
| Display Modes |
Linear Mode
