06-12-2009, 06:06 AM
#91
Hi,
i edited your CJSend Script and now it goes with the v1.56.
...but i cannot use, because the high CPU Load
Can someone upload its config.ini, where the CPU Load is down with CJ? On a "normal" PC, without Duo or Quad CPU!
06-12-2009, 08:38 AM
#92
I'll post my config when I make it back to the house. The Computer the screenshot was on, was a P4 2.2GHz. I'll try to get my Lap-top stable enough to see the CPU load on it, its a Centrino 1.76 ghz.
06-13-2009, 08:49 AM
#93
I've been using the 1.56 without any script (to my knowledge) for the past day.
I didn't feel any CPU problems. It worked like a charm.
Didn't check the cpu load though. But it's on a dual Atom board, so plenty of upperarm strength there.
I made a skin file that didn't try to send anything to coverjuke,
so functionality is just flapping through the covers with fingersliding and single taping the cover I'd like to hear.
That works fine, although access to the search function would be nice at some point in the future.
Oh yes, and did a "reloadlist||exit" on the exit button
Henrik
06-15-2009, 08:06 PM
#94
CPU test results
Ok, I have tested the newest version on a pretty basic computer:
Samsung N110
Intel Atom 1.6ghz
1.00 gb RAM
Windows XP SP3
The CPU hovers around 15 to 18 while I constantly cycled through 4 album arts. It may be different if there are MANY covers, but it seemed pretty stable.
Check out the screen shot and coverjuke.ini:
coverJuke.txt
06-15-2009, 09:45 PM
#95
toxic000 can you share the edited CJSend script?
06-16-2009, 08:05 AM
#96
Okay thanks ws6vert,
in my Virtual PC is it again at 100% with your coverjuke.ini - but it has no Graphic Card. I test it again in Car with a Graphic Card.
@Schma: simple edit the File Name to *.exe
With this CJSend Version and the good Work from ws6vert i can use the Sendkeys.
With Space Navigator i can scroll through the Folders and select it. In my Skin is also an Button to reload Covers in Coverjuke.
06-26-2009, 10:21 AM
#97
Hi. Are there any released skins that have Coverjunk fully pre-integrated?
Thanks.
06-26-2009, 12:32 PM
#98
The Last Good Gremlin
Outstanding! Works great. Thanx
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
06-26-2009, 02:14 PM
#99
Thanks.
Doc Breezy has coverjuke in 506 Breezy I believe, not sure if it has been updated with the new version that does not require the embedder script.
06-30-2009, 05:46 AM
#100
Ok i embeded the coverjuke and thats fine..
BUT the "Music information" on RR is not properly like the music is playing against coverjuke.
Im using foobar2000 as external audio player on coverjuke and foobar2000 plugin by guino on RR..
Do u guys have the same problem with winamp ?
Ty
Reason: new problem lol
06-30-2009, 11:33 AM
#101
Dont understand your problem/question enough to aswer you...
Henrik
06-30-2009, 12:14 PM
#102
I understand. The problem is that when u change the album or song in coverjuke, the labels in RR dont update with the right information. You will need to send a reloadlist command or have a command set-up to take u to a screen with a play-list.
07-01-2009, 05:19 AM
#103
Henrik
Did your reloadlist command worked properly ? i having some problems against it.. sometimes the coverjuke do not send ALL album musics for winamp and i have a button RELOADLIST just to test but nothing happens on RR.. it just play and do not "reloaD" music information..
Any tips?
if possible can u post your coverjuke.ini ?
07-01-2009, 08:26 AM
#104
Can't remember if the correct name of the command is RELOADLIST, you can check that in the commandfile for Roadrunner. But yes, it works perfectly for me.
Sorry, can't post my ini file as I am with one leg out the door for a 2 weeks trip to England already.
Henrik
07-01-2009, 09:19 AM
#105
Henrik
I tried all of reload** of roadruner noone works :/
ReloadLIST
reloadlistex
reload.....
did you select external player as winamp right ?
BTW "RELOADLISTEX" works but my skins uses TAGTITLE,TAGLEALBUM etcetc commands and they do not work but IF i used TRACKTITLE command it works flawesly.. i lost Album name genre etc.
I will wait to a better solution so...
| Thread Tools |
| Display Modes |
Linear Mode
