Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 07-01-2009, 12:46 PM   #106
ws6vert is an unknown quantity at this point
U can add a hidden playlist to the screen that coverjuke exits back to after selecting an album. That will force RR to update its information. Let me know if u want to try this, and I can tell you how to set it up.
ws6vert is offline   Reply With Quote
Old 07-01-2009, 03:11 PM   #107
victornet is an unknown quantity at this point
Of course i want . Thanks for your time btw
victornet is offline   Reply With Quote
Old 07-01-2009, 05:05 PM   #108
You mind posting the Skin documentation file for RR? haha I dont have it installed on this computer, and Im in London this month and cant get to another one.
Old 07-01-2009, 06:11 PM   #109
Here we go :P
Old 07-01-2009, 07:24 PM   #110
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
to create a hidden playlist use the skin editor, add a playlist in the screen. then drag it outside of the visible area, or just change the first 4 parameters, S,-1,-1,0,0, . easy.
EL CAMINO is offline   Reply With Quote
Old 07-01-2009, 08:35 PM   #111
There we go... El beat me to it. I didnt know the exact order of the window placement, so I was hoping to see the commands. 'Preciate El. Let us know if u still have issues with it, victor.
Old 07-01-2009, 09:57 PM   #112
Works like a charm ..
Thanks a lot EL CAMINO and ws6vert..
Old 07-02-2009, 01:17 AM   #113
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
you poor sod comming here lol... your just round the corner from me 1/2 drive at most lol...
carputer1 is offline   Reply With Quote
Old 07-04-2009, 01:41 PM   #114
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Ok, I just gave this a try to embed it in my skin. I am having the CPU issues I see posted all over this thread, and not sure how to correct it.
I set the Frame Rate at a very low 5 FPS for testing before I did anything else
When I start CoverJuke, it takes around 15 seconds for the window to appear. If I click on an album cover, it takes 11 seconds for the window with the song names to slide in from the left of the screen. Trying to use the slider is also very slow for me.
Does this have to scan the album covers every time it is started?
I am testing this on my desktop PC:
- Dual Core P4 2.8 Ghz
- 512 Meg Gfx card (GeForce 7900 GT)
- 4 gigs of ram
- Test folder with just 10 albums copied to it.
I am Running the latest 1.56 version from the Source Forge page. I am not sure if this uses flash in the BG, but if it does, I am using the latest flash 10 fully updated with IE and stand alone.
When I run coverjuke, I get around 80% CPU usage on one core and around 70% on the other one. So far all testing has been stand alone, and have not tried to embed it into RR yet. If I cant get it to use less CPU, there is no reason to do a skin for it, as it will never run on my poor little 2.2 Ghz CarPC
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 07-04-2009, 06:40 PM   #115
THE EXPERIMENTER
carputer1's Avatar
have a look in coverjuke.ini about 1/4 down
Use cache system for loading process
set to true if not this creates a txt file of your collection helping it load better
Old 07-09-2009, 05:54 PM   #116
l1nk's Avatar
l1nk is an unknown quantity at this point
Just installed coverjuke 1.56 and edited the exectbl.ini to replace the unnecessary cjembedder then replaced the old cjsend to have the buttons of skin working with this new version.
All seems to be ok: coverjuke embeds correctly and buttons works. No cpu issues at all.
But I noticed a difference between the 2 versions: with the previous version, when a cover was clicked, a screen with the tracklist (ilist enabled) was shown instead with this last version nothing happens when I click on a cover!! No tracklist is shown and nothing is played on winamp!! I'm sure I lost some configuration bit but don't know where
Edit: Even if I click on ENTER key nothing happens but help screen (F1) says that ENTER plays current album...
l1nk is offline   Reply With Quote
Old 07-09-2009, 05:58 PM   #117
do u have coverjuke set-up to send commands to covers.exe?
Old 07-09-2009, 06:09 PM   #118
l1nk's Avatar
I'm not sure I've understood your question... Please try to explain me!!
Old 07-09-2009, 06:16 PM   #119
in coverjuke config, you need to add the system path to the covers.exe script tothe "Path to external player audio" under the system parameter tab. Do u have the covers.exe script?
Old 07-09-2009, 06:31 PM   #120
l1nk's Avatar
Issue solved! Thank you ws6vert
As you correctly noticed, I forgot to set the "cover.exe" path in "Path to external player audio" and instead I've set the winamp path!
Switching between RR and copilot CombatCQB Road Runner 13 01-26-2009 06:27 PM
RR Black screen of death? maxxell Road Runner 7 12-17-2008 10:23 PM
RR Interchange - Update RR via a USB Media Stick Gobby Road Runner 60 10-04-2005 05:48 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
Bruno Speech Recognition with RR? ruairi Road Runner 12 05-03-2005 01:20 PM
