Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 02-25-2009, 08:06 PM   #1
ws6vert is an unknown quantity at this point
CoverFlow + RR = Coverjuke
Coverjuke 1.54
Coverjuke 1.54 has been released and now embeds perfectly within RR. For that reason, I have removed the download for the coverjuke embedder script. I will attach updated files that will embed coverjuke.
-Accolades go to El Camino for his Cover.exe script, and Valerhu for the skin files that I modified and are supplied for this. All sources are included.
Sceenshots:
Old screenshots:
http://www.mp3car.com/vbulletin/1291590-post50.html
Last edited by ws6vert; 04-06-2009 at 05:50 PM.. Reason: Coverjuke 1.54 released!!
ws6vert is online now   Reply With Quote
Old 02-25-2009, 08:10 PM   #2
[Reserved]
Old 02-26-2009, 11:09 AM   #3
toxic000 is an unknown quantity at this point
Sample Picture
This is the Coverjuke in my Skin. No Buttons needed, because next/prev & play goes in the Screen:
toxic000 is offline   Reply With Quote
Old 02-26-2009, 08:08 PM   #4
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
When you go to the site, this is the file to download and install:
Setup_coverJuke_v1.53_audio.exe
There are a few other choices which makes it a little confusing.
treetop777 is online now   Reply With Quote
Old 02-26-2009, 08:39 PM   #5
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
For some reason, I can't get the config to run. Will download the binary and try that.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 02-26-2009, 08:50 PM   #6
are you getting an error or a blank config screen? If it is a blank config screen, then you need to change the properties and have it open in Windows 2000 Compatibility Mode
Old 02-26-2009, 09:05 PM   #7
Raw Wave
treetop777's Avatar
Same here. Will try the compatibility mode.
Old 02-26-2009, 09:08 PM   #8
Raw Wave
treetop777's Avatar
Yep, it poped right up in compatibility mode.
Old 02-26-2009, 09:27 PM   #9
Yeh, this its a bug, the creator knows about it. If using in vista, there is no problem, only in XP.
I will add instructions to the ReadMe for this issue.
Has anyone had a chance to see my thread on OSKTOCMD in skins forum? I can't figure it out.
Old 02-26-2009, 10:37 PM   #10
GizmoQ's Avatar
Old 02-26-2009, 10:51 PM   #11
docbreezy's Avatar
docbreezy is an unknown quantity at this point
When you figure the OSKTOCMD out, i would like to know about it. I had to make an alternate OSK menu with the SKIPTO command to browse through the letters.
On a Different Note, where does CoverJuke get the album artist from? Is it from the tag or from the folder ? I get the album title but not the artists. My aldbums a setup MUSIC\ALBUM and is not organized by artist
NEVER BLEND IN!!!
docbreezy is offline   Reply With Quote
Old 02-26-2009, 11:40 PM   #12
Coverjuke gets the information from the folder titles. I have mine set-up with genre's so it displays the genre in what would normally be the Album text area, and then displays Album - Artist for the album text area. (See Pic)
Old 02-26-2009, 11:48 PM   #13
Doc, did you confirm the GOTOALBUM did not work? Can you try running it with RR Skin Tool to see if it works then? Thats the mystery problem im having. I can get the command to work fine in RR Skin Tool, but when having it assigned to a button in RR, nothing happens.
Old 02-27-2009, 12:53 AM   #14
docbreezy's Avatar
I figured as much. I'm going to have to re-work my music folders when i have the time.
As far as search goes, no dice. Getting this working would be nice. Takes me a while to get lower down my list since i dont use the scroll bar. Even so, it's so much fun scrolling, its still my defaauld cover browser.
NEVER BLEND IN!!!
Old 02-27-2009, 12:59 AM   #15
You can quick scroll 10 albums at a time with these button commands:
Jump Right 10 albums, "RUN;$pluginspath$CJSend.exe|{PGDN}"
Jump Left 10 albums, "RUN;$pluginspath$CJSend.exe|{PGUP}"
May make jumping around your library a little quicker.
I'm still searching for a solution to the OSK thing.
Switching between RR and copilot CombatCQB Road Runner 13 01-26-2009 06:27 PM
RR Black screen of death? maxxell Road Runner 7 12-17-2008 10:23 PM
RR Interchange - Update RR via a USB Media Stick Gobby Road Runner 60 10-04-2005 05:48 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
Bruno Speech Recognition with RR? ruairi Road Runner 12 05-03-2005 01:20 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
