Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 04-15-2009, 12:36 AM   #1
pcpete's Avatar
pcpete is on a distinguished road
CoverMess 0720 - Bug fix update
CoverMess 0720
BugFix Update 0720
- Fixed most sizing issues where flip button would not appear, still needs improvement
- Fixed double song entries on backcover
This happened if useid3=1 in rr.ini. Works fine now and showextensions flag in rr.ini will also be honored...
- RR 07/01 changed (fixed) the way it responded to fscommand("GETDL","");
This version supports both the newer and older versions ( for now )...
- Changed default in albums.txt for songmenubutimage=none.jpg so that no bubble will occur
- Changed default zoomspeed=2 in albums.txt for faster animation
***BE CAREFULL NOT TO OVER WRITE YOUR ALBUMS.TXT, AS YOU WILL LOSE ALL YOUR CUSTOM SETTINGS***
0714 Update
-Now supports custom text and text settings for all buttons
0710 Major Update!!!!
-This version now only has one mode!!! XML mode is gone
-This version is easier to configure and has less pre-requisites
-You can flip the covers and select song(s) individually
-All list are ilist style, ie throw lists
-CM will display folders with no cover art
Introduction
CoverMess ( CM ) is a GUI for selecting and playing digital audio files on a windows PC. It is writen in actionscript 2.0 v8, and requires the
carpc front end 'Ride Runner' ( RR ) to operate. It will NOT work without RR.
Below is a screenshot of CM running in RR...
The covers can be moved around, double clicking zooms them in and allows for furter actions, such as playing the audio files that are
associated with that cover.
CM displays a user configurable amount of covers at a time, in this case I've configured it for 25 max. CM spreads the total amount
of covers between a series of pages. This can be seen in my screenshot near the bottom left, in the green box.
The covers are sorted alphabetcally by artist name. You can move from page to page using the arrows or select a specific page from the
'Alpha Selection' menu.
You can filter the albums by using the 'Genre' menu. This menu is created dynamically from your file structure - requirements explained
below.
You can further filter by artist by using the "Selected Artist" menu. This way you can isolate all of an artists albums on the screen easily.
CM can load covers from a txt file, that is user selectable.
Mine is called paths.txt...here is a sample part of it...
LSTc:\testmusic\Music\Classic Rock-Metal\- Various -\folder.jpg
LSTc:\testmusic\Music\Pop-New Wave\- Various -\folder.jpg
LSTc:\testmusic\Music\Classic Rock-Metal\10,000 Maniacs\folder.jpg
LSTc:\testmusic\Music\Classic Rock-Metal\10cc\folder.jpg
LSTc:\testmusic\Music\Classic Rock-Metal\38 Special\folder.jpg
LSTc:\testmusic\Music\Pop-New Wave\A Flock Of Seagulls\folder.jpg
LSTc:\testmusic\Music\Pop-New Wave\A Ha\folder.jpg
LSTc:\testmusic\Music\Pop-New Wave\ABC\folder.jpg
LSTc:\testmusic\Music\Classic Rock-Metal\ACDC\folder.jpg
LSTc:\testmusic\Music\Pop-New Wave\Adam Ant\folder.jpg
LSTc:\testmusic\Music\Classic Rock-Metal\Aerosmith\folder.jpg
LSTc:\testmusic\Music\Classic Rock-Metal\Air Supply\folder.jpg
This file is automatically created in your skin path by CM and RR.
CM searches your RR musicpath for audiofiles, and then asks RR to create a custom list of folders pointing to cover art.
If you do not have cover art, CM will substitute with a default cover , user specified, and if that does not exist it will fallback to a blank white cover.
You do not have to and should not specify jpg in your audiofiles rr.ini anymore.
So now CM can operate without any coverart! It will display all your folders, regardless.
The included cm_readme.txt contains detailed configuration info and examples.
Enjoy, and Good Luck!!! Feedback , praise and bugs reports are welcome!
P.S. The flash animation is opensource, I've just modified it to display cd covers and integrate with RR..
A link to the original source and to other cool flash viewers is in my skin thread here..post #27
http://www.mp3car.com/vbulletin/rr-s...26-09-a-2.html
pcpete is offline   Reply With Quote
Old 04-15-2009, 02:00 AM   #2
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
great start pete works very well and low cpu have not fully added yet just tryed it showing the covers as i'm off to work this morning running late due to this lol...
i'm no flash coder but i had a idea to put past you .
if i can create a xml file of my whole music folder, is it possiable to and ABCDE etc at the top or bottom of the flash file or even a button to show a ABCD screen and on press it shows the albums of the same letter.
ie hit N = all albums in xml starting with N shown
hit B = all albums in xml starting with B shown and so on
just a thought great start
ENJOY
carputer1 is offline   Reply With Quote
Old 04-15-2009, 09:17 AM   #3
Iceman_jkh is on a distinguished road
Idea: A Shuffle button - Randomly shuffles the album covers.
Looks good.
So when are you adding the same thing for Videos... cept also each album/postcard plays a realtime preview of the video and can be dragged in realtime on the screen ?
Iceman_jkh is offline   Reply With Quote
Old 04-15-2009, 10:57 AM   #4
pcpete's Avatar
Looks good.
Shuffle button - good idea, will do...
as for the video , hmmm, let's see um...
Oh, I made a small update to CD Mess, just a bug fix...
Old 04-15-2009, 12:59 PM   #5
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
very very nice work, another alternative to browse by cover.
EL CAMINO is offline   Reply With Quote
Old 04-16-2009, 12:22 AM   #6
pcpete's Avatar
ENJOY
Sorry, overlooked this! Yes this should be doable.. I'm planning on adding more RR integration..
The main thing I want is to dynamically search for albums as opposed to using only xml files...so if you are in audio_browser skin and select CD Mess it searches the current highlited folder ( and subfolders ) for any folder.jpg files and dynamically builds a list of albums...
I'm also planning to implement that rotate button to flip the cd and display the back cover....
I'm open to any other ideas...
Old 04-16-2009, 12:23 AM   #7
pcpete's Avatar
Thx man, glad you like it...
Old 04-16-2009, 02:07 PM   #8
pafftis is an unknown quantity at this point
good work!
640x480 no size flash!!
RUSSIA - WINER!!!
pafftis is offline   Reply With Quote
Old 04-16-2009, 03:45 PM   #9
pcpete's Avatar
glad you like it, not sure what you r saying though......
Old 04-16-2009, 03:59 PM   #10
THE EXPERIMENTER
carputer1's Avatar
i think what he is saying is the app dose not resize very well , if you have it full screen its fine but if you have it smaller , when you double tap a cover the cover gets focus but its zoomed in to much , as you can see from my img below the album title is cut off.
if i make the app area (F,XX,XX,XX,XX) bigger its fine , making this a resizable problem. well thats what i think he means anyway , i have tryed alot of different res's
Old 04-16-2009, 04:10 PM   #11
pcpete's Avatar
ah, actually i've just changed this behavior in the source, should be uploading tonight
Old 04-16-2009, 04:12 PM   #12
THE EXPERIMENTER
carputer1's Avatar
great can you make it so its more scattered on start, the covers are too bunched up at mo.
Old 04-16-2009, 05:51 PM   #13
pcpete's Avatar
Ok, added small update, should resize now...
Old 04-16-2009, 11:10 PM   #14
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
THis works awesome... As expected..
ThunderStick is offline   Reply With Quote
Old 04-16-2009, 11:11 PM   #15
One Sharp Cheddar
One request... The buttons are kind of hard to see when overlayed on top of the cover art sometimes. Is it possible to add a little more contrast and possibly make them bigger.
Intel D945GCLF2 Dual-Core Atom txspazz General Hardware Discussion 643 11-15-2009 09:39 PM
FlashFlex 2nd test release 03/26/09 pcpete RR Skins 54 07-06-2009 08:08 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
How do you flash without Floppy or CD? marc456 Software & Software Development 11 01-23-2007 07:14 PM
Help! WRX2001 PhoneControl 3 01-25-2005 04:50 PM
