Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 05-08-2009, 04:45 PM   #1
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
TAGTITLE, TAGARTIST - Question
is there a way to change the data in this label, from an Extention plugin? i tried to set different data and the result was, "TAGTITLE data and NEW DATA" so in other words, if TAGTITLE use to show "BLACK", then in my plugin i want "TAGTITLE" to show "KASHMIR" what RR is showing is both at the same time. "BLACKKASHMIR", i can change indicators but not this labels. so if is possible i can use some help here,by the way i'm using vb 6.0 in a very basic plugin (RRTube).
EL CAMINO is offline   Reply With Quote
Old 05-08-2009, 04:51 PM   #2
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
very simple.. here's how i change "trackname" for rrshoutcast.
Code:
Public Function ReturnLabel(ByVal LBL As String, ByVal FMT As String) As String Select Case LCase(LBL) Case "trackname" If ShoutcastStatus = "Tuned" Then ReturnLabel = RRShoutcastTrackName End If End Select End Function
This code preserves the TRACKNAME label unless my plugin is "Tuned". And RRShoutcastTrackName is of course a variable set by a timer function. TAGARTIST,TAGNAME, and any other label can be modified from an extension plugin in the same manner
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 05-08-2009, 04:56 PM   #3
EL CAMINO's Avatar
Code:
Case "tagtitle" If Playing Then ReturnLabel = PlayingVid
if i use this code it wont work, dont know why. all i get is the results i mention before.
Old 05-09-2009, 10:25 AM   #4
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Try this:
Code:
Case "tagtitle" If Playing Then ReturnLabel = PlayingVid: LBL = ""
Basically, you should be careful when overriding label/command codes so that you prevent further processing of the label/command by RR and/or other plugins running. For this, all you have to do is empty the label/command code so nothing else processes it (like above). In the case of sonic, it is possible that it isn't an issue if the trackname was blank.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 05-09-2009, 07:03 PM   #5
EL CAMINO's Avatar
will try that, thanks guino.
heavy-duty OBD standards support question Michael2006 Engine Management, OBD-II, Engine Diagnostics, etc. 0 01-07-2007 05:13 AM
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 06:15 PM
Forum Etiquette Enforcer Newbie 5 01-09-2006 06:58 PM
Paint And Polish Question gboy Fabrication 8 08-13-2005 08:22 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 10:03 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
