Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 06-22-2009, 11:37 AM   #1
Serfio is an unknown quantity at this point
Execute command from my plugin only into a screen
Hello,
I'm developping a plugin...
My plugin have a timer which every 6 seconds calls a method to
update a custom list
I would execute the function only if the user is viewing the
screen where the custom list is located.
How I could obtain this?
Serfio is offline   Reply With Quote
Old 06-22-2009, 01:55 PM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
The first RR SDK example made shows you how to retrieve the current screen in RR -- basically you just read the "RRSCREEN" label code (i.e. RRSDK.GetInfo("RRSCREEN"). You can use this info to check if you're really on the desired screen before doing anything else.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 06-23-2009, 05:08 AM   #3
ok, I have found this workround...I thought that there was a way to enable or disable the plugin
I thought at sometinghs like: LOAD;MySkin.skin||ENABLE;MyPlugin
I wouldn't hard code the name of the skin if it is possible...
thanks
Old 06-23-2009, 12:13 PM   #4
guino's Avatar
Hard coding the name of the skin tends to keep skins cleaner in general, but if you don't want to do that, you can certainly make a command in your plugin to do what you want -- there's no limitation in that regards when making extension plugins.
.net Bluetooth Mobilephone Plugin lambosprit RR Released Plugins 614 11-19-2009 05:34 PM
RRTMS - RoadRunner tire monitoring system extension plugin Robby BMW RR Released Plugins 145 10-17-2009 03:31 PM
Asus Eee Box carpc in a Mazdaspeed 6 pixelgazer Show off your project 14 08-20-2009 09:41 PM
ASRR plugin: advanced support RoadRunner niko73 RR Released Plugins 21 06-28-2009 02:29 PM
Playing full screen video only to rear screen yossisibi Centrafuse 3 10-29-2006 07:06 AM
