O.K. Here are my findings:
Weather - yes, reloadweather does use the GPS data if the above conditions are met.
RRGAS - thanks Enforcer for your suggestion. I am using your exact code, i.e, the following,
"GAS","BYVAR;GASFIRST;RRGAS||RRGAS_GPS||SETVAR;GAS FIRST;1<<RRGAS"
Unfortunately, I am having some issues with RRGas 1.6 that I need your help with.
1. I have added an RRGAS slider on top of the RRGAS_UPDATED label, and I also have a pop-up that stays onscreen that says "Loading Gas Prices". The problem is if I use the RRGAS_GPS button commands none of the above give me any indication that anything is happening and the RRGAS_UPDATED label never changes. If I use RRGAS_ZIPCODE, neither the pop-up nor the slider do anything; the only way I know its updated is the label, RRGAS_UPDATED, eventually does change when the operation is complete. I guess part of what I'm asking is "does RRGASSEARCHING and RRGASDONE fire when using the RRGAS_ZIPCODE and RRGAS_GPS button commands?" I know it does for RRGAS_REFRESH.
2. Does the RRGAS_GPS button command update the RRGAS_ZIPCODE label? (mine doesn't)
3. RRGAS_#_fdnavigate does switch my skin to the GPS screen, but does not set the route. (I am using your personal edition of FD. Is there something in the FD or RR ini that I should check, I know I don't have all the send/recieve stuff turned on)
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
