Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 10-22-2009, 01:09 AM   #1
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
GPS-Based internet data
Before the changes in RideRunner, I had weather and gas screens that would automatically load data based on GPS location when the screens were initially opened.
How do I restore that functionality with the latest version of RideRunner? What should the RRCode look like or is it even possible anymore? If so, how can I refine it so it automatically loads based on GPS location the first time I run it , yet just show the exising data on subsequent returns to this screen?
Can the dev team add a command to the weather plugin called GPSWEATHER? The docs don't show a command nor explain if an existing command performs a GPS-based data download/display.
I know RRGas has a command, rrgas_gps, and I've figured out how to achieve the above, but a response from Enforcer with his suggestion for the RRCode to use would be appreciated.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 10-22-2009, 08:19 AM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Looking at the new code/plugin it should be exactly the same as before, meaning, just have zips.dat available (so RR knows your current Zip code from the GPS data) and set the localdatacaptureinterval setting accordingly, the weather plugin will read that and auto-update in that interval whenever there's a GPS lock.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 10-22-2009, 09:44 AM   #3
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
you might want to check the RR source guino i believe someone has broken the gps location stuff. Hasnt worked in a few months for me. I just figured it was scrapped so that someone could do it via plugin
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 10-22-2009, 07:41 PM   #4
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
I thought I remembered this being scrapped, by whom I cant remember. But it had something to do with the zip.dat file and ziplocator.? file something or other. It was adding a lot of confusion. Anyway, just a memmory I think I had.
maybe Im wrong, who knows...
This was an awesome feature that has been lost for sometime now though.
ThunderStick is offline   Reply With Quote
Old 10-22-2009, 07:57 PM   #5
guino's Avatar
Blue separated the weather plugin, but zips.dat support is still in the core, and the weather plugin seems to have all the code ready for it.. I'll have to try it out to see then.
Old 10-23-2009, 12:54 AM   #6
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
How about the Exectlb code that used to work, might help in narrowing down either the issue or what you may need to modify to get it working again.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-23-2009, 09:40 PM   #7
GizmoQ's Avatar
If J remember correctly, I believe the RELOADWEATHER command was run after the screen loaded and thats it. Now the reload doesn't do it anymore.
Old 11-02-2009, 03:01 PM   #8
The Curator
Blue ZX3's Avatar
When I was working in the weather PI last night... I did look and yes the "RELOADWEATHER" cmd looks to see if you have an valid gps AND your locate city lbl contains something and if both true then uses that info otherwise defaults to cityweather setting. If I remember correctly, I didn't change any of that part was just a cut N paste into the PI.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-02-2009, 04:11 PM   #9
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Sorry missed this.
What exactly do you want to do?
Enforcer is online now   Reply With Quote
Old 11-02-2009, 04:20 PM   #10
The Curator
Blue ZX3's Avatar
Its a weather question not a gas one.... look n read first...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-02-2009, 04:29 PM   #11
Confusion Master
Enforcer's Avatar
Then why is gas mentioned twice in the OP, plus my name against a request?
So why don't you actually try understanding what you read before making comment.
Old 11-02-2009, 05:58 PM   #12
The Curator
Blue ZX3's Avatar
He was using it as an example...duh. Asking if there was a similar cmd for weather PI now
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-02-2009, 09:18 PM   #13
GizmoQ's Avatar
The OP was for both.
I will change my weather code back to RELOADWEATHER and verify.
I am curious what the developer of RRGAS would suggest as code to put in the exectbl.ini to get RRGAS to load the gas.skin and pull the internet data immediately for the current GPS location.
Thanks Blue for looking into the weather PI and Enforcer I await your reply.
Old 11-02-2009, 10:19 PM   #14
Confusion Master
Enforcer's Avatar
Try this
"GAS","BYVAR;GASFIRST;RRGAS||RRGAS_GPS||SETVAR;GAS FIRST;1<<RRGAS"
note: no space in GASFIRST
and add to ONRESUME
"SETVAR;GASFIRST;0"
and to ONSKINSTART (if required)
"SETVAR;GASFIRST;0"
and Blue
Old 11-03-2009, 10:39 PM   #15
GizmoQ's Avatar
Quote: Originally Posted by Enforcer View Post
Try this
and add to ONRESUME
"SETVAR;GASFIRST;0"
"SETVAR;GASFIRST;0"
Well I was close. Didn't think to use a variable that way. Thanx
and Blue
Renault "Tuner List" Head Unit/CD changer hacking - Controls Vicne Hardware Development 790 08-19-2009 02:55 PM
IG4 Crash-Reboot with GPS data bmac67 GPS 1 02-05-2008 02:01 PM
Feature Request: Auto check for gps data Sonicxtacy02 WhereIsMyGPS Online Tracking 3 07-31-2006 07:50 PM
