Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
View Poll Results: Should the radioSHARK support be native in RR?
Yes 68 95.77%
No 3 4.23%
Voters: 71. You may not vote on this poll
Old 09-21-2006, 07:05 PM   #151
Evolution VIII's Avatar
Evolution VIII is an unknown quantity at this point
Quote: Originally Posted by spjuenger View Post
Are you guys getting good reception from your radioShark? I don't seem to get anything around the STL area.
You have to use external antenna.
Evolution VIII is offline   Reply With Quote
Old 09-22-2006, 11:04 AM   #152
xs10x's Avatar
xs10x is an unknown quantity at this point
Sofar tested on beta machine and works great. Modifying Alpine skin for record feature.
Can't seem to get the AM part working or the indicator (REC) for recording. Recording status works great.
`¨`¨`¨`¨` _____||¯.\__
.:.:.:.:.:.:;!_(o)______(o)'i
TruckputerX - Vortech SuperCharger Vid
TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
xs10x is offline   Reply With Quote
Old 09-23-2006, 01:32 PM   #153
Exclamation Your feedback is required.
Is it no one using RadioSHARK or everybody is just too lazy to post a feedback? People it is very simple: Without your feedback it will be no official RoadRunner release that includes native RadioSHARK support!
Please leave you feedback.
Old 09-23-2006, 05:49 PM   #154
xs10x's Avatar
Sofar everything seems to work great. The only issue I have is trying to switch from AM-FM. I assign a button with the code: "Radioband" and it does not seem to switch to AM. The recording part works great but can't get the indicator to show "REC" next to the "Radiostatus". I modified the "ON" radio skin with the REC and assigned a indicator with the code: "radiorecord".
Does the old commands work? are there any more new commands?
I also removed all the old settings from the ExecTLB.ini. deleted the radioshark.ini, radioshark skin files , radiosharkplugin, changed the :"RADIOSHARK","AM FM Radio" to "Radio,""
I love the fact that I can Add / Delete and Modify preset stations.
Old 09-23-2006, 06:39 PM   #155
Did you mean from "RADIOSHARK","AM FM Radio" to "DADIO", "AM FM Radio" ?
Please download the executable again, you may have downloaded before I switch the commands.
You can also use standard RR "FMAM" indicator. For AM/FM abd MHz and KHz indications.
The old commands works on the plugin only.
Here are the new skin commands:
BUTTONS
"RADIORECORD" - Start/Stop radio recording
"RADIOVOL+" - Adjust radioSHARK volume up
"RADIOVOL-" - Adjust radioSHARK volume down
"RADIOBAND" - Change AM/FM
"RADIOMUTE" - mute radioSHARK
INDICATORS
"RADIOMUTE" - Indicates if radioSHARK is Muted
"RADIORECORD" - Indicates if RadioSHARK is currently recording
LABELS
"RADIOVOLUME" -shows radioSHARK volume
"RADIOSTATUS" -Shows RadioSHARK status/recording status
Old 09-24-2006, 07:43 AM   #156
xs10x's Avatar
yes, "RADIOSHARK","AM FM Radio" to "RADIO", "AM FM Radio"
Going to redownload the executable and test this afternoon.
Old 09-25-2006, 06:47 AM   #157
xs10x's Avatar
Ok , I redownloaded the rr.exe and now I have everything working as well as the radioshark volume and "Rec" indicator. The only issue I have left is switching from AM to FM. I have assigned a button for this, with the code "RadioBand" and nothing happens when I press it.
Old 09-25-2006, 08:50 AM   #158
Sorry, I had the typo in the button code. Please download it again.
However, you don’t even need to use this button as RadioSHARK will automatically switch to AM/FM base on frequency.
Old 09-25-2006, 09:31 AM   #159
xs10x's Avatar
Done Downloading. Tested on test machine and seems to switch from FM to AM. Going to test in my ride soon...
Old 09-25-2006, 11:07 AM   #160
xs10x's Avatar
Here is a pic from my alpine radio skin.
Everything works:
Tune, record, Am-FM switching, Mute, Function - to edit modify or delete presets
*AM / FM indicators still do not work
Old 09-25-2006, 03:33 PM   #161
Everything works:
AM / FM is an existing RR indicator previously used for HQCT, the code is "FMAM". You must create add "AM" on picture_OF and "FM" on picture_ON. Same for "MHz" and "KHz".
Old 09-25-2006, 03:54 PM   #162
xs10x's Avatar
Dude you lost me. on the picture_on and picture_off.
Details or example.
Old 09-25-2006, 05:14 PM   #163
Details or example.
LOL.
“FMAM” indicator works exactly as “mute”, “radiomute”, “radiorecord” etc. or any other RR indicators.
radio_player_ON.jpg must have FM and MHz
AND
radio_player_OFF.jpg must have AM and KHz.
add one indicator with "FMAM" code over "FM" part of the image and another with "FMAM" code over "MHz" part of the image
Old 09-25-2006, 05:18 PM   #164
xs10x's Avatar
Got yaa. Will try later on. You just lost me with the picture_on stuff.
Just stick with the simple ON OFF and Down skins. LOL
Old 09-25-2006, 05:21 PM   #165
xs10x's Avatar
Hey Evo,
What are the chances in the future to have the other features of Radioshark like timeshift etc.
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
radioShark am/fm usb adapter with timeshifting kickerks80 Car Audio 13 10-04-2004 05:08 PM
Help with winXP/hibernate/LCD plugin dave123456 Software & Software Development 0 10-17-2002 09:17 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 06:10 PM
