Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
View Poll Results: Should the radioSHARK support be native in RR?
Yes 68 95.77%
No 3 4.23%
Voters: 71. You may not vote on this poll
Old 02-17-2006, 02:52 PM   #16
cartdan is on a distinguished road
CDRskull - Any chance of getting the skin you did for the radioshark? I was trying to come up with something myself that looked good with MC2.0 when I stumbled on your post here...
- Dan
cartdan is offline   Reply With Quote
Old 02-17-2006, 05:15 PM   #17
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
not played with it much.. about 5 mins, so might be missing a few functions.
HERE
CdR
CdRsKuLL is offline   Reply With Quote
Old 02-17-2006, 05:36 PM   #18
Thanks CDRSkull! Looks a lot better than what I was working on...
- Dan
Old 02-17-2006, 11:46 PM   #19
Evolution VIII's Avatar
Evolution VIII is an unknown quantity at this point
Quote: Originally Posted by CdRsKuLL
Did a quick skin to match MC2.0 today and installed it in the car, found the best results for the aerial was to solder the inside of the car aerial to the fm aerial point on the board and the neg to the point above it (opposite side to the am aerial)
I noticed that the plugin takes it skin from the rr.ini file, and not from the resume.ini file if its there, which might confuse some peeps. Will the source be available for the plugin ?
cheers
CdR
Thanks for suggestion. I will check for "resume.ini" in next release.
Evolution VIII is offline   Reply With Quote
Old 02-18-2006, 08:07 PM   #20
xs10x's Avatar
xs10x is an unknown quantity at this point
I still can't get it to sound. The plugin shows the skin but no sound or channels.
Am I doing something wrong? I removed the "N N" gap also.
Does the path have to be c:\roadrunner for it to work? I have mine under c:\program files\roadrunner
I have in my ExecTBL.ini :
/, Set Below the Path to Radioshark plugin (if used)
"RADIOSHARK","PLUGIN;RRRadioSharkPlugin;C:\Pro gram Files\Road Runner\radioSharkPlugin\radioSharkPlugin.exe"
Can someone post a menu.skin of the tuner part
`¨`¨`¨`¨` _____||¯.\__
.:.:.:.:.:.:;!_(o)______(o)'i
TruckputerX - Vortech SuperCharger Vid
TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
xs10x is offline   Reply With Quote
Old 02-19-2006, 04:45 AM   #21
TheKingPlaza is on a distinguished road
Do you get sound before patching radioShark? It seems i'm missng some setting here.. driving me nuts! I can't get sound!!
TheKingPlaza is offline   Reply With Quote
Old 02-19-2006, 12:41 PM   #22
Looks like radioSharkPath is not correct.
Make sure you can start radhioSHARK.exe by it self without the plug-in. The patched exe should work as stand-alone providing all radioSHARK functionality.
Make sure the “radioSharkPath” entry in the radioShark.ini (the file you drop in your RoadRunner installation folder) is the actual path of your executable.
# path of the radioShark executable
radioSharkPath=C:\Program Files\Griffin Technology\radioSHARK\radioSHARK.exe
Old 02-19-2006, 12:54 PM   #23
Thanks.. got it running now!
Radioshark has to be connected by audio cable also (I thought it would be usb only) which was not mentioned in the guide. annyhow.. It seems to work now! audio comes from line-in. Is there anyway to pause winamp and unmute line-in while starting and visa versa while closing? I read something about this in the FAQ but not quiet sure how to configure..
Old 02-19-2006, 04:15 PM   #24
FreeDrive Creator
CdRsKuLL's Avatar
Mine is connected via usb only.. First I just got it working with the software on the cd that came with it, once I got sound and got a couple of radio channels I then set about installing this kewl plugin.
btw.. I soldered the car aerial adapter.. with the + going to where the original fm aerial went, and the - to the point above it..
ie..
o - neg on aerial
o - pos on aerial
o - am
o - am
0 - spare
think thats right.. I got the best signal by using these points, unsure if there correct or not but I'm happy
Another thing I noticed is the failer of the plugin to pull the correct format from the ini files for labels.. ie format of time. I know this isnt anything to do with your coding, but this has stopped me release a picture viewer plugin.. maybe guino could take a look
CdR
Old 02-19-2006, 04:30 PM   #25
ie..
o - neg on aerial
o - pos on aerial
o - am
o - am
0 - spare
Here's a picture of the board, I'm in the middle of doing the same thing...
CDRSkull - How's the AM reception in the car with the standard radioshark antenna?
- Dan
Old 02-20-2006, 12:22 PM   #26
xs10x's Avatar
I have mine workingthrough USB also. But it does not work once i launch the plugin. What am I doing wrong? can someone post the exectbl and menu.skin part.
Old 02-20-2006, 02:13 PM   #27
ExecTBL.ini
Code:
"RADIOSHARK","PLUGIN;RRRadioSharkPlugin;C:\Program Files\Road Runner\radioSharkPlugin\radioSharkPlugin.exe"
button..
Code:
B,540,0,130,80,"RADIOSHARK", "AM FM Radio"
Old 02-20-2006, 10:22 PM   #28
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
I'm posting this plugin in RR's sites, I was just wondering if you plan to make the sources available at some point in time (even if after you don't want to make any more changes to it).. I only ask in case later on, if/after you loose interest in working on it, that other people could make improvements/tweaks as they see fit. But it's very nice to see a plugin done from the "basic" plugin interface .. Plus, this seems to be one of the best options for USB radio right now.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 02-21-2006, 01:08 AM   #29
I will release the source code after I done developing. I still have few ideas left. It would be nice to integrate radioSHARK into RR.
Old 02-21-2006, 02:22 AM   #30
FreeDrive Creator
CdRsKuLL's Avatar
yeah I would love that :-)
CdR
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
radioShark am/fm usb adapter with timeshifting kickerks80 Car Audio 13 10-04-2004 05:08 PM
Help with winXP/hibernate/LCD plugin dave123456 Software & Software Development 0 10-17-2002 09:17 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 06:10 PM
