Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
View Poll Results: Should the radioSHARK support be native in RR?
Yes 68 95.77%
No 3 4.23%
Voters: 71. You may not vote on this poll
Old 04-08-2006, 06:46 PM   #61
mnmis is on a distinguished road
I just purchased a RadioShark and I am trying to get the plugin to work.
I went through the readme and made sure all of the paths are corrent but I cannot get the plugin to work.
The screens come up and the radiosharkplugin starts but the radioshark exe doesn't.
The radioshark.exe was patched and works standalone.
Any ideas on why it doesn't work?
mnmis is offline   Reply With Quote
Old 04-17-2006, 03:13 PM   #62
fury is on a distinguished road
I too am having some difficulties with it. When I start the radioshark plugin from RoadRunner, it starts the radio app up, and I can click on the buttons programmed into the skin, but the plugin does not hide the app from view, and does not accept the key commands I have programmed into RoadRunner. (WASD instead of the arrows)
Any ideas?
Is there an SDK document that you used to make this plugin? Would you mind sharing with us, in case we just want to write our own module for it? If possible it'd be nice if I don't even have to start radioShark.exe.
Thanks Great work on this, BTW, and I agree on the integration into RR point... would be perfect
fury is offline   Reply With Quote
Old 04-19-2006, 09:33 AM   #63
Evolution VIII's Avatar
Evolution VIII is an unknown quantity at this point
Check the path again. Copy the radioSHARK.exe path and go to: Start > Run. Paste the copied path and hit the OK button.
Evolution VIII is offline   Reply With Quote
Old 04-19-2006, 09:46 AM   #64
Any ideas?
1. Try to use the skin downloaded with the plugin. If it does work then you did not programmed your buttons correctly. Instead making new skin from scratch, try to modify existing skin.
2. Patched radioSHARK.exe will not accept KEY commands you programmed previously. You have to choose between plugin and KEY commands
3. In the next release I will fix the problem. It will hide the radioSHARK screen.
Old 04-19-2006, 09:48 AM   #65
Quote: Originally Posted by more mods
When the source is released we should be able to get it modified to have list support (like everything else in road runner) instead of all those extra preset buttons. There's just no way to add all those extra buttons to my skins and have them large enough to be useable and still look nice. I honestly don't understand why it was done that way.
I'm working on the list support for the plugin.
Old 04-19-2006, 01:24 PM   #66
Evolution,
I have checked the path and it is correct.
One question I have is the radioShark.ini file. Should it be in c:\Program Files\Road Runner folder or c:\Program Files\Road Runner\radiosharkplugin folder?
I am thinking that the plugin cannot find the ini file. I tried it with the ini file in both places and it still failed.
Is there any way to debug this?
mnmis
Old 04-19-2006, 08:31 PM   #67
Evolution,
mnmis
It should be in Road Runner instalation folder.
Old 04-20-2006, 07:33 AM   #68
I installed the plugin on to a different computer and it worked.
I guess I have to figure out why the first one fails.
Thanks for your help.
Old 04-20-2006, 02:10 PM   #69
Winni is on a distinguished road
Works good!
Thanks for your great work.
But how did you manage to get audio over usb?
I have no audio in oportunity in my car
Winni is offline   Reply With Quote
Old 04-20-2006, 05:38 PM   #70
toddwess's Avatar
toddwess is on a distinguished road
I have tripple checked all my settings. They all match the readme.txt file.
I click on my radio button, and the new skin comes up, but no frequency, or sound or anything.
If I run the plugin as a standalone (after the true/false change), again, the skin comes up but no sound
If I run radioSHARK all by itself (either patched or unpatched) it comes right up.
Perhaps I need to re-install Road Runner. . .
HELP! Did I just waste 75 bucks?
Todd
toddwess is offline   Reply With Quote
Old 04-21-2006, 08:44 AM   #71
toddwess's Avatar
Do I need to make any changes to the rrconfig.exe file in the "Radio" section?? I wish I knew why this wasn't working for me . . .
Old 04-21-2006, 10:13 AM   #72
toddwess's Avatar
Okay more weirdness . . .
I installed Road Runner and radioSHARK and the plugin on a different computer (the desktop at work) which is running windows 2000 server and guess what.
Works perfectly.
Then I copied the entire Griffin Folder and Road Runner Folder from the desktop, and copied it to the machine that I can't get it to run on . . . and guess what . . .
Nothing. Still won't run. The skin comes up, but no dice.
So, it appears to be a hardware thing. Are there any dll tips or anything I should check to make the plugin run? DirectX? .NET framework?
Thanks!
Todd
Old 04-21-2006, 01:07 PM   #73
I fixed my problem last night by reinstalling the operating system.
The big Fdisk cures alot.
Hopefully it stays that way.
mnmis
Old 05-05-2006, 06:55 AM   #74
genesis66 is on a distinguished road
I have troubles understanding how the preset are used. Is there a way to save a preset with the current frequency on the fly or do you have to put it by hand in the radioshark.ini file???
Any news if the sources will be released and when??
genesis66 is offline   Reply With Quote
Old 05-19-2006, 02:48 PM   #75
xs10x's Avatar
xs10x is an unknown quantity at this point
Any new changes to the plugin?
`¨`¨`¨`¨` _____||¯.\__
.:.:.:.:.:.:;!_(o)______(o)'i
TruckputerX - Vortech SuperCharger Vid
TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
xs10x is offline   Reply With Quote
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
radioShark am/fm usb adapter with timeshifting kickerks80 Car Audio 13 10-04-2004 05:08 PM
Help with winXP/hibernate/LCD plugin dave123456 Software & Software Development 0 10-17-2002 09:17 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 06:10 PM
