View Poll Results: Should the radioSHARK support be native in RR?
Yes
68 |
95.77% |
No
3 |
4.23% |
06-04-2006, 11:08 PM
#91
Quote: Originally Posted by Evolution VIII
RADIO_REC_STATUS = RadioSHARK recording status (it can record)
RADIO_MUTE = Displays word "Mute" when you mute "radioSHARK" (mute indicator is for RR and if you noticed you have mute button to mute radioSHARK)
RADIO_REC = Displays word "Record"
I understand that it records, but what does RADIO_REC_STATUS actually display? I need to know so that my label width is large enough. My guess is that it displays how long it has been recording (00:00:00).
I did notice the mute button was for radioshark, I am just curious why you included the RR mute indicator. It's no big deal, I don't plan to remove the mute indicator anyway, I am just curious.
Thanks,
more mods
It's the cake having/eating thing.
06-05-2006, 07:06 AM
#92
Hey moremods,
I will be your tester. Let me know when its ready to go.
`¨`¨`¨`¨` _____||¯.\__
.:.:.:.:.:.:;!_(o)______(o)'i
TruckputerX - Vortech SuperCharger Vid
TruckputerX Progress Bar [ |||||||||-] 90% Complete [It's never 100% done]
06-06-2006, 01:50 PM
#93
work this plugin with Leadtek TV2000 Expert?
06-08-2006, 12:21 PM
#94
Master Yoda,
work this program not with Leadtek TV2000 Expert
Did you actually read from the beginning of this thread? It's clearly explains that this is RR plugin for radioSHARK hardware.
06-08-2006, 12:42 PM
#95
I read bad this topis.....
i write there, because i only see plugin and the read radio...i´m so unhappy because i bought TV2000 Expert and it don´t work with RR...
my fault
06-14-2006, 08:57 AM
#96
Have anyone tried the new version of the radioSHARK plugin?
06-14-2006, 09:54 AM
#97
I must of missed that there was a new version.
I will test it in the next few days, time permitting.
Anything you want me to look at?
mnmis
06-14-2006, 11:32 AM
#98
I tried it but it tells me unable to find the skin path.
06-15-2006, 08:16 AM
#99
I have reloaded only the radiosharkplugin v1 back into the folder and it works.
v1.01 gives me path not found for the skin.
06-15-2006, 09:41 AM
#100
Funny, I gave it the 30 second test stand alone and it worked for me.
I did create my own skin but that shouldn't matter.
06-18-2006, 01:30 PM
#101
Skin Problem????
I am able to run the RadioShark exe by itself. I have followed the ReadMe.txt and have removed the space between the "n n". I am now getting this error when I click the RADIO button on 2 different skins:
Steel Blues Skin: Error: 76, Path not found: 'C:\program Files\roadrunner\skins\Steel Blues\'
BM2 Skin: Error: 76, Path not found: 'C:\program files\roadrunner\skins\BMV2\'
I have checked every ini and skin file I can think of but the paths are all correct.
Could someone please HELP.
Thanks,
Tonysch
Hardware: VIA-SP13000, M2-ATX, Voom case, HQCT, Linksys WiFi, Bluetooth, 512MB, 80GB, Dynamix 706.
Software: XP Pro (stripped), Drivers only, Road Runner, CentriFuse, EzSync
99% done... [never completely finished... a continuing hobby]
06-19-2006, 09:51 AM
#102
Quote: Originally Posted by tonysch
Skin Problem????
Thanks,
Tonysch
Same problem here. Load the older plugin and it works.
06-19-2006, 10:23 AM
#103
xs10x- Thanks for the responce.
Evolution VIII- Could You supply me with the older plugin? Your link is only for the 1.0.1 version.
TIA
06-19-2006, 11:51 AM
#104
TIA
Just copy this the the radiosharkplugin path
RadioSHARK Plug-in for RoadRunner v.1.0.0
DESCRIPTION:
Controls following functionality of the radioSHARK:
1. Change band (AM/FM).
2. Start/Stop recording.
3. Mute.
4. Fine tune frequency.
5. Seek.
6. Separate radioSHARK and main volume controls
7. Unlimited radio stations preset with radio station names.
NEW FUNCTIONALITY IN v1.0.0
1) Pause music or video if is it currently playing in RR when showing plugin screen.
2) Return to the previous RR screen without closing the plugin. The radio will continue playing. Just change the “EXIT” to “BACK_TO_RR” command in your radioshark_player.skin
3) Mute radio if music or video start playing in RR and un-mute when returning to radio plugin.
4) Resume music or video when returning to audio_player or video_player screens.
5) Close previous instance of radioSHAK.exe
06-19-2006, 01:02 PM
#105
XS10X
Thank you very much. Works very well.
| Thread Tools |
| Display Modes |
Linear Mode
