Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
View Poll Results: Should the radioSHARK support be native in RR?
Yes 68 95.77%
No 3 4.23%
Voters: 71. You may not vote on this poll
Old 02-07-2006, 02:12 PM   #1
Evolution VIII's Avatar
Evolution VIII is an unknown quantity at this point
Exclamation radioSHARK Plugin for RoadRunner
RadioSHARK Plug-in for RoadRunner v.1.0.2 released! 09/01/2006
Please read this thread if you'd like to run your RadioSHARK natively in RR without using any plugins with the standard radio_player.skin included with RR.
DESCRIPTION:
Controls following functionality of the radioSHARK:
1. Change band (AM/FM).
2. Start/Stop recording.
3. Mute.
4. Fine tune frequency.
5. Seek.
6. Separate radioSHARK and main volume controls
7. Unlimited radio stations preset with radio station names as buttons or scrollable list.
8. Direct tune (numosk)
9. Add new preset
LINK TO DOWNLOAD:
Version 1.0.2 (included working skin)
Version 1.0.1
Version 1.0.0
WORKING SKIN: (this version will not work with the skin included in the 1.0.0 or 1.0.1 zip files)
Download here
* If you still want to use your old skin and the plugin is not working (error: No valid skin found.) you must do the following:
1. Ither remove referense to the slider from your skin
S01,277,493,247,25,277,493,247,25,H,01,"",0,"MASTE R",""
OR
1. Make sure that the reference to slider and slider file path are present in the skin
Y01,"SLIDER_VOLUME\slider_*.gif"
2. Make sure that the slider file path (folder) and slider images are exists in your skin folder.
3. Make sure you edit the RadioShark.ini to have the correct paths to your volume sliders, and pointer.
NEW FUNCTIONALITY IN v1.0.2
1) "TUNE" command will load your "numosk.skin". You can enter a frequency and hit [enter]. It will tune radioSHARK to that frequency.
2) "ADDPRESET" command will load your "osk.skin". You can enter the preset name and hit [enter]. It will create new preset with current frequency and name that you entered.
3) On the startup plug-in should detect last preset that was used and display appropriate preset name and number.
BUG FIXES IN v1.0.2
1. You will no longer see "touchlist" if you don't have it on your skin.(it was sometimes visible).
NEW FUNCTIONALITY IN v1.0.1
1) Scrollable list support. (You can display your radio station presets in the scrollable list instead of the buttons)
2) Slider support.
NEW FUNCTIONALITY IN v1.0.0
1) Pause music or video if is it currently playing in RR when showing plugin screen.
2) Return to the previous RR screen without closing the plugin. The radio will continue playing. Just change the “EXIT” to “BACK_TO_RR” command in your radioshark_player.skin
3) Mute radio if music or video start playing in RR and un-mute when returning to radio plugin.
4) Resume music or video when returning to audio_player or video_player screens.
5) Close previous instance of radioSHAK.exe
INSTALLATION INSTRUCTIONS:
1. Make sure you have radioSHARK USB Radio Client v1.1.7.0 or later installed on your computer.
* The software that comes with the radio Shark on the CD is outdated. To download new software please visit http://www.griffintechnology.com/support/radioshark/
2. Copy “radioSHARKPatch.exe” into radioSHARK installation folder (e.g., “C:\Program Files\Griffin Technology\radioSHARK\”) and run
to patch radioSHARK.exe
3. Copy “radioShark.ini” file and "radioSHARKPlugin" folder into your RoadRunner installation folder (e.g., “C:\RoadRunner\”)
4. Copy content from the “SKIN” folder into your current RoadRunner skin folder (e.g.,“C:\RoadRunner\SKINS\LSX\” and/or "C:\RoadRunner\SKINS\BMV2\", etc...).
5. Open “radioShark.ini” file and make sure that the path of the radioSHARK executable is correct (e.g., “radioSharkPath=C:\Program Files\Griffin Technology\radioSHARK\radioSHARK.exe”).
6. Add the following line into Roadrunners’ ExecTLB.ini file:
"RADIOSHARK","PLUGIN;RRRadioSharkPlugin;C:\RoadRun ner\radioSharkPlugin\radioSharkPlugin.exe"
7. Modify the tuner button command in the "menu.skin" file to:"RADIOSHARK","AM FM Radio".
8. To run pluging as standalone application you must set: standalone=true in radioShark.ini (not used in version 1.0.2).
* Make sure you have valid wait.skin file in you favorite skin folder. The RoadRunner will not load any plugins without it.
You are done!
Last edited by Evolution VIII; 09-24-2006 at 11:56 AM.. Reason: new version released
Evolution VIII is offline   Reply With Quote
Advertisement Sponsored links
Old 02-08-2006, 03:51 PM   #2
travphel's Avatar
travphel is on a distinguished road
Looking good! I've tested it on one of my machines and it works like a champ. However, I can't get it to work on the MMI Skin. Other then that it looks great! I'm actually thinking about installing my RadioShark now because there's finally a good solution for RR w/ the RadioShark
Great work and thanks a million!
Quote:
DAYNA: Don't you ever get bored of being right?
AVON: No, just with the rest of you being wrong.
Current Project: 2004 Subaru WRX Waggon
Planning Phase: [*********-] 100%
Get Parts Phase: [**********] 100%
Installation Phase: Done
travphel is offline   Reply With Quote
Old 02-08-2006, 11:53 PM   #3
MMI missing "wait.skin" file. The wait.skin is requred by RoadRunner to load plug-in.
1. Create text file in your SKINS/MMI/ folder.
2. Add following text (do not include “---------------------------------”):
MEDIACAR Skin
MEDIACAR wait skin
END
3. Rename it to wait.skin
That’s all.
Old 02-09-2006, 01:00 PM   #4
travphel's Avatar
Perfect! Now all I have to do is create a skin that will match the skin I'm using RR and I'll be done. I'll continue testing and let you know of any issues.
Old 02-10-2006, 08:35 PM   #5
xs10x's Avatar
xs10x is an unknown quantity at this point
Hey I can't seem to get it to work.
I am using the BMV2 Skin. Followed the instructions but cant get it to play.
`¨`¨`¨`¨` _____||¯.\__
.:.:.:.:.:.:;!_(o)______(o)'i
TruckputerX - Vortech SuperCharger Vid
TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
xs10x is offline   Reply With Quote
Old 02-11-2006, 03:35 PM   #6
It is not clear what you mean "can’t get it to play". Please be more specific. Does RoadRunner loading plug-in? What do you see on the screen after plug-in is loaded?
Old 02-13-2006, 01:30 PM   #7
cartdan is on a distinguished road
Talking
I had the same problem (it wouldn't work, just said "LOADING" and never came back). Turns out that in the line of text I had copied from the readme.txt in the installation package, there was an extra space in one of the paths that you copy to the Exec TLB.ini file. Remove the space between the 2 "n"s in Roadrunner. and that fixed it for me.
Working great now, Thanks a million Evolution III!!!!!!
- Dan
cartdan is offline   Reply With Quote
Old 02-14-2006, 02:22 PM   #8
xs10x's Avatar
Tried the "n" fix. Need to try again once I finish installing my Carputer in the truck.
Old 02-15-2006, 04:26 PM   #9
DaPCWiz is on a distinguished road
this is awesome. I will try this soon!
DaPCWiz is offline   Reply With Quote
Old 02-15-2006, 04:39 PM   #10
TheKingPlaza is on a distinguished road
is this the same...or just for mac?
http://www.macstuff.nl/product_info.php?products_id=740
TheKingPlaza is offline   Reply With Quote
Old 02-16-2006, 12:32 AM   #11
Yes, this is the same radioSHARK hardware as you would use for a MAC. However, the plug-in is for RoadRunner and MS Windows only.
Old 02-16-2006, 02:45 PM   #12
thanks.. I'm gonna test it tomorrow
Old 02-16-2006, 05:35 PM   #13
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
Got mine in the post today.. going to stick it in a new box tomorrow and attach a car aerial. I will code a skin for MC2.0 soon as I get a free hour.. Just tried this plugin.. works great very impressed with it, just crossing my fingers that it works as good in the car (the radio not your plugin)
thanks again m8
CdR
CdRsKuLL is offline   Reply With Quote
Old 02-17-2006, 09:06 AM   #14
feeling kinda stupid.. Installed radioshark today.
Everything works wel except.. no sound :s
I do get sound while recording with "C:\WINDOWS\system32\sndrec32.exe" using radioshark. But this way I can only record sound.
Must be some kind of setting but I just can't get it running. plugin seems to work well! any ideas please?
Old 02-17-2006, 01:20 PM   #15
FreeDrive Creator
CdRsKuLL's Avatar
Did a quick skin to match MC2.0 today and installed it in the car, found the best results for the aerial was to solder the inside of the car aerial to the fm aerial point on the board and the neg to the point above it (opposite side to the am aerial)
I noticed that the plugin takes it skin from the rr.ini file, and not from the resume.ini file if its there, which might confuse some peeps. Will the source be available for the plugin ?
cheers
CdR
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
radioShark am/fm usb adapter with timeshifting kickerks80 Car Audio 13 10-04-2004 05:08 PM
Help with winXP/hibernate/LCD plugin dave123456 Software & Software Development 0 10-17-2002 09:17 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 06:10 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
