Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 05-12-2006, 10:42 AM   #151
pyros's Avatar
pyros is on a distinguished road
Quote: Originally Posted by b8bboi
Yes I can but my purpose was not to interfere with iGuidance at all. Maybe there'll be a spinoff version of IGmon that does that.
The nag screen is pretty simple to get rid of. It is just a registry key. I have a simple windows shell script (.vbs) taking care of it for me, along with setting my gps port (for some reason iguidance never seems to remember it!), then loads iguidance:
IGLoader.vbs:
Code:
Set WshShell = WScript.CreateObject("WScript.Shell") WshShell.RegWrite "HKEY_USERS\Software\iNav\iGuidance\ShowWarning", 0, "REG_DWORD" WshShell.RegWrite "HKEY_USERS\Software\iNav\iGuidance\CommPort", c, "REG_DWORD" WshShell.CurrentDirectory = "C:\Program Files\iNav\iGuidance\" WshShell.Run "iGuidance.exe"
2004 Ford Mustang Mach 1
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
pyros is offline   Reply With Quote
Old 05-12-2006, 10:47 AM   #152
camsgs3 is on a distinguished road
wow this thread got big quick...
those who are running iglaunch\skinbedder, how do i get ride of all the icons from that app...like the zoom\3d,menu
I would like just to get rid of the nag screen and to get the full map in view w/o toolbars and status bar
b8bboi thanks again..this app is great
camsgs3 is offline   Reply With Quote
Old 05-12-2006, 10:50 AM   #153
cMags's Avatar
cMags is on a distinguished road
IGLoader.vbs:
Code:
Are you talking about the warning screen that tells you not to use iG while driving? If so, there's a switch (with most modern versions, 2.0+ IIRC) that you can call on the commandline... Just open iG with "iguidance.exe nowarning"
No hacking, no registry, simple.
CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
cMags is offline   Reply With Quote
Old 05-12-2006, 10:53 AM   #154
yep that works just as good
http://www.mp3car.com/vbulletin/rr-skins/75006-ig-nag-screen-embed-issues-fix-how.html
Old 05-12-2006, 11:10 AM   #155
cMags's Avatar
You know, every time I see your SN camsgs3, I think it's my own post for a second... Especially since if I can't use cMags I use cMags613... It makes me feel a tittle lysdexic...
Old 05-12-2006, 11:11 AM   #156
pyros's Avatar
Problem is I still need to set my gps port which is in the registry also. I guess I could add the nowarning to the part where it loads iguidance.exe instead of the registry key.. thanks!
My XM FAQ
Old 05-12-2006, 11:59 AM   #157
b8bboi is on a distinguished road
Anyone on the East Coast who's driving to an airport area, please save the log (File -> Record Track) then post it back here. There's one more color value I need to get for DirectionBoxColor.
b8bboi is offline   Reply With Quote
Old 05-12-2006, 12:35 PM   #158
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
I cant get auto zoom to work. I just switched to skinbedder so i wouldn't have monkey around with the ini. I turned on the debug mode and the grey box is right over the zoom area and it appears to be polling but the zoom but the level never changes. I went through each line of the INI file to see if i could see somethign that was wrong and nothing looked out of place. I tried the aggresive and regular modebut didn't get anywhere and of course i exited out and restarted igmon after each change. Do you have any ideas?
On another note. This works really good. The pause mode for the voice is really really good, this is what i have been waiting for. I have a question for you though, is there a way to make it not pause for the "ding" its really annoying. I can handle it pauseing for the speech but the pausing and unpausing really fast is aggrivating.
I really like the OSK it is finally more functional. Thank you so much for this Top notch app.
Also antialieasing would be a great option for us with p4 or similar machines for a future version
antimatter is offline   Reply With Quote
Old 05-12-2006, 12:39 PM   #159
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
its different depending on which app ur using
IgLaunch has no buttons in it
igskinner has buttons.. but has a function in the .ini to hide them
for skinbedder (and igmod) i just replaced all the icons in the skin with 1x1 white bmp's. They dont show up on the screen.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 05-12-2006, 12:53 PM   #160
Auto Zoom is kinda hit or miss. Works for some. Doesn't for others.
I will release a tool for you to check why it doesn't work.
The "ding" issue will be addressed in a later release. It annoys me, too.
Old 05-12-2006, 12:57 PM   #161
pyros's Avatar
[*]Pausing RR when iGuidance is giving directions. You can also lower Winamp volume instead.
I haven't had a chance to test this app yet.. but it sounds like what I've been dreaming of.
One request though, would it be possible to have the option with the above to lower the line in volume, then restore it to what it was? I use an external XM app that doesn't use the winamp line in plugin, so this wont work for it. Just an idea, if not, no big deal. Once my XM app plugin for RR is done, it should be able to handle this..
Thanks,
Chris
My XM FAQ
Old 05-12-2006, 12:57 PM   #162
cMags's Avatar
I'll be going to Logan in Boston on Sunday morning, so I can record that track. How much of it do you need? Just enough that I'm recording before I get into the airport area shown on the map?
Also, do you need iGMon running during the track? Or is plain-old iG good enough?
And finally, can someone email a copy of the beta 1.1 install to cmagnell at gmail dot com? My work firewall blocks the download. Thanks!
Old 05-12-2006, 01:05 PM   #163
Terminal flasher
Thanks,
Chris
Quote:
Also I've set mine up to lower the winamp volume and restore it after giving directions. So much better, in my opinion, than pausing and resume. It seemed a little too harsh to cutoff the music like that. So instead of PAUSE and RESUME in the ini file, I used "exec SETVOL;winamp;30 and SETVOL;winamp;100 respectively.
... canadians
J/K
03 Acura RSX Coupe
Old 05-12-2006, 01:07 PM   #164
pyros's Avatar
Quote: Originally Posted by Sonicxtacy02
... canadians
J/K
I don't understand... the XM app doesn't use winamp.. and I cant have it lower the master volume or else it will lower everything so i need just to lower the line in volume..
...americans
j/k
My XM FAQ
Old 05-12-2006, 01:18 PM   #165
Terminal flasher
...americans
j/k
which line does xm use? just substitute winamp with whatever line it is.
03 Acura RSX Coupe
iGuidance NATIVE in Road Runner skippy76 Road Runner 218 05-01-2007 02:10 AM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 01:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 07:21 PM
Does Iguidance embed w/ Road Runner? J187 GPS 5 05-25-2005 07:38 PM
Road Runner sceen for iguidance Kalt RR Skins 20 05-16-2005 12:42 PM
