05-10-2006, 10:28 AM
#46
Quote: Originally Posted by tj!2k4
If you are interested in making it compatible with more FEs, I think it would just require some of your features' actions to be able to be mapped to configurable hotkey combinations.
I don't know if you'd be able to make all features available for other FEs, but for instance one of the major features, the pausing of music during directions, could be accomplished by sending a "Ctrl-Alt-P" (default play/pause command in Centrafuse)..
I will definitely look into that later.
RR is convenient because it has a command line utility that you can use to send a command directly. There's no need for key shortcuts.
05-10-2006, 10:31 AM
#47
Quote: Originally Posted by Sonicxtacy02
can we use the ACTIVATE; command with your app for sendkeys? I prefer to have no buttons on the iguidance screen and set them up thru the skin. Igskinner couldnt use this if i recall correctly.
Yes and actually it's even easier than that. All you need is have your RR button do a SENDMSG command to iGMon kinda like this.
"SendMSG;iGMonitoring;ZoomIn"
There'll be tons of custom commands available.
05-10-2006, 10:41 AM
#48
Wow great work just the way I would like ig to work can't wait to try your app
05-10-2006, 10:44 AM
#49
Terminal flasher
beautiful.. i cant WAIT for this to be released!
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
05-10-2006, 10:51 AM
#50
Banned
Where can I get a serial port splitter?
05-10-2006, 11:10 AM
#51
 the Forum for XPort3
05-10-2006, 11:13 AM
#52
b8bboi, is that popup window skinnable and can it popup at any screen,like the shot below?
05-10-2006, 11:35 AM
#53
MGD, the popup is not skinnable right now. Might be in a later version. However, I don't think it'll work exactly how you want it. iGMon can parse and save the next turn street in memory. It can also save the next turn arrow on a GIF file so you can display back in RR. However, it cannot monitor the distance to next turn. I tried to find the memory address where IG saves this but it kept jumping around.
05-10-2006, 11:41 AM
#54
Thats good enough, she tells you the distance anyway. Good Job on this one.
05-10-2006, 12:01 PM
#55
It would be really great if the top toolbar (file tools view) can be gone to.
It's just extra space for your maps that you lose.
By2Way - It looks great
I would love to test it with iguidance 2.1.2 europe
05-10-2006, 12:02 PM
#56
it already can be done using IGskinner
05-10-2006, 01:29 PM
#57
Jesus Freak
Nice work. That is the skin and the front end i use. I cant wait for this. This is really good news.
Can you explain how the sound muting works. I use SPDIF alot so i wonder how your program effects it. The video looks really good. Very close to what i want. The only thing i could add too it is the skinnable popup with the addition of the turn direction and have it not lower the volume of the music for the ding...just the spoken directions.
05-10-2006, 02:08 PM
#58
WIN98SE support? PLEASE
Thanks!
Otherwise looks great.
05-10-2006, 02:32 PM
#59
This is a pretty simple trick. iGuidance sets the Wave volume to a certain level when it speaks. My app only monitors that. If the Wave volume drops somewhere below that level, it'll pause RR. Of course, the side effect is if another app also lowers the Wave volume, iGMon will mistaken that. So the trick is set IG volume to somewhere around 40% and make sure all your other apps don't do this.
This will probably be in a future release.
05-10-2006, 04:09 PM
#60
Cant Wait
ok ok ok..... download please..... getting IG just because of this thread.. cant wait!!!
woo hooo
96 cobra
suspension: MM CC plates, H&R super sport, bilsteins, steeda:bump steer kit, X2's, moly SFC's, triax shifter. MGW handle, cobra knob. Audio:RUX-C701, PXA-H701, MRV-F545, MRD-M1005, SIR-SC-H1, DMHD1000, Polk/Momo MMC6500, MM2104
| Thread Tools |
| Display Modes |
Linear Mode
