Features that work with 2.1.3:
enter new address via OSK skin
Picking Favorites
Turn Popups
Auto switch to GPS screen when iguidance is talking
Thats all I tested so far, just drove around the block ;p
LSX VOID MOD <------ use this to allow IGMon to work with the void skin
Those of you who want to use this with LSX VOID, here are the files I modified to make it usable, it gives you audio control when in fullscreen GPS (at the cost of removing the flash speedo) and is fully compatible with igmon
replace the following files (note, this is set for 800 X 600 only)
The coords.ini replaces the coords.ini in LSTOOLS\SB2.9\IGUIDANCE\
The .skin files, and the ExecTBL.ini should overwrite the Skins\LSXvoid\ files of the same name
Just unzip the attached file and overwrite as decribed above
Hope that helps
