Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Old 05-11-2006, 02:47 PM   #106
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i'm hoping that the version later thats works with skinbedder will also work with iglaunch
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 05-11-2006, 03:24 PM   #107
b8bboi is on a distinguished road
Why do you use iGLaunch? What's the benefits?
b8bboi is offline   Reply With Quote
Old 05-11-2006, 03:37 PM   #108
SkinBedder users, download Beta 1.1 in the first post.
Download everything and run the Wizard again.
For LSX Void users, when the Wizard asks you what app to run when switching GPS, use "GPS" instead of "EXTERNAL" as in
Code:
exec.exe GPS
Old 05-11-2006, 03:38 PM   #109
Terminal flasher
two pics .. first without iglaunch second with
03 Acura RSX Coupe
Old 05-11-2006, 03:42 PM   #110
Then use iGSkinner. It also removes the file menu bar and everything. It's a later version of IGLaunch. They were both written by leelo.
BTW, in the screenshots, I wasn't using iGSkinner. It was the original version of iGuidance.
Old 05-11-2006, 03:42 PM   #111
MGD
MGD's Avatar
MGD is on a distinguished road
IGLaunch removes all borders and toolbars. You get an intgrated look.
MGD is online now   Reply With Quote
Old 05-11-2006, 03:46 PM   #112
Here's where you can download iGSkinner.
http://www.mp3car.com/vbulletin/show...ight=iGSKinner
Old 05-11-2006, 03:59 PM   #113
Quote: Originally Posted by Sonicxtacy02
Noticed that too.
Ok i did more testing and with the settings and exe you gave me it did zoom down to 100ft when i changed the simulator to 15mph from 60, but it didnt do anything from there. No matter if i went slower or faster it stayed at 100ft. Everything else but this is working just fine now when plain ole iguidance is loaded in (w/o iglaunch igskinner n all that)
Btw my iguidance is in day mode in that screenshot, though i had to put the day/night setting in igmon at 1 else it wouldnt autozoom at all
Does Guidance screen switching work with regular iGuidance? I think iGLaunch was messing with it.
As for Auto Zoom, can you do this for me? Take a screen shot when iGuidance is running. Open it in Photoshop or something. Cut the part where the Zoom Level shows and save it as a GIF. Then post it back here. I'm suspecting they were using a different font back then that throws off my OCR code.
I'll code up a debugging version later so you can test.
Old 05-11-2006, 04:07 PM   #114
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Whats the point of running IGskinner when your using the Justintime button mod. All we want is to launch and click the warning button and strip down everything except the map view. IG skinner is a little overkill and last time i checked a bit buggy
antimatter is offline   Reply With Quote
Old 05-11-2006, 04:14 PM   #115
Terminal flasher
i got the beta 1.1 and autozoom is now working!
Screen switching i really cant test with the simulator. Im on my way home in 40 mins and will fool around with it there. In all honestly screen switching is of least importance to me though.. i'm only testing it for bugs for others. As long as that popup shows on every screen i can live without the switching.
And yes i agree that igskinner is overkill. It doesnt quite embed correctly, but i tested igmod with igskinner embedded and its working so i might HAVE to switch from iglaunch
Once the popup is skinnable this will be exactly what you intended it to be .. the all in one solution
03 Acura RSX Coupe
Old 05-11-2006, 04:20 PM   #116
Terminal flasher
screen switching IS working now with beta 1.1
I swear i'm not post-whoring lol
03 Acura RSX Coupe
Old 05-11-2006, 04:22 PM   #117
I use iGSkinner in my car all the time. Not buggy at all. It's the same thing as iGLaunch, ie. you use it to remove the Nag screen and strip everything but the Map view. That's the point.
Old 05-11-2006, 04:23 PM   #118
Great! See, please use what I use and save me the headache.
Old 05-11-2006, 04:34 PM   #119
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Wiredwrx has a little shameless behaviour in the past
O.K. All, Hopefully this isn't off topic. If it, I will remove it.
What skin are you guys using to send commands from the RR to IG.
I have heard mention of the LSX Void skin. Any others. I want something integrated. I am thinking about using JIT's Big Button Mod. Just want to use a skin that is as integrated as possible, has buttons that sends commands to the IG, and will make use of IGMon as well.
Michael
Wiredwrx is offline   Reply With Quote
Old 05-11-2006, 04:39 PM   #120
iGMon now should work with iGLaunch
I just tested out with iGLaunch and was able to get it working. Please try the following.
Download iGMon again (Beta 1.1)
Run the Wizard.
When it asks you to Start RR and switch to GPS blah blah blah, just do Cancel.
Open iGMon.ini and change
iGuidanceWindowName =iGLaunch
IGHeightOffset =0
You won't be able to use the latter part of the Wizard so just read iGMon.ini and edit things manually.
Should work now. All these different versions of iGuidance, iGSkinner, iGLaunch are driving me nuts.
The next person asks that I get iGMon to work with iGMod, I'll go postal on your ***.
iGuidance NATIVE in Road Runner skippy76 Road Runner 218 05-01-2007 02:10 AM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 01:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 07:21 PM
Does Iguidance embed w/ Road Runner? J187 GPS 5 05-25-2005 07:38 PM
Road Runner sceen for iguidance Kalt RR Skins 20 05-16-2005 12:42 PM
