The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins
Thread Tools Display Modes
Old 07-13-2006, 02:03 PM   #1
leckan's Avatar
Vehicle: Skoda Octavia 2003
My Photos: (0)
Carweb 2.0 (now Out) (rrplugin)
Now you can download Carweb 2.0.
Work as a RR plugin (Easy to install)
Http://www.zinknet.se/ENG/
Carweb 2.0 NOW FOR DOWNLOADING
leckan is offline   Reply With Quote
Sponsored Links
Old 07-13-2006, 02:53 PM   #2
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (129)
i tried this. Your instructions did not get carweb running in rr. I added the exectbl.ini entry, added the button to my menu skin, and added the carweb folder to rrs folder, moved your skin to my skin folder.. and the button does nothing. Only way i got it to run was to use LOAD;wbrowser.skin;RRCARWEB;C:\Program Files\ROAD RUNNER\CARWEB\carweb.exe;RRCARWEB
and with that it runs on top of rr instead of in it. What does this do that the built it web browser doesnt? And i have a suggestion. You need the status bar, most of us dial up users with cell phones needa know if the page is loading or just sitting there.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 07-13-2006, 03:34 PM   #3
leckan's Avatar
My Photos: (0)
I have run it in my car for a week without problem you installit exatly same you install rrcdrip. the status bar dont work with the mozilla plugin that i use
what i know, i found out something.
put this in your execTBL.ini below the Rrcdrip text.
/, Set Bellow the Path to the web plugin (if used)
"CARWEB","PLUGIN;RRCARWEB;C:\Program Files\ROAD RUNNER\CARWEB\carweb.exe"
"QUIT","SendMsg;RRCARWEB;showplugin||bye"
"BYE","QUIT"
go to menu skin and put this code on the button you wanna use,
B07,348,335,102,75,"CARWEB","CARWEB"
if you use BMV2 or BAV2 else only change code to CARWEB
i attach the execTBL.ini , menu.skin
File Type: txt KeyTBL.ini.txt (872 Bytes, 101 views)
Old 07-13-2006, 04:49 PM   #4
leckan's Avatar
My Photos: (0)
Carweb automatic dail your default connection when you startit.
an disconnect when you close
Old 07-15-2006, 07:07 PM   #5
SMKFree
liquid_smoke's Avatar
Vehicle: VW Passat
My Photos: (0)
so far looks good, the install instructions are a little off though. You should design everything so there are no conflicts with any other files or settings in RR. Your "QUIT" command is already present in the ExecTBL.ini file and if you also have CDRIP enabled there will be issues, so you either have to manually combine the comands or you should create a unique command to use for carweb like
"QUITCARWEB","SendMsg;RRCARWEB;showplugin||bye "
also you should NOT overwrite any default skin files in RR, your plugin should use 100% of its own files so when you install it, it dosent break any default functions of RR, but yet adds onto.
The files that get overwritten are
wbrowser.skin
So if you install carweb and later decide you dont like it for whatever reason, you now have the issue of restoreing these files and may have to reinstall whatever skin you were using.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
USB 2.0 issues PLEASE HELP! Kamakazie2 General Hardware Discussion 25 10-23-2006 07:25 AM
WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc CavityCr33p Classified Archive 1 01-30-2006 05:57 PM
USB 1.0 vs USB 2.0? Worth upgrading in my case? SMOKINV8 General Hardware Discussion 3 10-17-2005 10:38 AM
IDE to USB 2.0 converter goosef350 General Hardware Discussion 8 08-11-2005 08:29 PM
2 questions about 2.0. jgme ME Archive 3 09-04-2003 03:42 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
