03-03-2007, 09:38 PM
#76
Quote: Originally Posted by DJiK
Ha! I said March, didn't I?
Yeah, you've got to watch what you say around here - we all have good memories.
03-13-2007, 02:32 PM
#77
Terminal flasher
thanks to the autoit coding skills of BlueZX3 i was able to skin the keyboard in this program in RR (or flash in this case). This screenie isnt complete as i havent got the backgrounds quite right or skinned the upper buttons but it shows that the space button is in its "pressed" state. It sends the letters the same way as if u were typing it on your keyboard.
Few questions....
can the background of your app be transparent so that whatevers behind it shows thru?
Is there any way to make it so that sending the key acts the same way as pressing a key on your skin (searches automatically instead of having to type the full keyword then pressing enter)
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
03-16-2007, 04:08 PM
#78
The Curator
Thanks for the reconition, I was wondering what you were going to use that for...as I didn't really ask
Glad I could be of help!
03-16-2007, 04:24 PM
#79
Terminal flasher
o prob.. it really works great too. Only current issue is the spacebar isnt working.. havent really tried to sort that out yet though. It works on notepad but not this application.
03 Acura RSX Coupe
04-03-2007, 08:37 AM
#80
It's awful quiet around here, DJiK. And what's this about you going to the lake over Spring Break? Next you'll be telling us that drinking beer and chasing women are more important that recoding the jump-to plugin. Priorities, man, priorities!
04-05-2007, 10:33 AM
#81
I am seeing a problem...I have installed RR and the DigitalFX skin. To my knowledge, I did not install your Jump-to-File plugin, but I am getting an interesting situation. I haven't figured out what I need to do, but JTF gets into a loop of popping up a message box that says:
Please be sure you're using the Classic Skin
I click OK, and it puts up another one. JTF keeps doing this until I kill it via task manager.
What does this mean...and how do I fix it?
04-06-2007, 08:37 AM
#82
DigitalFX comes bundled with the Jump to Plugin. If you installed DigitalFX using the installer, it will install the plugin automatically.
As for the error message, are you using Winamp with the classic skin rather than the modern skin? If not, you need to switch to the classic skin. This is a RR requirement and is not particular to the Jump to Plugin.
04-06-2007, 08:44 AM
#83
If I go into Winamp and select Skins, <Base Skin> is selected. The properties on the skin says: Winamp base skin v2.95.
I don't have anything entitled classic skin or the modern skin.
04-06-2007, 01:53 PM
#84
That is the skin my program is referring to.
Weird... Maybe you'd want to try switching to the latest Winamp version instead?
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
04-06-2007, 02:03 PM
#85
Terminal flasher
2.95 is not friendly with this plugin.. try 5.03. I've had no issues with it in the months i've been using this plugin.
03 Acura RSX Coupe
04-06-2007, 02:12 PM
#86
Huh...I only chose version 2.95 because it was indicated in the RR install readme. I will try 5.03.
Thanks!
04-07-2007, 07:54 PM
#87
The Curator
yea sonic, any progress on your ver?
04-08-2007, 08:39 AM
#88
Terminal flasher
havent messed with it honestly.. i use it daily and with the exception of the space bar not working its fine. I'll package it up and send a skin sample monday
03 Acura RSX Coupe
04-09-2007, 04:24 PM
#89
Works w/o issues on v5.13. Space bar works too.
04-09-2007, 04:30 PM
#90
Mine works without issues with Winamp Version 2.95. The only problem is that it doesn't always properly embed into RR, but that's not a Winamp issue. I've tried using 5.13 with RR and it causes me lockup problems. I don't know why. Version 2.95 is rock solid for me.
| Thread Tools |
| Display Modes |
Linear Mode
