07-23-2008, 07:56 PM
#16
All the other labels work ie charging / discharging etc.
Im using I,715,24,62,34,"powermon_gbattlevel"
The files are in my Road Runner\Powermon
and images are Road Runner\Powermon\Images
The battery indicator doesnt display
I'l have a play around when i'm back in the car, im prob missing something
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
07-23-2008, 10:18 PM
#17
dumb question but have you registered the new dll? rr isn't still using an old version?
07-24-2008, 07:13 PM
#18
Def not I re-registered the dll, and got the success message
CarPuter Progress:
08-06-2008, 06:58 PM
#19
Festy,
I added a 08 to the label, and that has cured it for some reason.
Was my skin that caused it.
Great plugin!
Im surprised theres no more comments from the other laptop users?
CarPuter Progress:
08-06-2008, 08:36 PM
#20
I'm lovin it.
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
08-06-2008, 08:58 PM
#21
Wants to make it harder
it seems any issues with this and other plugins are related to recent RR releases rather than the individual plugins. to test whether it's RR or the plug-in, remove all other X,plugin codes and if it works, it's RR, if it still doesn't, it's the plug-in.
There's talk amongst those who help code the source that this may be something since the 10/06 release, and it's being looked at. Soon there will be a new RR release and this will be fixed.
Also, the old powermon version had different labels than the new one which adds powermon_ to most of the labels.
08-07-2008, 02:41 PM
#22
Festy,
The only other thing that would complete this great plugin
Would be to add the ability to hibernate the machine after a set time limit (maybe read from an ini file) and ability to launch applications on resume (again from an ini file)
This would mean we wouldnt have to use shutdown software any more
Not sure if this is possible, but seen as the plugin already knows the power state anyway it seems do-able
CarPuter Progress:
08-20-2008, 02:10 PM
#23
Request: Change slider graphics to be relative to $skinpath$ folder instead of powermon folder to follow RR's standard slider conventions?
nLite'd XP Pro / RR v09/10/2008 / Winamp v5.13
08-20-2008, 09:03 PM
#24
I did it a little differently:
(.gifs above are only 10 of the 20 images each.)
I basically took the label for the charge percentage, stripped the percent sign, and evaluated that into a slider. For the charging symbol, I used the RRStrings plugin to evaluate the length of the label, if it's 8 (Charging) it displays a charge symbol, if it's 11 (Discharging) or anything else, it displays nothing. I did it this way so that I could use one set of images for the battery whether it were charging or not.
A normal indicator would be nice. A simple true/false kind of thing...
08-20-2008, 09:17 PM
#25
I did it the same way, as well, but it's rather round-a-bout. Took a look at the source code and looks to be a quick fix.
I just didn't like defining a TMR function to check batt states...
08-20-2008, 09:38 PM
#26
I know, with the timer, every interval, the skin has to perform the calculation, where it would be nice to have a normal slider (0-65535) that can be used without that round about manner, along with an indicator that can be used with byind rather than having to check the length of the label string.
| Thread Tools |
| Display Modes |
Linear Mode
