07-23-2008, 06:58 PM
#301
Quote: Originally Posted by Fama
Has anyone managed to have the IBUS work successfully on CENTRAFUSE?
i am in the mood to make a lil donation to anyone who has???
This should work fine with centrafuse (all the steering wheel controls)
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
07-23-2008, 06:59 PM
#302
"@SENDMSG;iBusRR;UNLOCK_DOORS@,"RELEASE"
This just activates my hazard warning lights, and iluminates my dash lights
Anyone else confirm it works/does the same?
CarPuter Progress:
08-01-2008, 05:29 PM
#303
IbusRR Rules...
WaRFiElD
Thanks for your development. IbusRR rules!
If possible, I would like to have one more info and send the reset to MID, as follows:
Info:
Consumption 2; and
Send:
the codes to reset the consumption1 and consumption2 to Zero.
I have my MID behind the my xenarc screen so all the buttons are not reachble.
Also, RANGE is not working for me. I have a E39/1996.
I know you are very busy. So when you have some spare time...
Thanks Again,
Zambz
08-06-2008, 03:53 PM
#304
For anyone interested im finishing an AIT script that will close and reload IbusRR after hibernation, its a simple exe that will cure the reload errors, and hibernation probs until WarField sorts the rest of the coding out
When iv'e confirmed its working OK il post it here...
CarPuter Progress:
08-07-2008, 12:45 PM
#305
Hi Guys,
I got problems and only one of you can solve.
I tried loading the software iBusRR v2.0.5 onto my carputer but this did not work. Is there something am missing or certain files i need to install first?
Please bare inmind i have never installed the ibus to my carputer. and this will be loaded onto a carputer running Centrafuse 2.0
Many thanx for your help
Fama
08-07-2008, 01:17 PM
#306
Confusion Master
iBusRR is a plugin for Road Runner, it won't work for Centrafuse.
08-07-2008, 04:13 PM
#307
Would anyone kindly point me in the right direction as i would wike ot use my abus with centrafuse and enjoy the features u guys are having on roadrunner...
08-07-2008, 04:17 PM
#308
Confusion Master
Best place would be here.
but not sure what has been done for CF yet.
09-07-2008, 01:30 PM
#309
I stumbled upon a new problem when using iBusRR in combination with an idle.skin.
I've been playing around with making an idle screen for my skin. So when RR isn't used for several seconds it should automaticly change to this idle.skin.
Now, this works as long as the car is in ACC. From the moment I turn the engine on the idle.skin won't show anymore. My guess is that iBusRR is sending information to RR preventing it from going idle.
Now I gave up in using the OBC info in RR since I don't have an OBC and the only information that can be displayed in RR on my car is irrelevant. So I'm now only using iBusRR for my steering wheel controls at the moment.
Is there a way to modify the iBusRR.ini file (or anything else) in such a way that only the steering wheel commands are send to RR and nothing else so RR can go idle after some time and my idle.skin can be loaded.
Thanks!
EDIT: Solved it. It seemed to be the Synctime that was causing it. Turned it off and now everything works fine. Didn't expect it to be this however. I thought the time was only syncronized when iBusRR was launched...?
BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
Bezel Worklog - My Install - My Website (Dutch)
Reason: Found solution
10-06-2008, 10:25 AM
#310
hi i have a problem:
when i switch on the light the gamma of monitor low only for a few second. why? can you help me (sorry for my english)
10-06-2008, 10:55 AM
#311
Steering wheel buttons...
Guys,
My Steering wheel does not have a R/T button, so I was wondering if I could use the buttons of cruise control when that is off (in my case most of time). With those buttons I would have at least 5 extra buttons to add features in RR.
Of course, when cruise control is on, the buttons would be off.
Thanks to all,
zambz
IBUSRR Rules!
10-06-2008, 11:08 AM
#312
Confusion Master
The cruise control buttons are not connected to the iBus, and in no way can be used if you have actually got cruise control connected.
The only way would be to not have cruise control connected (physically) and then use the buttons as just push buttons and have to make up your own circuit.
I would not recommend this route at all.
10-06-2008, 11:21 AM
#313
Changing Steering Wheel
Enforcer,
Do you think it would work if I change the steering wheel for one with R/T buttons, without adding any other cabling or circuits?
Thanks,
zambz
10-06-2008, 12:03 PM
#314
i solved my problem with a rr skin configuration. thanks a lot
10-08-2008, 01:46 PM
#315
i have a problem with the light sensor. when the key power is off, the gamma control get down the luminosity, but when the machine is turned on , the gamma control don't get down the monitor luminosity. why?
| Thread Tools |
| Display Modes |
Linear Mode
