Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 12-03-2007, 02:08 PM   #31
pwntbypat is an unknown quantity at this point
I was able to get it working, but as laposelemer is experienceing, the wifi manager loads up behind RR but doesn't show through, nor does it take the intended shape of the area box. all buttons work fine (except enable/disable - my fault though, screwed up my connection awareness and need to reinstall). My system doesn't hang however.
EDIT: It appears I'm having a problem with the new wireless.exe program - could be related to an issue I created earlier. The program won't stay open in the background. it launches then closes right away. Once RR is open and I run wireless.exe, the wifi manager resizes the wifi window and loads it in to RR but if I click any buttons in RR, the wifi window hides behind RR and I have to alt-tab to get it back. If I hit the wifi buttons "connect, refresh, etc" it's fine.
pwntbypat is offline   Reply With Quote
Old 12-03-2007, 05:26 PM   #32
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
Quote: Originally Posted by pwntbypat View Post
Sweet! thanks for the enable/disable feature. that kicks ***.
Okay, having issues again. replaced wifi_man and wireless.exe with updated versions, replaced exectbl line with new line and changed the exe location name (that's it). When I load the wireless skin, I get the wifi_man, but none of the buttons work and I don't get any "status" labels to show up.
I think the issue might be with devcon and the fact that the wireless card I have doesn't have a dev value. Under device id I have:
USB\VID_13B1&PID_000B\5&1DD5D721&0&1
the buttons dont work because the skins commands are different now, as you can see in the ExecTBL. ckeck the sample skin to see the difference. i did this because some people were having some issues with the "Wireless Connnection Manager" window(including johnWPB, DFX), so i change the window title to "Wifi Information". the only buttons that aren't included in the sample skin are enable/disable. but they do work. as long you get the dev number. dont know why the dev number is not listed in your card. is there any way you can test this with another card?
EL CAMINO is offline   Reply With Quote
Old 12-03-2007, 05:31 PM   #33
EL CAMINO's Avatar
are you sure is embeded?, can you please post your wireless.skin, your ExecTBl lines for this and paths for the exe's.
Old 12-04-2007, 12:22 AM   #34
I completely re-made my wireless.skin file and exectbl with the code provided in the new readme. The only thing I think I changed was $skinpath$wireless.exe to $skinpath$scripts\wireless.exe
all my files (wifi_man.exe, wireless.exe, and devcon.exe as well as wifi_man.ini) are located in:
C:\Program Files\Road Runner\skins\Shock v5.0\SCRIPTS\
exectbl
Code:
"WIRELESS","LOAD;wireless.skin;WIFI;;Wireless Network Connection||SETTOPMOST;RR;TRUE||RUNQW;$SKINPATH$scripts\wireless.exe||SETTOPMOST;RR;FALSE||ACTIVATE;Wireless Network Connection" "NEXT_WIFI","Activate;WiFi Information||SENDKEY;{DOWN}" "PREV_WIFI","Activate;WiFi Information||SENDKEY;{UP}" "REFRESH_WIFI","Activate;Wifi Information||SENDKEY;{F5}" "CONNECT_WIFI","Activate;Wifi Information||SENDKEY;%c" "DISCONNECT_WIFI","Activate;Wifi Information||SENDKEY;%d{ENTER}" "DISABLE_WIFI","SENDMSG;wifi_man;disable" "ENABLE_WIFI","SENDMSG;wifi_man;enable"
to call wireless skin/app
Code:
/DEFINE B10_FUNCTION "WIRELESS"
skin.ini
Code:
MEDIACAR Skin MEDIACAR wireless Skin Wifi_menu_off.png,wifi_menu_off.png,wifi_menu_on.png,wifi_menu_off.png INC,settings.txt /, A, x, y, w, h, color;RGB A,228,92,508,225,000,, L,698,3,100,45,#TOPBAR_RED#,#TOPBAR_GREEN#,#TOPBAR_BLUE#,#TOPBAR_SIZE#,#FONT#,#BUTTON1#,"CENTER" L,584,3,106,45,#TOPBAR_RED#,#TOPBAR_GREEN#,#TOPBAR_BLUE#,#TOPBAR_SIZE#,#FONT#,#BUTTON2#,"CENTER" L,464,3,110,45,#TOPBAR_RED#,#TOPBAR_GREEN#,#TOPBAR_BLUE#,#TOPBAR_SIZE#,#FONT#,#BUTTON3#,"CENTER" L,350,3,108,45,#TOPBAR_RED#,#TOPBAR_GREEN#,#TOPBAR_BLUE#,#TOPBAR_SIZE#,#FONT#,#BUTTON4#,"CENTER" L,232,3,107,45,#TOPBAR_RED#,#TOPBAR_GREEN#,#TOPBAR_BLUE#,#TOPBAR_SIZE#,#FONT#,#BUTTON5#,"CENTER" L,115,3,104,45,#TOPBAR_RED#,#TOPBAR_GREEN#,#TOPBAR_BLUE#,#TOPBAR_SIZE#,#FONT#,#BUTTON6#,"CENTER" L,5,3,101,45,#TOPBAR_RED#,#TOPBAR_GREEN#,#TOPBAR_BLUE#,#TOPBAR_SIZE#,#FONT#,#BUTTON7#,"CENTER" /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L,64,101,151,29,255,255,255,14, #FONT#,"=REFRESH","CENTER" L,64,163,151,21,255,255,255,14, #FONT#,"=CONNECT","CENTER" L,64,224,151,21,255,255,255,14, #FONT#,"=DISCONNECT","CENTER" L,64,282,151,21,255,255,255,14,#FONT#,"=UP","CENTER" L,64,341,151,21,255,255,255,14,#FONT#,"=DOWN","CENTER" L01,240,341,187,28,255,255,255,14,#FONT#,"=Network:","LEFT" L01,500,341,187,28,255,255,255,14,#FONT#,"=Signal:","LEFT" L01,331,341,187,28,255,255,255,14,#FONT#,"CUSTOM_WIFI_SSID","LEFT" L01,569,341,187,28,255,255,255,14,#FONT#,"CUSTOM_WIFI_SIGNAL","LEFT" /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,54,93,162,51,"REFRESH_WIFI","refresh" B,54,152,162,51,"CONNECT_WIFI","connect" B,54,211,162,51,"DISCONNECT_WIFI","drop connection" B,54,270,162,51,"NEXT_WIFI","next" B,54,329,162,51,"PREV_WIFI","previous" B,228,329,250,51,"ENABLE_WIFI","enable" B,489,329,250,51,"DISABLE_WIFI","disable" /Indicators I,202,469,97,10,"MUTE:b" /Buttons B,703,405,102,78,"exit", B,601,404,100,78,"SHUFFLE", B,501,404,99,78,"NEXT", B,400,404,102,78,"PLAY", B,300,404,99,78,"PREV", B,199,404,100,78,"MUTE", B,96,404,103,78,"VOL-", B,0,404,98,77,"VOL+", B,695,0,106,72,#B1_FUNCTION#, B,579,0,116,71,#B2_FUNCTION#, B,462,0,116,71,#B3_FUNCTION#, B,347,0,114,72,#B4_FUNCTION#, B,228,0,117,73,#B5_FUNCTION#, B,110,0,116,74,#B6_FUNCTION#, B,0,0,109,72,#B7_FUNCTION#, END
Old 12-04-2007, 11:10 AM   #35
laposelemer is an unknown quantity at this point
Hi!
Some improvements!
1. I found the most useful conbination for me: ver0.4 wireless.exe and wifi_info.exe
but in the exectbl.ini I use the ver 0.3 exectbl content for run.
In this case when I call the wireless skin, the wireless.exe run correctly more or less.
The system hang up about 10-15 sec, after the time the wireless.exe closes itself. And do this only 1 time. If I recall wireless skin it shows the manager correctly.
With the ver0.4 exectbl contents the the system stays hanging. And do this every time I recall the wireless skin.
2. I can reach that to fill out the box:
in exectbl I changed "your" connection name to "my" connection name
"WIRELESS","LOAD;wireless.skin||SETTOPMOST;RR;TRUE ||RUNQW;$SKINPATH$\wireless.exe;My connection name||GETFOCUS"
and I did the same with te button codes.
Still problem:
when I load wireless skin, the wireless.exe calls the "network connections" instead of "reachable wireless network connections" and not the whole system hangs up, only the cursor ?? (it seems the wireless.exe can't close itself or run correctly,because if I shut it down with task manager everything ok) and I have to open manually the "reachable wireless network connections", after this it fill out the box.
Still don't give any info about the connection except speed and type.
I tried this skin on my work laptop, which has builtin wifi and this device has dev.no.
and I have an USB wifi for my car, it hasn't dev.no. hmm...
+1: my hungarian language windows can cause problems to your program to handle the network windows correctly? I mean my window names are translated and this can cause problem?
laposelemer is offline   Reply With Quote
Old 12-05-2007, 09:08 AM   #36
I solved my issues (not the dev id but everything else)
The code for exectbl shipping with the latest version still calls for the old wireless connection window "wireless netowrk connection" while it should be looking for the new window "wifi information".
This is the working exectbl code
Quote:
"WIRELESS","LOAD;wireless.skin;WIFI;;Wifi Information||SETTOPMOST;RR;true||RUNQW;$skinpath$\ wireless.exe||SETTOPMOST;RR;FALSE||ACTIVATE;Wirele ss Network Connection"
new issue, the connection labels are not working for me. before I didn't have a wifi network to connect to (my bad... heh) but when I connect to a network, I still get "not connected" as status.
Old 12-05-2007, 07:47 PM   #37
EL CAMINO's Avatar
yes, sorry for that ExecTBL line, my bad, about the labels, i got the bug killed now(Many thanks to johnWPB for his help).i uploaded the new wifi_man, with that issue fixed. just replace the Wifi_man.exe.Another thing in the line you fixed, replace the last "Wireless Network Connection", with "Wifi Information" as well.
Old 12-05-2007, 07:52 PM   #38
EL CAMINO's Avatar
Quote: Originally Posted by laposelemer View Post
Hi!
Some improvements!
Still problem:
if you want to use the enable/disable feature you need the DEV number if not dont worry.
+1 that might be the case, please post a screencap of the next windows,
"Network Connections" and "Wireless Network Connection" so i can fix that for you.
(i need to see the window title of each one)
Old 12-06-2007, 01:30 AM   #39
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by EL CAMINO View Post
yes, sorry for that ExecTBL line, my bad, about the labels, i got the bug killed now.
YOU got the labels bug killed?
For anyone that was having problems with the labels showing up, it should be working perfectly now. Also there is some new code to check your wireless card name automatically, but am not sure if ElCamino included it in the in atest posted version.
Overall this is a fantastic script, and blends seamlessly into Road Runner!
Just make sure if you are using it, that you are using windows default wireless connection manager, and not one that many cards come with on the install CD. Personally, I just plugged in my WiFi adapter, and had windows look at the CD for the drivers, and did not install the software on the CD.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 12-06-2007, 02:14 AM   #40
everything is working perfectly. two thumbs up
except enable/disable because of no dev-id
Old 12-07-2007, 10:42 AM   #41
beuz is on a distinguished road
Hi,
Any1 had it working with LSXVOID 3.0 pls?
Also, is there somewhere that explains how to install this? The included readme.TXT file seems to show only updates.
beuz is offline   Reply With Quote
Old 12-07-2007, 11:32 AM   #42
everything's in the readme for custom skinning. You need to go into the skin examples folder with this program and copy the contents of exectbl.ini to your $rrpath$\exectbl.ini
Old 12-10-2007, 11:53 AM   #43
In the last few days, I do some test.
So, the wireless.exe (ver.0.45) can run "correctly", but I thing the runtime is too long (1:30 min). After the box will fill correctly. But after the wireless.exe run, my "Network Connections" window will rename to "Wifi information" ??
problem: Maybe my mismatch "Network Connections" window name can cause the long runtime. I made a screencap about the "Network Connections". That window name in my language is "Hálózati kapcsolatok".
Here is a picture, you can find my window name.
I don't know what do you mean in "Wireless Network Connection". Could you explain it?
Here is an other picture, maybe you can find what you mean.
The enable/disable feature isn't workable with my wifi USB card (no dev. no.).
The connection info is now ok.
Old 12-10-2007, 05:10 PM   #44
EL CAMINO's Avatar
ok, the "wireless Connection Manager" is the window that shows the available networks in range. please do the same, as you did with "Network Connections" window.write down the window title, so i can make a custom wireless.exe for you. i' will upload a new version, that fixes the enable/disable for cards with no dev number.
Old 12-11-2007, 03:45 AM   #45
aha...
the "wireless Connection Manager" window name is the connection name. I can change it as I want. So now my connection name is "RT73 USB Wireless LAN Card". You can see in my last post 2nd picture. Or for example here is another picture from my work laptop.
I will check the updates.
Holux GPS Trouble mangus580 StreetDeck 34 11-26-2007 09:56 PM
