Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-19-2007, 05:53 AM   #16
richyrich's Avatar
richyrich is an unknown quantity at this point
Quote: Originally Posted by JohnWPB View Post
Wow, fantastic work on the hardware, skin, and configuration utility! Just wish there was a current place to buy the "whole package".
Over here in the U.S. we use PSI (Pounds per square inch) and not Bar's. In preparation to the hardware becoming avail, is there a way you could add a math conversion into the extension plugin to measure in PSI? Possibly just a check mark / drop down list in your config utility? I have never personally seen a tire pressure gauge, compressor or such using Milibar's here.
Secondly, another very useful addition, would be the ability to have a "Add Air" mode button on the skin. Pressing this & then adding air to the tires would sound an audible tone, speech or something to let you know you are at the correct pressure. It would save on adding air, checking with a gauge, adding more air, checking with a gauge... Adding air, OOPS too much...hisssssss.
Oh and just another thing... robby's software has the capability to set a maximum pressure too so when you could set that to say 32PSI or whatever havee your pc running and when pumping up your tyres when it reaches that the alert will come up "Tyre pressure acheived "
richyrich is offline   Reply With Quote
Old 10-19-2007, 05:59 AM   #17
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by richyrich View Post
Robby has already done that John! you can change it in the settings (second picture down!!)
Duh!
Sorry
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 11-01-2007, 04:47 PM   #18
dexter4000's Avatar
dexter4000 is an unknown quantity at this point
the links for the binary and surce code dont work
can i get them ?
dexter4000 is offline   Reply With Quote
Old 11-01-2007, 05:16 PM   #19
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
work for me.
Enforcer is offline   Reply With Quote
Old 11-01-2007, 05:23 PM   #20
dexter4000's Avatar
yeah , i got them
Old 11-01-2007, 05:24 PM   #21
dexter4000's Avatar
where do i download roadrunner as a executable ?
Old 11-08-2007, 12:15 PM   #22
inh
inh is an unknown quantity at this point
In the config app, when you chang the units to degrees F, does it change the units used to enter the data in the app as well? I would just download and see but I dont have a computer at the moment (at an internet cafe)
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 11-10-2007, 06:50 AM   #23
Robby BMW's Avatar
Robby BMW is on a distinguished road
Yes, all the units will be changed in the config utility and in the main RR plugin, also all the thresholds configured will be automatically converted.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 11-10-2007, 06:59 AM   #24
PontiacGA's Avatar
PontiacGA is on a distinguished road
Now if I could find a 3D picture of a Vibe to replace the BMW, it would be perfect.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Old 11-10-2007, 07:22 AM   #25
Robby BMW's Avatar
It is not essential, you can use also a 2D picture
Old 11-10-2007, 09:10 AM   #26
PontiacGA's Avatar
This is true. Maybe a top down view.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 11-10-2007, 09:33 AM   #27
juve021 is on a distinguished road
You mean like this? Top view of an S60
juve021 is offline   Reply With Quote
Old 11-10-2007, 10:59 AM   #28
Confusion Master
Enforcer's Avatar
Or a picture of a horse and cart
Old 11-10-2007, 04:23 PM   #29
erricson_nguyen's Avatar
erricson_nguyen is an unknown quantity at this point
can this be integrate to RR
Maintaining correct tire pressure saves you fuel, protects against tire wear, and guards against dangerous loss of traction. Keep track of your tires in real time with Hella's TC-400 tire pressure/temperature monitor system.
The TC-400's four sensors transmit the tire data to the cockpit display, saving your hands from getting dirty every time you want to check your tires. You can change the display's background color to match your car's lighting. This kit comes with everything you need to monitor your car's four tires.
Note: The remote sensors replace the valve stems in your vehicle's wheels. Proper installation, tire replacement, and wheel balancing should be performed by a professional mechanic.
Details:
tire pressure monitor system
4 wireless in-wheel sensors
display with choice of 7 background colors
warning buzzer and graphics
2-stage low pressure alerts, fast leak alert, high-pressure and -temperature alerts
warranty: 1 year
Top of page
erricson_nguyen is offline   Reply With Quote
Old 11-10-2007, 06:35 PM   #30
Robby BMW's Avatar
Is this kit able to comunicate with ours car pc throug USB?
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
